Login
XBimmers | BMW X3 Forum • DIY: Battery Replacement + Registration + Coding |
07-12-2020, 06:51 PM | #1 |
![]() ![]() ![]() ![]() ![]() 267
Rep 888
Drives: 08 135i M Sport 6MT, 15 X3 35i
Hi all,
Recently replaced my battery, so here is a brief overview. Batteries tend to last around 5 or so years, and our cars are pretty sensitive to battery issues. I have had a "Battery faulty or worn out" code stored and the battery is original, with a week 10/2015 date stamped on the top of the negative terminal. All batteries will have a date on them somewhere, in the format of WW/YY (WW between 01-52 weeks followed by YY for the year). Since mine was original, I had the stored code, the battery was at 78% of its capacity based on diagnostics, and was starting to see some odd behavior it was certainly time for a replacement. It's important to get the correct battery for your vehicle; Battery type, capacity (Ah, Amp Hours) and CCA (Cold Cranking Amps). Without going into much detail, most BMWs will use an AGM (Absorbent Glass Mat) battery. If you're curious, fill your boots: https://batteryuniversity.com/learn/..._glass_mat_agm Long story short though, they suspend the battery acid in a glass mat so they cannot be spilled if the battery is ruptured. I purchased a new one from Costco, shipped to my door for significantly less than I could get one from anywhere else. New specs are slightly different, summary below. I was not able to find a 105Ah anywhere but the dealer. Original: AGM, 105Ah, 950 CCA New (Energizer H8 EA95-L5): AGM, 95Ah, 850 CCA The most straight forward approach is to match the factory battery type exactly, as it saves you a step. Some people seem to be against registering the batteries, citing it's silly and not required because other cars work fine without this step... I disagree. The vehicle is smart, it charges the battery based on its capacity, age, and likely other factors to stretch the battery life as long as possible and keep the electronics in the car functioning at their peak. To this end, it's very important to register a new battery and if the battery is a different type, code it. More information on the IBS can be found here if you are interested: https://www.newtis.info/tisv2/a/en/f...ttery/BdzoqEna https://bimmerscan.com/bmw-intellige...ry-sensor-ibs/ Procedure: 1. Identify the Factory Battery, source and purchase a new battery The information is on the battery sticker. 2. Remove the Existing Battery Open the liftgate, remove the lower trunk liner by lifting via the handle ![]() Next open the battery compartment. At the rear there are two plastic retainers that you can use a flathead screw driver to rotate 90 degrees. The retainer is shaped like a "T" on the bottom and rotating it allows the "T" to slide through the slot. After that, remove the push pin type retaining clips (4 total). You will need a cats claw or "Y" shaped trim removal tool to remove these. It can also be done with a small flathead screwdriver or pick, but you will almost certainly damage them by not using the proper tools. ![]() 3. Remove the Battery A. Take a picture of everything assembled for reference. ![]() B. Disconnect the Negative battery terminal. The vehicle MUST be completely powered down for this. Ie, ignition fully off. If you have a battery charger it must not be connected. Using gloves is also a good idea when working with batteries and high voltage electronics. C. Disconnect all cables from the Power Distribution Box (big red box on the left): https://www.newtis.info/tisv2/a/en/f...older/1M33WCXv D. Disconnect the cable retainers from the battery retention bracket. These can be removed using a cats claw or trim removal tool. Pry them out; they can be pushed back into place after. Make sure the plastic is warm, it may break if cold. Removing these allows you to move all cables out of the way to access the bracket. E. Remove the Power Distribution Box by using a flathead screwdriver to pop the shiny metal tabs free at the front/back. There is a 'V' shaped point you slip the screw driver into and pull away from the battery; they will pop free and the box can be lifted out. Make sure the box is first unbolted from the Intelligent Battery Sensor. After this, disconnect the Intelligent Battery Sensor and Positive Battery Terminal. ![]() F. Remove the battery retention bracket. There are two bolts, one at the rear, one at the front. The bracket then lifts up/out G. Remove the battery holder(s) at the bottom. Mine had only one L shaped holder at the front right of the battery, yours may have one at the front, one at the side. It's held in place by a single bolt, unbolt it and remove. H. Remove the battery vent tube from the left of the battery. It's a little plastic plug connected to a vent line. You can see it disconnected in the above photo in step 2E. G. Lift the battery up and out. 3. Install the New Battery Before installing the battery it's important to install the vent plug in the negative terminal side vent. My battery was supposed to come with one, but did not. I used a pick tool to pull the vent plug from the factory battery and install it in my new one. Info specific to AcDelco batteries, but the process is universal: https://www.techconnectcanada.com/bl...ery-vent-plugs A. Lift the battery in to place B. Install the vent hose into the positive side vent port C. Reinstall the battery retention bracket and battery holders at the bottom, torque spec for these bolts is 10nm. I just went hand tight as 10nm is not much. D. Reconnect the positive terminal/IBS E. Reinstall the Power Distribution Box by sliding it over the threaded rod on the IBS, it should clip into place with the metal tabs top/bottom. F. Reinstall all remaining cables, except the negative cable, bolt the Power Distribution Box to the IBS, and bolt the positive cable to the Power Distribution Box. Torque for both is 15nm, I also just did these by hand because again, it's not a high value. Reinstall the negative battery cable. G. Reinstall the battery compartment cover / trunk storage bin. The retainer pins are two pieces, gently 'feed' the top of the pin into the seat so it's just started, push the whole assembly into the hole in the metal trunk bed, then push the top of the pin down. It will cause the 'legs' on the bottom to flare out holding the fastener in place. Next push the "T" style retainers you used a flathead on at the start back down, rotate them 90 degrees. Reinstall the trunk liner/lid. 4. Battery Registration This is the more complicated part, in that it needs a proper scan tool or software. I'm using ISTA+. You can do a google search and find lots of info/where to download it. You will also need an OBD to ENET (RJ45) cable to connect with the car. The procedure is straightforward, the following video documents the steps. If you have a battery that is different than the factory one, you will need to code the correct values after this step. 5. Battery Coding Only do this if you have a battery which is different than your factory one. To do this, I used E-sys, however there are also other options. I believe Carly and BimmerCode have the ability to code a battery but I'm not certain on that. Do some research and decide what software works best for you. Once in E-sys and connected with the car the process is simple. A. Access the CAS module B. Line 3702 C. VCM_BATTERY_CLASS D. Change the value to the one closest matching your new battery type. My battery was a 105Ah battery, replaced with a 95Ah battery. 95 is not an available value so I coded it to a 90Ah value. Once complete and the module is flashed, enter ISTA+ again, go to the battery registration procedure and review battery replacement info. The readout from my car is below, you can see this is the first battery change at 98,170km, and that the current battery is a 90Ah AGM. ![]() After this pack everything up, and enjoy your ride again!
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles ![]() Last edited by 6MT_Addict; 07-12-2020 at 07:00 PM.. |
07-12-2020, 07:50 PM | #2 |
![]() ![]() 32
Rep 90
Great write-up and pix. I'm book marking this because I'm coming up on six years with mine and will need to replace the battery soon.
Pat
2015 F25 X3 35i M Sport - Carbon Black |
07-14-2020, 01:01 PM | #3 | |
![]() ![]() 683
Rep 1,715
fyi, I had Pep Boys replace the original lead acid battery in my 2012 model year X3 2 years ago - new AGM battery installed and coded/registered- $215 out the door, in SoCal. |
07-14-2020, 03:17 PM | #4 |
![]() ![]() ![]() ![]() ![]() 476
Rep 877
Nice writeup. Admit it, you killed your battery when you had your doors open for days wrapping the car.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 |
07-14-2020, 04:03 PM | #5 |
Rep 888
Hahaha that may have had something to do with it.
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles ![]() |
08-11-2020, 08:35 PM | #6 |
Rep 9
I replaced the battery on my 2011 X3 35i today with the help of this write up. Replaced with Energizer AGM battery from Costco which costed me about $315 delivered to the door. However, I scanned the vehicle with Carly before and after replacing the battery and it shows several issues with the vehicle.
Before replacing the battery the codes were as below: Engine Fault code: 216111 Start aggregate pinion starter: exceeded number of motor starts Fault code: INFO 213604 Power management, closed-circuit protection: closed-circuit current violation (0x213604) Fault code: INFO 10AA20 Coolant temperature sensor, plausibility, cold start: temperature too high Fault code: INFO 10AA30 Coolant temperature sensor: group error After replacing the battery and registering the battery: Engine Fault code: 216111 Start aggregate pinion starter: exceeded number of motor starts Fault code: INFO 213604 Power management, closed-circuit protection: closed-circuit current violation (0x213604) Fault code: INFO 10AA20 Coolant temperature sensor, plausibility, cold start: temperature too high Fault code: INFO 10AA30 Coolant temperature sensor: group error Telematics Fault code: INFO 61A003 Not enabled sim card Fault code: INFO 619400 VSM event vehiclestate Central Gateway Fault code: INFO 101008 Not resolvable ambiguous routing - sg is not in the target table svt Fault code: INFO 100100 Lost contact with fcm slave Fault code: INFO 100104 HW weckgrund zgw Fault code: INFO 100204 Botschafts monitoring: failed system context signal Junction Box Module: Fault code: INFO 002031 VSM event vehiclestate Fault code: INFO 002040 Pdc: reset due to watchdog timeout Check Control Module: Fault code: INFO 482451 Sensor - rotor position - steering angle - loss multiturn value Airbag: Fault code: INFO C95423 Icm: steering angle front axle effectively - signal invalid Instrument Cluster: Fault code: INFO 93000A Function block (method): signs of life does not come on time Fault code: INFO 93003F Sender node: error in function addressed Integr. Chassis Module: Fault code: D014A1 Signal fault (actual position EPS, ID: AVL PO EPS) - qualifier Fault code: INFO 482651 Slip angle estimator - inputs not valid sbs Fault code: INFO 482656 Slip angle estimator - internal degradation due to sbs Fault code: INFO 482782 Steering angle aufsetzalgorithmus - stacked by index signal While most of the messages were categorized as "Not serious" the below 2 are of concern to me: Engine: Fault code: 216111 Start aggregate pinion starter: exceeded number of motor starts Integr. Chassis Module: Fault code: D014A1 Signal fault (actual position EPS, ID: AVL PO EPS) - qualifier I could not find any good write up on the above. Any inputs/thoughts ? Last edited by Wrangler; 08-11-2020 at 08:37 PM.. Reason: grammatical errors |
08-12-2020, 04:54 PM | #9 |
Rep 888
A good number of these look to be related to the steering angle sensor. Odd it would pop up after a battery replacement though.
Regardless, try the steering angle sensor reset, google it for a how to, pretty straightforward from what I remember. Plugging the code starter into a fault code lookup gives this info... might be an issue with the starter motor. https://bmwfault.codes/XMLDiagView?d...AAOAA3ADAANAA=
07-02-2021, 12:29 PM | #10 |
Rep 1
Thank You!
Thank you this guide is exactly what I'm looking for. I have pretty much the same setup.
I know this thread is older but if you still receive notifications I was wondering if you could help me out. I'm like new to cars and everything so if this is a silly question, my bad: Did you use a battery tender or a Keep Alive Memory OBD thing to make sure that all your presets, seat memory and stuff stayed alive? I purchased my car used so I'm afraid when I install the new battery, I'm gonna brick the thing and won't be able to find a radio code or whatever. I have both bimmerlink and bimmercode to do registering and recoding if that helps. |
evilchargerfan221.50 |
07-02-2021, 03:47 PM | #11 |
![]() ![]() ![]() 261
Rep 359
You can disconnect the battery (in general, or in the process of replacing the battery) and you will not lose presets, seat memory, profiles, idrive selections, or any of the coding you have done to date.
The trip computer and date/time will reset. If you have the auto start/stop set to remember the last setting, it will default to on the first time, so you'll have to press it to off once, but then it will remember it going forward.
Current:
2017 F87 M2 6MT 2013 F25 X3 3.5i 2008 E90 M3 6MT |
03-31-2022, 05:09 PM | #13 |
Rep 3
Great Instructions!
Just replaced the battery in my 2015 X3 35i with no problems using these excellent instructions, and registered it with BimmerLink. Found the replacement at Batteries+Bulbs with the same specs (105 Ah, 950 CCA) as the OEM (which apparently is no longer available).
tracer bullet1207.50 |
