06-04-2020, 09:43 AM | #1 |
Rep 3
PDC fault
I've purchased a 2013 X3 F25 and found out the parking control doesn't work, I have no warrantee on the vehicle so can't go back to the dealer.
I've checked everything I can but all I get is a warning message on the xdrive screen saying the parking sensors are not working refer to service for rectification. I get the car image and fans front & rear in grey and then the fault screen kicks in soon after. Can anybody give some advise as to how this can be rectified, or is it a dealer only repair. Also can you clarify where the PDC is located as there are various conflicting theories on BMW forums whether its in the boot or in the front passenger footwell |
06-04-2020, 10:34 AM | #2 | |
Rep 5,096
deeLow148.00 |
06-04-2020, 01:17 PM | #3 |
Rep 3
I don't have a diagnostic machine to plug into OBD, Ill have to get an auto electrician to do a diagnostic test for me, I can then get any fault codes. Hopefully It will give me all the info needed to repair the issue. Thanks for your help
06-04-2020, 01:48 PM | #4 | |
Rep 5,096
https://bmwfault.codes You'll need to select your engine from the drop down list. Good luck! |
07-23-2020, 11:53 AM | #6 |
Rep 4
Park distance control failure
2011 X3 35i The PDC started working intermittently a few months ago, but now not working at all. OBD reader shows no faults. A youtube video suggested to spray WD40 on the sensors - did not work for me. I do most mantenance on this vehicle and quite handy with tools etc. Does anyone have suggestions for diagnosing he problem, and the fix? (other than using the $BMW$ dealer)
07-23-2020, 02:21 PM | #7 | |
Rep 5,096
