05-10-2020, 02:33 AM | #1 |
Rep 2,495
G30 Ceramic Control unit install?
I’m pretty sure that this will plug and play but wanted to check to see if anyone has done it or had any experience?
https://www.ebay.co.uk/itm/153555296813
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
05-10-2020, 07:37 AM | #2 | |
Rep 5,115
EDIT: Found it! https://x3.xbimmers.com/forums/showt...&highlight=g30
moff1364.00 |
05-10-2020, 11:36 AM | #4 |
Rep 5,115
Mostly graphics i.e. you can see the seats depicted in the linked unit vs ours that just shows a scale for heat / air etc. Basically a cool factor I suppose
05-10-2020, 01:13 PM | #5 |
Rep 4,703
The passenger side fan can't be controlled separate from the driver as the x3 / x4 doesn't have a separate fan for the driver and passengers. The same fan does both sides.
05-10-2020, 03:29 PM | #7 | |
Rep 2,495
Will see how it goes when it arrives. Thanks for the tips and the link.
2kaccordocoupe1273.50 BMWZ41914.00 |
05-12-2020, 12:51 AM | #8 | ||
Rep 18,794
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
05-12-2020, 04:04 AM | #9 |
Rep 2,495
Looks
I may well still get the ceramic iDrive controller later and then upgrade the knobs on the climate control. Do the passenger vent power buttons still work for the single zone?
r33_RGSport13122.00 |
05-12-2020, 07:45 AM | #10 |
Internet Crash Test Dummy
334
Rep 1,055
Drives: F97 X3MC / F80 M3 / F90 M5
The only thing to be aware is that if you retrofit the ceramic controls (AV/iDrive) it will throw a code when you/the dealer are running ISTA for diagnostics/retrofits etc as it will complain you do not have the option 4U1 (Ceramic controls) installed
Some dealers will be fine with it , others may not be happy to and ask you to re-install the original parts in order to perform diagnostics etc
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107 |
dinan5m34371.00 |
05-12-2020, 08:43 AM | #12 | |
334
Rep 1,055
The feel is a little bit smoother (ie ceramic feel)
05-12-2020, 08:51 AM | #13 | |
Rep 18,794
Passenger side fan button doesn't work. Not a big deal for me since I always on Auto. Just adjusting the temp most of the time. If it gets too hot, I just pressed the Max AC for a few minutes then go back to Auto.
05-12-2020, 09:49 AM | #14 |
Rep 2,221
05-12-2020, 12:06 PM | #15 |
Rep 2,495
Interesting... I’ll keep my fingers crossed that it adjusts for RHD!
05-12-2020, 04:56 PM | #16 |
Rep 18,794
I believe it should detect it based on your VO.
07-16-2022, 08:54 PM | #17 |
Rep 2,115
07-16-2022, 08:55 PM | #18 |
Rep 18,794
OEM for OEM.
dinan5m34371.00 |
07-16-2022, 08:56 PM | #19 |
Rep 2,115
07-16-2022, 08:58 PM | #20 |
Rep 2,115
Same here, non-ceramic one, mainly because the ceramic version had to come from Germany, and they are screwed up over there with supply chain, particularly electronics parts, and didn't want to wait ~months. I'm still waiting for my replacement headrests from Germany, for weeks. Damn you....
07-16-2022, 09:02 PM | #21 | |
Rep 2,115
But then again, don't know if some savvy place would know that f97/f98, g01/g02 never offered this option. Then again (urgh), if mixing S4U1A=yes retrofits with S4U1A=no retrofits in the car coded with S4U1A, then that would also set an alarm in ista scan (???). So, it's all or nothing retrofits wrt such option. Although, now sure how many more of S4U1A=yes retrofits are left or worth doing. hrm... Maybe i should just keep 4U1=no in the car. Last edited by dinan5m3; 07-16-2022 at 09:14 PM.. |
11-16-2022, 01:40 AM | #22 | |
Rep 2,115
gofastbmw5100.00 |
