01-04-2020, 08:24 AM | #1 |
Rep 1,137
G30 Touch Climate Control Panel installed on G01
Getting a bit ahead of myself, I have already started ordering parts for my 2020 530e which is being delivered in February, and one of the parts I had ordered to retrofit was the Touch Panel Climate Controls which come with the 4-Zone climate control, which is pretty much only available on the M5 in the U.S.
When it arrived, I thought the panels and outer trim looked very similar to what was in my M40i now, so after verifying the wiring diagrams were the same, I decided to see if it would work in the X3, and sure enough, it hooked right up with no problems! No coding needed, no error codes. The trim plate is in fact identical so it was just a straight plug-n-play swap. The only odd-looking thing about it being in the X3 is that since the 5-Series has separate fan speeds for the driver and passenger, it still shows that on the display. However, the Passenger Side fan speed and Auto button don't do anything if you press them, other than turn Sync off. Otherwise, everything else functions perfectly. Great swap for anyone who likes the more digital look, or if you plan on retrofitting the Ambient Air/Ionizer options. The climate panels can be found online on auction sites/salvage yards for around $250 USD. Instructions for removing and installing the radio/AC control panel can be found here. |
01-04-2020, 08:43 AM | #2 |
Rep 911
Drives: 2020 X3 M40i
Nice! Good to know.
And.. Hey! BMW did kill the CD player in 2020. I had a 2019,and now 2020, I thought I had a CD player before (there is not one in the 2020). Almost thought I must have misremembered. Not the I miss it - I haven’t played a CD in a car for at least 15 years.
• 2020 BMW X3 M40i Graphite : ZDA/ZDB/ZPX/718M/2VF/2T4/3KA/3AC/688/6NW/3AC
01-04-2020, 09:03 AM | #3 | |
Rep 1,137
01-04-2020, 10:15 PM | #4 | |
Rep 2,060
And is that retrofit of non-USA offered option of ambient air/ionizer into USA model, possible? Thanks. |
01-05-2020, 11:30 AM | #5 | |
Rep 1,137
As for your other question, yes, it is possible to retrofit the ambient air, however it does require you to be comfortable taking apart your car, as you have to remove the dashboard to install parts, which means you also have to remove the steering wheel, center console, and quite a bit more. On the X3, you would also have to replace the glove box, which in my months of looking I was not able to find used, and a new one from Germany costs around $360.00. I have most of the parts to retrofit it in my 530e when I get it as the G30 doesn’t require the glove box replacement, and I’ve just been slowly accumulating the parts as I find good deals online as the ionizer module and air freshener module are pricey if bought new. |
01-05-2020, 11:33 AM | #6 | |
Rep 5,103
01-05-2020, 12:44 PM | #7 |
Rep 120
Drives: MY20 X4 M40i
01-05-2020, 01:29 PM | #8 |
Rep 911
Maybe a Canadian thang. ;-)
01-05-2020, 01:30 PM | #9 |
Rep 5,103
A bit odd, seeing as these dash consoles are identical. Maybe overstock on CD players so they're sticking them in the M vehicles lol
Mpetey75.00 |
01-05-2020, 04:06 PM | #11 |
Rep 5,103
Yeah, maybe. Canadians are generally slow at adopting new tech lol i.e. stream via Bluetooth or Spotify
01-05-2020, 04:13 PM | #12 |
Rep 2,073
I didn't even think to check if my car had a CD drive....I just checked, it hasn't. I have almost 1,000 albums across 2 usb sticks plugged in permanently. Really CDs....
01-05-2020, 04:42 PM | #13 |
Rep 211
Getting slightly off topic but, the CD/DVD player in my 2019 does come in handy when watching DVD's whilst waiting for the wife when she's shopping, I always keep couple in the car :-)
07-20-2020, 03:14 AM | #14 |
Rep 20
Is the G11 Touch Climate Control Unit how can fit the X3 ?
Anyone experienced that ? Like here ? https://x3.xbimmers.com/forums/showp...3&postcount=22 P.S: G30 and X3 are same completely, but G11 unit has different external connectors (wiring and sockets are same) So can i move the g11 climate control block to inside the my g30's climate control cover so it may compatible then. |
07-20-2020, 10:19 AM | #15 | |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3509
Rep 4,206
11-05-2020, 11:04 AM | #16 | |
Rep 202
Drives: 2023 BMW 760xi, 2024 BMW 530i
11-05-2020, 11:45 AM | #17 |
Cowboy Astronaut Millionaire
2313
Rep 2,885
I would be so doing this if the black buttons were silver like in the 2020+ models.
11-05-2020, 02:13 PM | #18 | ||
3509
Rep 4,206
11-06-2020, 04:17 PM | #20 |
Rep 648
Please look here —> https://www.ebay.de/itm/114475668094
11-06-2020, 04:58 PM | #22 | |
Rep 339
