XBimmers | BMW X3 Forum BMW X3/X4 Forums BMW X3M (F97) and X4M (F98) General Forum (2018+) NEW RELEASE: Dinan BMW F97 X3M and F98 X4M Axle Back Exhaust Systems
      07-14-2020, 02:56 PM   #1
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
BIMMERPOST
     Featured on BIMMERPOST.com
Part Number(s): D660-0086 & D660-0086-BLK
Applications:
  • 2020-2021 F97 X3M
  • 2020-2021 F97 X3M Competition
  • 2020-2021 F98 X4M
  • 2020-2021 F98 X4M Competition
Product Page(s) / Pricing:Release Date: Available Now!
Description: The “baby M’s” of the ’X’ family just got a bit more big brother like. With more volume and a deeper, more aggressive note courtesy of the Dinan axle back exhaust system, the F97/F98 now stand on the precipice of rivaling, or even surpassing, its V8 siblings --- at least, in regards to sound. With an intoxicating and menacing sound befitting of a high performance SUV the X3M/X4M holds its own amongst the pantheon of more traditional M’s.
In order to achieve the deep and throaty signature Dinan sound the system incorporates larger 76mm tubing (vs 70mm stock) that allows freer flow through the entirety of the system but specifically to both outer pipes when the enlarged valves are open. The resulting flow and sound mimics an awe-inspiring straight pipe solution with a deeper, fuller tone, a defining element of all Dinan exhausts. In contradiction to the aggressiveness resulting from open valves, when the valves are closed, all gasses are forced into the muffler for sound deadening and exit the two inner tips. Regardless of valve position, the intimate nature of the interior is retained so conversation can continue without an excessively loud drone courtesy of drone abatement technologies housed within the can. With the Dinan exhaust equipped on the X3M/X4M you get the best of both worlds; aggressive tone/sound and civility
Perhaps equally important to the sound of the installed Dinan axle back system are the resulting aesthetics. With a nearly perfect symmetrical design, the raw muffler and pipe routing are pleasing to the eye even when the matching proportions are only partially visible after install. The piping culminates into four massive 114mm (4.5”) tips that fill up the previously spacious factory cut out in the valance without appearing to be oversized and unnatural. The imposing tips utilize a new tip design with an inverted clamp neck. The new style allows for two very important things to happen. The first is the ability to have a longer tip sleeve length without sacrificing real estate for a clamp neck thus allowing larger tips even when there is limited straight pipe to clamp on to. Secondly, the interior clamp neck means that the clamp itself is almost completely hidden from view for an unblemished install. Dinan has retained its signature straight cut tip design, safeguarding its unique and elegant styling position amongst a crowded marketplace full of angle cuts. With systems available with either black ceramic coated or polished clamp-on, and laser engraved exhaust tips, there is a version that is sure to meet your individual aesthetic needs.
Features/Benefits:
  • More Power: Max gains of +8 HP @ 6600 RPM, +6 FT-LB @ 6600 RPM.
  • Enjoyably louder, sportier sound.
  • Quad 4.5" (114 mm) diameter clamp-on, double-walled laser engraved exhaust tips. Available in ceramic black or polished.
  • Tuck-it tip design ensures a nearly flawless and unencumbered visual appearance
  • 100% 304 brushed stainless steel construction w/ TIG welding.
  • Larger diameter piping for increased flow (76mm vs 70mm).
  • 5 lbs lighter than the stock system.
  • Computer controlled exhaust valves retained, limiting noise during low speed driving and opening fully during high-load conditions.
  • Twin exhaust valves are a whopping 76mm diameter, making them 30% less restrictive than the OE valves.
  • Easy bolt-on installation with included mounting hardware.
Appreciate 12
      07-14-2020, 03:17 PM   #2
AlexFL
Drives: BMW X3MC, Audi RS7 (pre-ord.)
This is awesome. Thanks for sharing!
      07-14-2020, 03:31 PM   #3
_x3M_Competition
_x3M_Competition's Avatar
140
Drives: 2020 x3M Competition DGM
Beautiful!
2020 Dark Graphite Metallic x3M Competition
Mods: BM3Tuning x Paul Johnson Tunes Custom Full E85 stage1+, MSS Adjustable Springs, AutoTeknic Matte Black Paddle Shifters, RG Front paint-matched reflectors, H&R 15mm F/R Spacers.
IG: _x3M_Competition
      07-14-2020, 05:39 PM   #4
ckrieg
Drives: X3M Comp
Sounds fantastic!
      07-14-2020, 06:14 PM   #5
SWOT1
The Hammock Man
SWOT1's Avatar
Drives: X3MC, X3 M40i, E93 M3
Me likey!
- '20 X3MC | Alpine White | Black Alcantara/Midrand Beige | loaded | 295/265 PS4S
- '09 E93 M3 | Alpine White | Bamboo Beige Novillo | DCT | loaded | Chrome M220 Wheels - 275/255 PSS
      07-14-2020, 06:20 PM   #6
FrankieNuo
FrankieNuo's Avatar
Drives: F97 X3M Comp RR Velar HSE P380
Considering the price and sound, this has to be the best exhaust available. Nice work!
      07-14-2020, 06:49 PM   #7
john_char
Drives: BMW 2020 X4 30i
Wish there was something like this for the 30i. would love my 30i to sound like the x2 m35i....
      07-14-2020, 07:01 PM   #8
FSociety
Follow Me on IG @BMW_F9X
FSociety's Avatar
Drives: F98 X4MC, F90 M5, F80 M3 ZCP
Very nice, any cutting required?
F98 X4M Custom STG1 1/4m 10.61@130.92 60-130 7.5 1st WR
TristateBM3 STG2-- 1/4m -- 60-130: 7.3 -- 0-100mph: 10.18
IG: @bmw_F9X
      07-14-2020, 07:32 PM   #9
pluckydks
Drives: 2005 M3 ZCP, 2020 X3MC
Unless it's full catback system, I'm 95% sure there would have to be cutting.
2005 Estoril Blue M3 ZCP, OEM CSL bootlid, AC Schnitzer everything else
2020 Phytonic Blue X3M Competition, Remus Race exhaust, AC Schnitzer everything else
Instagram
FSociety3574.00
AlexFL5638.00
      07-14-2020, 07:39 PM   #10
Dinan_Engineering
Drives: Any BMW
Correct. Axle back so cutting will be required. A full complete cat-back would be the only way to avoid that reality. We will also be releasing a resonator delete/x-pipe to accompany the system for those that want a bit more volume as well — it got delayed a bit unfortunately but it's coming.
pluckydks507.50
AlexFL5638.00
F85MTuNED1314.00
LimiX4m40138.00
BLACK OPS107.50
      07-14-2020, 07:40 PM   #11
pluckydks
Love the massive 114mm tips!
Instagram
Will Pwr658.50
      07-14-2020, 07:45 PM   #12
skioutwest
Drives: 2020 X4MC, 2017 M3ZCP, 2014 M5
Will the resonator delete be available as a stand alone option, or is it designed to only mate to the Dinan exhaust
      07-14-2020, 07:48 PM   #13
Dinan_Engineering
Drives: Any BMW
Can be stand alone.
      07-15-2020, 06:52 AM   #14
bernpromos
bernpromos's Avatar
24
Drives: BMW X3 M
Any idea on whether BMW dealers would consider this to void the factory warranty?
      07-15-2020, 11:02 AM   #15
smithf80
smithf80's Avatar
Drives: '18 F80 M3 6MT
2018 F80 M3  [5.00]
There is almost no circumstance under which an exhaust should void your warranty other than any warranty on your exhaust system, or like, if it fell off while you were driving and damaged and bunch of other stuff, which is unlikely, but, I suppose, possible.
      07-15-2020, 11:09 AM   #16
12v_dub
12v_dub's Avatar
Drives: 21' M340i
Looks great with the extra wide exhaust tips. Any issues with fitment for m40i ?
      07-15-2020, 11:26 AM   #17
knepsterd
Drives: 2018 M3 BSM
I know of someone that got a crack head and BMW NA said due to CAI. Owner lost.
      07-15-2020, 11:28 AM   #18
knepsterd
Drives: 2018 M3 BSM
Any aftermarket is still a possible red flag if BMW NA wants to be an ass. The money alone to take to court and fight is stupid. So going in there and taking the aftermarket route is always a remote possibly. Exhaust is more than likely bad cats need to be replaced on your dime.
      07-15-2020, 11:48 AM   #19
AlexFL
BMW NA is not stupid. BMW lives off mod-happy, returning customers like us and they will never us flag us for petty stuff like aftermarket exhaust. My BMW dealer even offered me to order and install the Akrapovic exhaust.
pluckydks507.50
      07-15-2020, 12:09 PM   #20
knepsterd
Drives: 2018 M3 BSM
It's a case by case, dealer and SA. At least up here in NY NJ tri state. Some dealers are more mod happy, others a downright Debbie downers.
      07-15-2020, 12:14 PM   #21
AlexFL
The Debbie downers should not sell any M cars. My dealer told me that allegedly up to 50% of all sold M cars are getting performance modded (exhaust, tune etc.) by their owners. Mod-happy, performance-oriented buyers buy BMW M cars... that's how it works.
dhurng388.50
slowF3276.50
      07-15-2020, 12:44 PM   #22
pluckydks
The dealer for my E46 M3 installed my exhaust for $75. After inflation, that's probably $150 now lol.
Instagram
AlexFL5638.00
dhurng388.50
Copyright ©2000 - 2021, vBulletin Solutions Inc.
