03-04-2020, 06:23 PM | #23 |
Rep 4,703
03-04-2020, 08:12 PM | #24 |
Rep 1,044
Do you have the latest PsdzData?
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29 MY19 X3 M40i: Produced: 2018-08-15; Delivered 2018-08-22 |
03-04-2020, 08:17 PM | #25 |
Rep 4,703
03-04-2020, 11:01 PM | #26 | |
Rep 245
If they have coded it out for certain regions, there has to be a legitimate reason. I would think stringent regulations are not being met, or something related to potential litigation issues. If you get in an accident as a direct result of you enabling a feature that was not intended to be enabled for your region, is BMW at fault? Even though your BMW just steered itself into another vehicle?? I don't think so... |
03-05-2020, 06:04 AM | #27 |
Rep 1,044
I used 4.22.14.
MY18 X3 30i:
03-05-2020, 06:09 AM | #28 | ||
Rep 1,044
If the hardware is there and functional, coding it on or off (like disclaimer nags) isn't dangerous. FDL coding is like changing registry entries in a Windows PC. It's not the same as VO coding, which attempts to tell the car it has something it may not. Face it: today's cars are platforms with wheels to keep the computer from scraping the ground. People are going to experiment with them as a hobby.
MY18 X3 30i:
03-05-2020, 06:36 AM | #29 |
Rep 4,703
Thanks. I'll try that version today.
03-05-2020, 03:41 PM | #30 | ||
Rep 245
03-05-2020, 05:19 PM | #31 | |||
Rep 1,044
People will turn it on and use it using the same logic that makes people ride on 21" summer tires in Boston winter weather. Do you think that the warning the wheel seller give the buyer telling him he's insane makes any difference? I am pleased it (appears to be) hard to code. That's not going to stop a substantial number of Massholes from doing it and crashing. But it doesn't mean BMW had a safety reason to code it off especially when it's the same hardware and software functionality (presumably) worldwide.
MY18 X3 30i:
03-08-2020, 03:09 PM | #32 | |
Rep 56
03-08-2020, 10:57 PM | #33 |
Rep 271
Perhaps someone can help. I see the following settings for SAS2 on a U.S. 2020 G01 X3 M40i and what they are currently set by default from factory:
- Under 3000 SAS_10, FC C_AHM_vorhanden: false C_aPDC_vorhanden: true C_HDC_vorhanden: true C_Segeln_vorhanden: enable C_LCA_vorhanden: true C_EDP_vorhanden: false C_EDP_Land_aktiv: 0xFBDC0000: FB,DC,00,00 C_STA_ALC_Vorhanden: true C_Segeltempomat_vorhanden: true C_ISA_vorhanden: false C_AWA_vorhanden: true C_LCA_rSKW_Vorhanden: true C_LCA_SKW_Vorhanden: true C_LCA_SVW_Vorhanden: true C_LCA_SWW_Vorhanden: true - Under 3001 Umfeldmodel, FC C_VZA_Funktion_Land_aktiv: UNK_PARAM_1: FB,DF,83,C0 C_vSLI_Land_aktiv: UNK_PARAM_1: FB,DF,83,C0 I'm also getting Kommentar=Trimmed Function on all of the HU-MGU Funktionen. This is with psdzdata 4.22.14 with e-sys 3.28.1 with Launcher Pro 2.8.2 Last edited by AcidLotus; 03-11-2020 at 04:58 PM.. |
03-13-2020, 12:38 AM | #34 | |
Rep 56
03-25-2020, 08:56 AM | #35 |
Rep 911
Drives: 2020 X3 M40i
Anyone get this working in 2020 X3 w/ iDrive 7 yet?
• 2020 BMW X3 M40i Graphite : ZDA/ZDB/ZPX/718M/2VF/2T4/3KA/3AC/688/6NW/3AC
03-26-2020, 04:58 PM | #36 |
Rep 247
FYI, after the coding is done make sure you are on a road which has a median / barrier between oncoming traffic.
This is a requirement of the system, it wont work on roads that dont have a barrier between the traffic. although i have a 2019 with ID 6 |
03-27-2020, 10:03 AM | #37 |
Rep 247
05-07-2020, 08:48 AM | #38 | |
Rep 41
Coded this today but no luck. I'm in Australia. Anyone got it working here? My car is 2019 G01 X3 with 5AT- Driver Assistance Plus. I-Step S15A-20-03-540. No reason this isn't working in Australia. Confused now... |
05-31-2020, 07:25 AM | #39 |
Rep 80
Can confirm it works on my G08 2020 X3(CN version of G01). And it's also possible to change the default above 70km/h triggering speed. It's also in the SAS module. Thanks for sharing!
06-02-2020, 07:05 PM | #40 |
Rep 247
06-03-2020, 04:30 AM | #41 | |
Deadly
1315
Rep 2,073
Tell me to mind my own if you like :-> |
06-06-2020, 02:22 AM | #42 |
Rep 80
10-22-2020, 06:55 PM | #44 | |
Rep 126
Drives: 2021 X3 M40i
I'm pretty new in this area so any help is appreciated, Thank you !! |
