09-29-2020, 06:16 PM | #1 |
Rep 11
Help F25 fuses
Fuse diagrams are so confusing! Need help. Which fuse controls the Parking Brake/warning? Front box, rear box? Which one is it??? And where is it? X3 2016!
09-30-2020, 07:06 AM | #2 |
Rep 11
You mean there's no fuse for the actuator which in turn controls the warnings? The older models had the "P" in the fuse diagram but P is nowhere to be seen. I guess the question should be which fuse controls the Parking Brake actuator? Has to be one! The dealer will say I need a new actuator ($$$$$) when in fact who knows, they might just change the fuse! That's the issue!
09-30-2020, 03:21 PM | #6 |
Rep 1,046
I doubt if there is a fuse specifically for the parking brake warning light. There is a fuse for the dash. The dash has a number of warning lights. Each one would not have it's own fuse. Why not just fix the brake issue? This way the driver will be warned prior to a catastrophic or systemic failure.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
