01-02-2021, 08:16 AM | #1 |
Rep 7
2020 X3 fuel door won’t open
Hi, I have a 2020 X3 and went to fill up and the fuel door would not open. The car was unlocked. Looked through the manual and all it says is go back to your dealer. Opened the side panel in the rear compartment and found a fuse panel. No blown fuses. Is there a manual way to open the fuel door?
01-02-2021, 08:48 AM | #2 |
Cowboy Astronaut Millionaire
2314
Rep 2,885
Is it frozen?
01-02-2021, 09:04 AM | #3 |
Rep 48
Don't you just press the fuel door to click it open?
What does the fuse panel have to do with it? Is there an automated button to press and I have been doing it wrong all this time? |
01-02-2021, 11:38 AM | #6 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3511
Rep 4,207
If the car is unlocked then the only thing preventing it from opening is if the lock hasn't pulled back all the way. Pull the green emergency release in the right side of the trunk (gently) and see if you can open it now.
01-02-2021, 05:20 PM | #7 |
Rep 7
I have tried to push it in but it does not move. I have pulled the panel out and removed the insulation. The only thing I found was a fuse panel. I can not see the green emergency cable. I have gone back and looked 3 times today
01-02-2021, 06:30 PM | #8 |
Rep 7
I have the car unlocked opened the rear door, removed the panel on the right side (same side as fuel door). Removed the insulation and I can see a a small fuse box and see the back side of the fuel goes in. The only 5hing I see is a wire running somewhere towards the front of the car. It was attached and not loose. Can not see a green cable.
01-02-2021, 07:58 PM | #9 |
Rep 4,107
Never had this issue but looking at my 2021 manual there is no mention of a green cable for emergency release of the fuel door. The manual says in emergency situations you may need to go to the dealer for to release the door...
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
01-02-2021, 08:16 PM | #10 |
Rep 3,928
When I had my 2019 X3 M40i, there was no emergency release cable/wire anywhere in sight behind the panels and insulation.
They probably deleted it (like they have done so often) and never bother to update the info in the owners manual. Last edited by BobsM3Coupe; 01-02-2021 at 08:29 PM.. |
01-03-2021, 08:57 AM | #11 |
Cailín gan eagla.
70836
Rep 1,004
Out of curiosity, I opened-up the rear panel. No emergency release cable to be found. I wonder if BMW will dispatch a technician in case you are miles away from a dealership and in need of gas... Better add that emergency crowbar in my tool kit.
Spacecoast151.00 |
01-03-2021, 09:36 AM | #12 |
Rep 380
Drives: 2023 BMW X3M40 1984 911 TARGA
That is kind of unacceptable solution as dealers service is closed Sundays also,
2023 X3 M40I 2018 X3 30i M Sport
2011 550i 2005 325i 1985 535I 2017 F150 2016 GS 2004 545i 1994 525I 1984 911 TARGA 2014 HD ULTRA |
01-03-2021, 09:41 AM | #13 |
Rep 4,107
Not kind of, totally unacceptable. Why BMW discontinue the emergency handle is beyond me...
2021 X3 M40i
Spacecoast151.00 |
01-03-2021, 02:46 PM | #14 | |
Rep 7
Thanks everyone |
01-03-2021, 08:33 PM | #15 | |
Rep 67
01-04-2021, 10:47 AM | #16 |
Rep 27
Huh looks like they did get rid of the cable.
In an absolute emergency you can unbolt the rear fuse box and push it aside , then reach your hand back there and just pull the lock back so the flap opens. Would require a T30 torx socket tho |
01-15-2021, 12:26 PM | #18 |
2314
Rep 2,885
Thanks for the update. I forgot about this one I was thinking of checking on the outcome.
01-15-2021, 06:47 PM | #19 |
Photojournalist, Tech & Product Analyst
507
Rep 471
The Corvette Stingray C7 (2014-2019) has a similar set up. It turned out that you can us a plastic pry bar to gently ease the cover away from the body and then slide the entire cover off of the hinge mechanism (without it doing any damage).
When my X3 was just a week old, I was sitting at a light when two guys came running between the two lanes of cars stopped at the light. The first guy was really flying and managed to hit my gas door with apparently a lot of force as he ran by. The door opened and flew (slid) off of the hinge and landed next to the front right tire. After I realized what had happened I got out, retrieved the gas door (which was auto locked along with the doors, since we had been driving up to the light) and it slid back on to the hinge with no damage. So, my somewhat long winded post is intended to state you can probably use a plastic pry bar to open our gas door in an emergency.
Current:2024 i4 Mineral White Metallic with Blue Exterior Accents, Canberra Beige Perforated SensaTec, Premium Package, Driving Assistance Pro Package, Drive Recorder. 2019 X3 Mineral White Metallic, Caberra Beige interior with most options. Corvette Stingray Arctic White w red interior.
Past:2002 Z3, Corvette Stingray and about 40 other cars |
