06-09-2021, 02:17 PM | #1 |
Supreme Allied Commander
3893
Rep 54,605
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Ohlins R&T for your G20 G21 RWD & X-Drive - Worldwide shipping!
This is the latest step in the Öhlins Racing automotive philosophy – Road&Track by Öhlins. A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises are over! We have also added a clever light-weight design with a majority of the parts in aluminium and on top of that all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products - worldwide. General > DFV (Dual Flow Valve) > Rebuildable > Corrosion salt spray tested (ISO 9227) > 2 year Limited Warranty Front > McPherson Strut > Single bleed adjuster > Spring preload adjuster (approx. 20 mm lower than standard)(5 mm on M sport) > Coil Springs (rate 80N/mm) > Dustcovers > Use with original top mounts Rear > Conventional Shock Absorber > Single bleed adjuster > Separate spring preload adjuster (approx. 15 mm(5mm on M Sport) lower than standard) > Coil Springs (rate 140 N/mm)(Additional springs at the rate of your choice will be supplied at no additional cost) > Dustcovers > Use with original top mounts F2x F3x (X-drive and RWD) 1-series (F20,F21) 2-series (F22,F23) 3-series (F30,F31,F34,F35,G20,G21) 4-series (F32,F33,F36) One in stock as of 12/19/2021 ***Vehicle with EDC will need to have EDC coded out*** ***We can ship the standard kit worldwide at a very discounted rate. PM us your address for a quote!*** BMS MU00S1 $2990 Last edited by HP Autosport; 12-17-2021 at 08:37 PM.. |
