Login
XBimmers | BMW X3 Forum • Quiet beeping noise driver side |
10-31-2020, 05:32 PM | #1 |
![]() 28
Rep 100
So today I heard a very quiet but not normal beeping noise that beeps every 2-3 seconds coming from the front driver side. When driving highway speed I can't hear anything.
Has any one hear the beeping noise during slow speed and on park? |
11-02-2020, 07:26 AM | #2 |
![]() 10
Rep 62
I have a chirping sound coming from sometimes under the steering or sometimes it's the passenger side. Can't figure out what it is. Has taken it in to show but it never cropped up. It's usually when I'm parked or in slow moving traffic.
Have not figured it out what it is. Anyone have any clue? |
11-03-2020, 09:16 AM | #4 |
![]() 10
Rep 62
Here is a link to the audio
https://www.dropbox.com/s/b4wro4k52q...chirp.m4a?dl=0 You can hear the chirp at 9, 14,26,35,40 seconds! |
11-05-2020, 01:01 PM | #6 | |
![]() 1075
Rep 1,924
On my older Nissan, several people have issues with actuators in the heating/cooling system. Could that be the issue? Does this happen when you are switching the air to the different vents? |
11-05-2020, 09:04 PM | #7 |
Rep 16
Clicky noise, not beep. It makes the same noise when manually switching vents. With AC in auto, it clicks every few seconds (can keep going for several minutes or longer), but I'm not actually feeling any airflow changing.
11-06-2020, 06:51 AM | #8 |
![]() 1075
Rep 1,924
That sounds like an issue with the actuators.
11-06-2020, 01:38 PM | #9 |
![]() 1075
Rep 1,924
To add (from my Nissan knowledge though it should be applicable), the actuators control things like direction of airflow (face, windshield, feet, etc.) but also how much hot/cold air to mix (this was called the blend door on my Nissan).
The blend door was responsibile for exactly the symptoms you describe. Basically it is not mixing the right volume of cold/hot air to give you the desired temp. I do not have this issue on my X3Mc, which is pretty much the same as the G01. I would not take the dealer's answer. Mine blows hot or cold with extreme prejudice depending on what I select for the temp. |
