05-26-2020, 04:49 PM | #1 |
N
34
Rep 631
Front Strut DIY? (F25)
Trying to replace my front struts but have a hang up on the bolt that clamps on the bottom of the strut body, whatever you want to call it. Are these bolts splined or need pounded out? I can't for the life of me get mine loose and have practically run out of options besides trying to beat it through with a sledge or something. Any tips?
05-26-2020, 05:17 PM | #2 |
Sandy
Rep 29
Look at this site with lots of good info, ensure you put your car specs in first, then go to the relevant pages
https://www.realoem.com/bmw/enUS/par...-X3_30dX&mg=31 or use this one https://www.newtis.info/tisv2/a/en/f...neral/F13OGy9X |
05-26-2020, 05:52 PM | #3 |
Rep 1,059
I did mine earlier this year. Hammer a screwdriver or chisel to expand the clamp around the strut. Make sure you have the coils compressed and they should wiggle out with some persuasion.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
tracer bullet3438.00 |
05-26-2020, 05:58 PM | #4 |
N
34
Rep 631
That's kind of what I figured needs to happen. Did you leave the bolt or did yours come out? ...because that's my main issue, everything else I should be able to figure out but this frozen bolt issue is holding everything up.
05-26-2020, 06:52 PM | #5 |
Rep 25
You need something like this: https://raceland.com/product/bmw-strut-spreader/
Did a lot of VW/Audi struts which are of similar design. |
05-26-2020, 07:08 PM | #6 |
Rep 2,650
Drives: Z4MC, X3-35i,525i, Corrado G60
So you were able to get the nut off, but the bolt won't budge? Probably need to soak it with something like PB Blaster overnight, a little heat may help too. The shop manual says to replace the nut and bolt, not sure how many people actually do that?
05-26-2020, 07:17 PM | #7 | |
N
34
Rep 631
05-26-2020, 07:20 PM | #8 |
N
34
Rep 631
Yeah I managed to get the nut off but the bolt won't budge. Identical to how it was on my 335 but on that the bolt managed to move and come out, this one is basically seized. Tried 2ft worth of breaker bar only to break a socket and an impact that didn't do anything. So next attempt is beating the p!ss out of it I guess
05-26-2020, 07:48 PM | #9 |
Rep 2,650
05-26-2020, 08:02 PM | #10 |
N
34
Rep 631
05-26-2020, 11:22 PM | #11 |
Rep 1,059
As mentioned, soak the bold with pb. Use a torch. Heat breaks frozen fasteners loose. Can you chisel or screwdriver the clamp space open? If so, you can leave the bolt.
05-27-2020, 11:42 AM | #12 |
N
34
Rep 631
Probably the route I'm going to try. Fingers crossed! Have to also attend to a wheel bearing as well while I'm at it, the hub assembly itself so hopefully that goes much smoother
05-27-2020, 05:06 PM | #13 | |
DOPE
148
Rep 758
05-27-2020, 10:51 PM | #14 |
N
34
Rep 631
Yes, I may even have a bad rear wheel bearing as well, tbd. I threw in the towel today trying to fuss with that bolt and getting that strut out. Called up a local indy shop and they're going to handle it. I was ready to throw a hammer through the window; I like being able to work on my cars myself. Then I added a little something from MHD and it put a big smile back on my face. Not quite as fun as the 335, but it'll do!
I appreciate the help guys |
05-29-2020, 10:38 AM | #15 |
Rep 1,059
I had a bad strut as well a wheel bearing. 80,000 miles. Unfortunately, they were about 6 months apart so I got to revisit the scene of the crime. The hub replacement was very easy.
