11-13-2020, 11:33 AM | #1 |
Joint Chiefs of Staff
24482
Rep 191,469
BMC X3M X4M Filters **NEW PRODUCT**
Order Link
https://x-ph.com/bmc-x3-x4-f9x-m-models-filters/ The panel / cylindrical air filter is commonly referred to as "replacement air filter". It is installed in the vehicle's original airbox to replace the OEM air filter. It is made of highly performing materials that allow an increased air flow combined with a more efficient filtration, guaranteeing containment of all impurities from as small as 7 microns (compared to OEM's 10 microns). Air flow chart for a sample BMC air filter against an OEM paper filter Temperature 25C° - Humidity 25% - Pressure 1020mbar Test ran with oem airbox, and the related air flow constrictions. This chart has a pure illustrative purpose and does not refer to the present filter. BMC air filters are produced using a "Full Moulding" system that enables the characteristic red filter to be realized from a single mould with no welded joints thus avoiding easy breakage. The rubber used in BMC air filtering systems has a long life, is very durable and has optimum adhesion characteristics to all shapes of airboxes. BMC filters are made of a multi-layered cotton gauze soaked with low viscosity oil covered with an epoxy coated alloy mesh to ensure protection from petrol fumes and oxidization due to air humidity. All BMC air filters are pre-oiled, and they can be washed and regenerated by using the appropriate BMC regeneration kit. X 3 (G01, F97) M [Full Kit] HP 480 year 19 > chassis F97 engine code S58B30A X 3 (G01, F97) M Competition [Full Kit] HP 510 year 19 > chassis F97 engine code S58B30A X 4 (G02, F98) M [Full Kit] HP 480 year 19 > chassis F98 engine code S58B30A X 4 (G02, F98) M Competition [Full Kit] HP 510 year 19 > chassis F98 engine code S58B30A
09-29-2023, 11:00 AM | #2 |
24482
Rep 191,469
10-23-2023, 09:15 AM | #3 |
24482
Rep 191,469
11-24-2023, 08:28 AM | #4 |
24482
Rep 191,469
01-24-2024, 09:35 AM | #5 |
24482
Rep 191,469
03-01-2024, 08:27 AM | #6 |
24482
Rep 191,469
03-18-2024, 08:25 AM | #7 |
24482
Rep 191,469
04-08-2024, 09:02 AM | #8 |
24482
Rep 191,469
04-18-2024, 10:00 AM | #9 |
24482
Rep 191,469
bump
04-23-2024, 09:37 AM | #10 |
24482
Rep 191,469
bump
04-26-2024, 08:54 AM | #11 |
24482
Rep 191,469
bump
05-02-2024, 11:19 AM | #12 |
24482
Rep 191,469
bump
05-07-2024, 01:10 PM | #13 |
24482
Rep 191,469
bump
05-14-2024, 12:43 PM | #14 |
24482
Rep 191,469
bump
05-21-2024, 11:33 AM | #15 |
24482
Rep 191,469
bump
