05-16-2020, 07:41 PM | #1 |
Rep 2,221
Finally Installed my eBay Mudflaps/Splash Guards/Rock Guards
Some people don't care for them, nothing to see here for you..move along
Some background, I was disappointed to learn there were no OEM mudflaps for the X3M as I find them useful for preventing sand blasting of my paint, dirt on the side, and sling from tire dressing. I saw some innovative options like JLT who got a universal one and had a shop cut them: I had those sitting in the garage and was pretty convinced I would not do a great job in cutting them. I also wanted more of an integrated one. I found this thread on the G01 forum where people with the M40i found an eBay option for the 2018 - 2019 "M Sport" X3 During a test fit they seemed as if they would work. I have ruined paint before with mud flaps that rest on it so I wanted to protect my paint. I already had PPF on the front but not the rear. I also had the entire car ceramic coated. After making some templates with paper, I put PPF on the fender flairs in the rear. It turned out pretty good for my first time, the hardest part was cutting to the right size. The ceramic coated paint was pretty slippery but I think it will stick ok as I'm careful washing. You have to remove the pop rivets (2 for each front, 1 for each back) and a couple/few 8mm bolts. I found this vid extremely helpful. I modified the technique and used a small torx bit and a 2x4 using the tire tread for leverage. What was great about this method is the bit was long enough to pop the center of the rivet, but short enough to not have the center part fall out - they all came out in one piece. The mud flaps I installed came with these screws and fender clips with a screw hole (I'm sure there is a technical name but I do not know what it is): I used those on the backs but ran out of fender clips. Luckily the original universal set of mud flaps I didn't end up using had the same but in black with an 8mm bolt head. Here's what they look like on the fronts: I tried to use these pop rivets I got on Amazon, but the flaps really required a screw to pull them tight to the fender. Moreover, I could not get the pin to pull through with pliers. Not a fan of this brand but it could be they require a rivet gun. I was working in my tiny 1 car garage so couldn't take off the wheels. Using my Skewdriver, which if you do not already own, I highly recommend getting, I didn't even need to turn the front wheels. I've used this tool more than any other tool I own. Anyway, once I abandoned the pop rivets and used the screws, things went pretty easy. Overall I'm very happy with the look and fit for $35 and some wrenching. They look like they will completely protect the car and they are not that noticeable on my Dark Graphite X3MC. |
14
r33_RGSport12967.50 AlexFL7837.00 Craig 1527232.50 pluckydks621.50 cfm56d7b5886.00 Transfer5254.00 sinbad4782.50 Kingpin4386.50 DucatiT1098S163.50 leon360x139.50 bmwmdistrict908.00 dmanb2b2124.50 Paavju116.50 TacosRule!606.00 |
05-16-2020, 07:49 PM | #3 |
Rep 6,589
05-16-2020, 10:54 PM | #4 | |
Rep 2,221
I can’t count how many times I’ve used it over the decades. You can even attach it to a drill if needed. |
elodewijk1.50 |
05-17-2020, 08:31 AM | #6 |
Rep 2,221
Thanks JLT!
I stared at those universal mud flaps for some time and kept on saying "There is no way I'm gonna cut those and not look like a monkey with a chainsaw did it When I ran out of the screws/clips, I tore apart my garage looking for more and came across that handy pack of hardware....perfect and saved me a trip! |
JTKY4.50 |
05-17-2020, 08:49 AM | #7 | |
Rep 69
05-17-2020, 08:56 AM | #8 | |
Rep 2,221
That hardware pack on the universal flaps (the flaps I did not use) was nicer because the screws are black (though the finish seems to wear easily) and they had large washers and were very similar to the OEM ones with a 8mm bolt/philips screw combo head. The screws that came with flaps I installed were thicker though. I'm sure you can get a pack like that at a hardware store/Amazon. I used 6 in total (4 front/2 back - in addition to the existing OEM screw bolts). If I were to do it again, I would have used the black ones in the back as well. I don't know how they will hold up to rusting but I'm not really concerned. |
05-17-2020, 09:03 AM | #9 | ||
Rep 69
06-06-2020, 03:46 PM | #11 |
Rep 931
OP for the second time I followed your lead and was not disappointed! Thanks again for sharing.
06-06-2020, 05:07 PM | #12 | |
Rep 2,221
Glad I could help brother! So did you have any concerns with paint rubbing/putting PPF? How about the hardware? Did what came with the flaps suffice? Edited to add - I REALLY like the way they look on dark X3Ms, like more than without. Curious to see them installed on a lighter color. |
07-16-2020, 03:29 PM | #14 |
Rep 911
Drives: 2020 X3 M40i
OP.. love the driveway!
• 2020 BMW X3 M40i Graphite : ZDA/ZDB/ZPX/718M/2VF/2T4/3KA/3AC/688/6NW/3AC
07-16-2020, 03:53 PM | #15 |
Rep 2,221
Thanks! I'm super happy with not only the look but the protection from my rock-magnet summer tires. I can't go 10 feet without the tires covered with pebbles as if you dipped an ice cream cone in sprinkles
Thanks! It's now like 15 years old but holding up pretty well. It better, cost an arm and a leg! |
07-18-2020, 10:26 AM | #16 |
Rep 1,328
They really seem to blend in well on the darker vehicles.
It'd be nice to see how they come off on Alpine White.
2020 BMW X3M Competition ///M - ALPINE WHITE / SAKHIR ORANGE Past: 18' BMW M3CS | 18' BMW X5M | '17 BMW M3 Competition | '16 Mercedes GLC250 | '16 BMW X5M | '15 BMW X5 M50d | '14 Audi SQ5 |
07-18-2020, 11:09 AM | #17 |
Rep 1,168
07-18-2020, 11:09 AM | #18 |
Rep 2,956
I put them on my Toronto Red X3M Comp. They stand out obviously compared to dark colored vehicles but they at least look OEM and don't have the gaps of having to modify the OEM regular X3 guards.
I had to used 2-sided tape on the rear ones to get perfect fitment but overall these are good for the money and I don't hear rocks pinging on the sides of the car anymore. |
07-18-2020, 12:13 PM | #19 |
Rep 2,221
07-18-2020, 12:16 PM | #20 | |
Rep 2,221
I did not have any alignment issues with the rear; the screws pulled them tight (or at least I think so). Note, I found it helpful to push them tight into place as I was tightening the screws. I have to say, this was one of the best mods I did to the vehicle - really protects the paint. |
07-18-2020, 12:20 PM | #21 | |
Rep 2,221
elisiX687.00 |
03-18-2021, 08:54 PM | #22 |
Rep 189
I bought these same mudflaps just before winter but did find installing them being way easier when tires are off. I am soon taking my car in for a summer tire change and am planning on having the dealership install them while swapping the tires.
Does anyone happen to have pictures of how these look like on a Donington Gray X3MC? I have been trying to model them but find it a bit hard to see the final result... |
