      04-16-2020, 11:36 AM   #1
spta97
Drives: BMW 2020 X3MC
Bavsound Ghost Subwoofer Rattle
I purchased the full Bavsound speaker set (subs and mids/tweets) and am very happy with the overall improvement.
However, I am having one issue with the Ghost subs (both sides). They are making a rattling noise on certain bass notes.
I am currently working with Bavsound to resolve, but I wanted to see if anyone else had this issue.
The noise is present with the sub outside of the enclosure (i.e.; it's not part of the car rattling), as well as with different sources (I noticed initially when streaming through CarPlay but had the same issue with a compact disc).
Initially they said it was distortion so I turned down the bass and EQ to flat and still hear it.
I'm curious if anyone else has ideas or has experienced this before?
Below is a vid of the sound.
(you can hear it at :10, :17, and :24 seconds)
      04-16-2020, 11:52 AM   #2
BMWZ4
BMWZ4's Avatar
1950
Drives: '23 X1/'23 Allroad Progressiv
Weird, but no I don't know where that rattle is coming from. If I didn't know better I'd say it was from the track itself, but I'm guessing you've tried other similar tracks with the same result?
      04-16-2020, 11:55 AM   #3
spta97
Correct. I've also played the song on my home theater with no rattle.
I've also played other songs which replicate the rattle. It doesn't happen on all but mostly bass heavy songs.
I can eliminate it by completely removing the bass but that defeats the purpose of subs
BMWZ41949.50
      04-16-2020, 12:03 PM   #4
BMWZ4
BMWZ4's Avatar
1950
Stumped. I thought maybe a cracked grille but you mentioned the vibration is in both sides, so that couldn't be the issue. I suppose a hardware defect.
      04-16-2020, 12:35 PM   #5
spta97
I was informed the metal grills are removable so I'm going to take one out this weekend and see if there is anything going on with the grill or inside.
I really hope I can find the root cause (and it is not the design) as they sound great otherwise.
I plan to install a sub and amp in the hatch so the ghosts would be perfect for punchy mid-bass.
      04-16-2020, 01:10 PM   #6
suby01
Cowboy Astronaut Millionaire
suby01's Avatar
Drives: 2020 X3 M40i & 2026 X7 40i
Okay yeah I am not an audiophile Im sure there are many other members that have so much more audio knowledge than me. But thats not a rattle. Thats clearly a defective speaker or sub. Either something with the actual speaker area itself, could be even the magnet. Go ahead and try removing the grills as a test. But you might as well ask for a replacement pair of speakers in the process.
BMWZ41949.50
      04-16-2020, 01:21 PM   #7
spta97
That's what I'm thinking as well. They offered to replace at first but I want to ensure it is an actual problem and not an issue with the speaker design.
What worries me is it is both speakers doing it. I could imagine one defect but both makes me worry it is something with the design (or perhaps a bad lot/batch?).
Bavsound has been good to deal with thus far. I've been emailing with them and sent them updated videos with a different source (CD) and bass flat on EQ and boost where it still made the sound.
Thanks for the input!
      04-16-2020, 01:35 PM   #8
BMWZ4
BMWZ4's Avatar
1950
Agreed probably a defect, even if it's the pair. I also don't believe it's a design flaw since others would've likely reported something by now. Keep us posted.
      04-16-2020, 02:15 PM   #9
spta97
Fingers crossed and will do
BMWZ41949.50
      04-16-2020, 02:48 PM   #10
Alias1431
Alias1431's Avatar
Drives: 2019 BMW X3 M40i
You torque those screws down enough?
Also, download a frequency generator app for your phone and play through car bluetooth. Way, way easier to locate and diagnose rattles.
      04-16-2020, 03:28 PM   #11
spta97
Also, download a frequency generator app for you phone and play through car bluetooth. Way, way easier to locate and diagnose rattles.
GREAT idea on the frequency generator!
Screws are torqued down tight but I also removed the speaker from the enclosure to eliminate the car from the equation (I could hear it while holding the speaker in my hand).
      04-16-2020, 08:48 PM   #12
suby01
suby01's Avatar
Youve blown your speakers. I dont know if the BS speakers have a break in period as most aftermarket subwoofers do. Or they were just defective from the factory. Anyway if youre hearing the same thing with them outside the enclosure they are fried, which sums up my first initial post that was hard to decipher from a online recording.
      04-16-2020, 09:08 PM   #13
Oldguysrule
Oldguysrule's Avatar
351
Drives: 2018 X3 M40i
2018 X3 M40i  [10.00]
Sounds like the voice coil on the speaker cone is rubbing on the core. Most likely over driven if its present on both speakers. Inspect the cones for possible tears. If you have a digital multi meter measure impedance between + and ground. You should get 4, 6 or 8 ohms. If you don't get anything, speaker is shot. Does it do it with just one source or multiple sources??
AlexFL8159.00
      04-16-2020, 09:47 PM   #14
sinbad4
How are you playing your track? From Phone over Bluetooth? Aux in? USB?
• 2020 BMW X3 M40i Graphite : ZDA/ZDB/ZPX/718M/2VF/2T4/3KA/3AC/688/6NW/3AC
      04-16-2020, 11:09 PM   #15
Alias1431
Alias1431's Avatar
Also, this goes for anyone, make sure your EQ is flat when you start playing music after installing the new ones. Not only for break in, but because they're a lot easier to drive than the stock ones.
      04-17-2020, 07:32 AM   #16
Tchgrif
Drives: X4 M40i
I also play a lot of bass heavy music in my x4 with complete bav sound upgrade save the amp, which still isn't available, and I do not have this issue. I would say to check how you bolted them down as you have to install them with bolts and nuts once you hammer out the old ones but i guess you have that even with them out of their enclosures. maybe when they are out hook them up and see if you can see if something extra is fluttering around? otherwise I would say you got a manufacturing defect probably where the magnets attach to the cones or the magnets themselves are not moving properly.
      04-17-2020, 08:01 AM   #17
spta97
I heard this from the initial install where I just turned on the volume low to hear if they worked. They could be blown, but I don't think I blew them.
Great advice - I will measure this weekend (they are 8 ohm speakers) while I am taking the metal grills off (I did not realize they were removable) to inspect for damage.
This was through bluetooth and a CD in the dash so I eliminated the source as the issue.
Good advice.
They are secure but I will be checking the voice coil/surround/magnet this weekend.
I'm still within the 100 days and Bavsound recommended sending me a new set of woofers but I still want to troubleshoot to find the root cause.
I like the way the entire system sounds outside of this rattle. Hopefully the new pair will resolve it.
BMWZ41949.50
Alias1431857.00
Tchgrif285.50
      04-27-2020, 11:06 AM   #18
spta97
Update...
I received the replacement Ghost Subs and did some testing this weekend. Keep in mind I have my ear right near the sub so these sounds may not be heard if sitting in the seat. I am also very sensitive to sound.
Troubleshooting: - Bass was set to flat on EQ and minus 2 clicks on the boost
1) Removed the metal grill from the rattling ghost subs and subs from the enclosure - the rattle persisted.
2) Tested the resistance of both the Ghost Subs in the vehicle as well as the new ones received - both measured 6.8 ohms (interesting as I thought they were 8 ohms but I guess they lowered the resistance to get louder sound like the Bimmertech subs).
3) Installed new subs - rattle persisted.
4) Tried a frequency generator - It seems the issue happens around 100-150 Hz . The bass gets sloppy and I get the rattling under the threshold (note: I have to get exact frequency as I was having CarPlay connectivity issues and a ran out of time).
5) Installed the factory sub and got a similar rattle/woofer muddiness on the same songs.
Findings:
1) I have come to the conclusion that the Ghost Subs (and factory) are just incapable of reproducing low bass frequencies below ~150hz (again, exact frequency TBD). They try but the sound falls apart.
2) As a result the bass becomes muddy/rattles the subs.
Proposed Solution:
1) I do like the mid bass punch of the Ghost Subs, so I was thinking of getting "Bass Blockers" to filter out the low frequencies from the Ghost subs.
2) I intend to install a dedicated JL Audio 500/1 amp and HO 10" ported sub box which will fill in the filtered frequencies.
Other Options:
1) I wonder if I would have better luck with another OEM replacement sub? I am limited to 7-8 ohms so I think the only other is Bimmertech AlphaOne.
For reference, I have an X3MC with the HK system.
Opinions appreciated
      04-27-2020, 11:18 AM   #19
Wgosma
Drives: 2019 G01 X3 30i (B48)
I think you might do well to install the add'l amp and large subwoofer speaker and then consider the under seat speaker situation.
That larger speaker is going to cleanly pull in the lows-
      04-27-2020, 12:15 PM   #20
spta97
Agreed. However, I typically like my subs to have a low crossover (like 40 hz). I'm willing to go up to 100-150hz but any higher than that I'm concerned it will not perform the way I want.
I'm also somewhat committed as I've already pryed the factory subs out of the enclosures and if I put them back in I'll have to silicone them which would be a PITA to remove.
      04-27-2020, 12:28 PM   #21
Wgosma
Agreed in the low crossover freq; maybe push it to 125 Hz.
Darn bad luck in the under seat units, hmm...
      04-27-2020, 01:11 PM   #22
suby01
suby01's Avatar
So they new replacement speakers no longer rattle then correct? Meaning the first ones were defective?
