XBimmers | BMW X3 Forum BMW X3/X4 Forums BMW X3M (F97) and X4M (F98) General Forum (2018+) X4M Competition vs Alfa Stelvio QV Drag Race
      03-04-2020, 03:57 AM   #1
aadam.f97
aadam.f97's Avatar
South Africa
27
Drives: X3M Comp F97, X5 G05 30d
BIMMERPOST
     Featured on BIMMERPOST.com
No surprises here, drag race in Western Cape, South Africa.
https://www.cars.co.za/motoring_news...ifoglio/48362/
Last edited by aadam.f97; 03-04-2020 at 05:17 AM.. Reason: NEEDED TO ADD YOUTUBE VID
      03-04-2020, 07:19 AM   #2
kzg1969
kzg1969's Avatar
Scotland
676
Drives: X3M Comp / Focus RS
wasnt expecting that result!
      03-04-2020, 09:09 AM   #3
heavyD^2
heavyD^2's Avatar
Drives: X3M Competition
Stelvio had a much better launch. Not sure if that's due to it having better launch control (both vehicles are use ZF8 transmissions) or driver skill but it's clear the S58 is packing more heat pulling it in like that.
      03-04-2020, 09:21 AM   #4
BMWZ4
BMWZ4's Avatar
Drives: 2018 X1 & 2020 X3MC
Or weight?
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1; Loaded '20 X3MC Donnington, Black/Tan Merino
JustChris12098.50
      03-04-2020, 10:26 AM   #5
strohw
Drives: 2020 X3M
The Stelvio quad weights around 150lbs to 200lbs less but it doesn't have launch control. You just brake torque it. It also has a better hp/tq curve between 2k and 3k rpm than the BMW in that it's more linear. It doesn't have that 50hp/tq hole that the X3M does. I also believe the X3M is underrated a bit more and has 20-30 more hp on the top end than the quads do.
      03-04-2020, 11:04 AM   #6
AlexFL
Drives: BMW X3MC, Audi RS7 (pre-ord.)
That torque hole you mentioned plays no role when you use LC. I think itís mostly Stelvioís lower weight and also X3ís launch was far from perfect. Iím actually not sure if he used the LC at all or simply brake torqued it. X3M has the best high end hp curve in itís class and thatís why I love it so much. Absolute beast at high rpms.
Wills26699.00
BMWZ41102.00
JTO242956.50
      03-04-2020, 11:19 AM   #7
strohw
Drives: 2020 X3M
Originally Posted by AlexFL View Post
That torque hole you mentioned plays no role when you use LC. I think it’s mostly Stelvio’s lower weight and also X3’s launch was far from perfect. I’m actually not sure if he used the LC at all or simply brake torqued it. X3M has the best high end hp curve in it’s class and that’s why I love it so much. Absolute beast at high rpms.
I know because LC puts you right up near the 3K point where the HP/TQ comes in along with allowing you to build that all that boost. But you can tell they didn't use launch control in this video. He barely brake torqued it before they set off. In this kind of instance the Alfa is better as it hits it's 0-60 numbers with just plain brake torquing. The X3M needs it's LC to hit 0-60 numbers near the Alfa. It's a bit slower if you can't use it. I do agree the M off the line as a bit delayed though.
      03-04-2020, 11:23 AM   #8
Transfer
Transfer's Avatar
Drives: M340i, X3M Comp
I don't think the X4M driver held LC long enough. Launch looked poor. Surprising that it reeled in the Alfa.
BOGX4M41.50
BMWZ41102.00
///M TOWN3909.50
M-Pilot4643.00
      03-04-2020, 11:37 AM   #9
AlexFL
Most of these drag-racing automotive journalists are simply too lazy to grab the manual and read the launch control instructions. It literally takes 30 seconds. Here is an (admittedly extreme) example:
      03-04-2020, 12:32 PM   #10
Carmicro
Carmicro's Avatar
158
Drives: T
Same gearbox but different sw. I think the sw on the Alfa give more aggressive change. I had drive of the Alfa the box seems slightly quicker and more aggressive.
      03-06-2020, 04:25 AM   #11
Wills2
Barge driver
Wills2's Avatar
Drives: X3M
Very impressive from the X4M, reeling in the Alfa after going 2-3 car lengths down at the start of the 1/4 mile is some going.
X3M/Z4C, Gone G11 740d xdrive/F80 M3/F10 M5/F31 335d/e92 M3 x 2/F10 520d x 2/997 C2S/e46 M3/e46 320d/SL320/Touareg 3.2V6/Audi allroad 2.7TDi
RustyBitz1231.50
      03-06-2020, 03:42 PM   #12
///M TOWN
///M TOWN's Avatar
3910
Drives: M GmbH
Good Lord.
Vin Diesel clearly left the scene..
Remove stability on that BMW and let us see that again.
JustChris12098.50
      03-06-2020, 04:48 PM   #13
M4 GTS
Drives: 2002 E46M3 2019 X3 M40
How about 409.2 less.186kg x 2.2 = 409.2lbs
      03-06-2020, 04:53 PM   #14
vincechase
vincechase's Avatar
Drives: G20 330 M Sport
That x4 M comp launch was type trash firstly.
The x4 M comp is def faster then that
11.6 seconds
The 2020 BMW X4 M and X3 M Competition both achieved a 3.3-second zero-to-60-mph time in Car and Driver testing. The pair of M SUVs also raced to the quarter-mile in 11.6 seconds at 119 mph. The Competition package adds an extra 30 horsepower to their twin-turbocharged 3.0-liter inline-sixes. I know this is with a race car driver but even with that being said
      03-06-2020, 06:17 PM   #15
rjd598
Drives: F30 340i
2016 BMW 340i  [0.00]
175kg=385.81lbs
      03-06-2020, 06:40 PM   #16
M-Pilot
M-Pilot's Avatar
Drives: 981 Cayman GTS
Alfa site states that Stevio Q weighs 4360 lbs while BMW USA says X4M Comp weighs 4590lbs. So the difference is 230lbs. Not sure where the figures in the video are from.
      03-06-2020, 07:17 PM   #17
Mako
(Sold) 2000 M Roadster, 2006 M Coupe, 2016 M3
Drives: '20 X3MC DG/SO '19 Volvo XC90
yeah weight is much closer than video implies, look at C&D tested weights on them. I don't think X4M used LC at all, thats how my X3M takes off from a stop light, but in magazine testing when they used LC properly the 1/4 miles is under 12 seconds every time.
POM335.00
      03-06-2020, 07:28 PM   #18
Thewolfbmw
Thewolfbmw's Avatar
Drives: X5 50i M Sport
They used LC, you can see it in the video. Proper amount of time to build boost is debatable. What was the elevation? Temps where in the high 70's.
      03-06-2020, 08:17 PM   #19
Jason60051
Jason60051's Avatar
Drives: 2018 BMW M3 ZCP Acura MDX
Love the noice the Stelvio makes. Wish bmw could tune their exhausts like this from the factory.
2018 M3 ZCP; 2020 Acura MDX Sport Hybrid Advance
      03-06-2020, 08:22 PM   #20
AlexFL
I think they just brake boosted, no LC.
      03-06-2020, 08:28 PM   #21
doug_999
doug_999's Avatar
1929
Drives: 2018 M3/2011 1M
Agreed, Alfa won this race based on exhaust note alone
2018 M3, Mineral White, 6 speed, ZCP, loaded sans CCB
2011 1M, Black loaded sans sat radio
Fuji550i101.50
      03-06-2020, 09:32 PM   #22
AlexFL
Disagreed, Bimmer won this race because it actually did.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
