12-17-2019, 07:52 PM | #1 |
Rep 15
2017 F25 Brake Rotors/Pads recommendations?
Short story:
Looking for recommendations on a good brand of rotors and pads for the F25. I'm not too familiar with brake brands, but my limited research so far suggests that EBC, Zimmerman, Stoptech and Brembo are all good rotor makers (though Brembo doesn't seem to make front rotors for some reason). As for pads, I've seen Akebono, EBC and Brembo recommended. I'm in Toronto, so Canadian-friendly recommendations on where to source these parts would be extra helpful. Also would welcome recommendations for a mechanic to do the work since it's winter and I don't have a covered garage. Long story: My 2017 F25 X3 xDrive28i has started giving me the "service due soon" message for the front brake pads and now says they should be replaced in 90 km. What's weird is that the iDrive says the rear pads have another 50,000 km in them. A quick visual inspection suggests that the pads on all four wheels are at least 8-10 mm thick. Seems as though that should be good for much more than 90 km. Nor does it account for the huge discrepancy in service life remaining between front and rear. This car came to me used with about 65,000 km on it, so I don't know if the brakes are original, or if they've been replaced and maybe someone didn't replace/reset the sensors. Regardless, I've been a little underwhelmed at the braking performance in this car and wouldn't mind replacing the rotors/pads on all four wheels. The OCD in me is also annoyed at rustiness of some of the rotors. Would love to hear your recommendations. Thanks! Edited to add photos of the front pads and rear driver's side pad for comparison Last edited by softsign; 12-17-2019 at 08:11 PM.. Reason: Added photos for reference |
12-17-2019, 10:16 PM | #2 |
Father of Frankenfold
297
Rep 532
Drives: Yo daddy's 2014 X3 M Sport
I like the EBC pad and rotor kits. Cheap and effective. The inside pads typically wear a little quicker on sliding piston calipers, so the outer pads may show more thickness.
softsign9.50 |
12-17-2019, 11:07 PM | #3 |
Rep 383
Akebono pads and Zimmerman coated rotors all around. Nearly no dust and braking power plenty for daily driving.
softsign9.50 slowblackx3f25101.00 |
12-18-2019, 07:25 AM | #4 |
Rep 45
I use Akebono Euro pads and Zimmerman coated rotors all around. Used the same on the 535 xi I used to have. I've had good luck with them over the years.
Doug
2019 BMW 430 XI Grand Coupe, White, Black leather interior 2016 BMW X3, 28d, Mineral White metalic, Oyster Nevada leather interior. |
softsign9.50 |
12-18-2019, 09:27 AM | #6 |
Rep 2,928
Just FYI, the service indicator means nothing. It is not monitoring pad wear in any way. It's just a guess. Kinda like of you had a kid, and somebody told you "22 years until college graduation." Then your kid takes an odd life path and graduates at 40. And if somebody did not reset the counter when the pads were last changed, then the system goes from useless to super-useless. Those are nearly new pads.
softsign9.50 |
12-19-2019, 03:16 PM | #8 |
Rep 15
Seems like the Akebonos are very popular and I'm inclined to go that way too. That said, most of the reviews I've read can be summarized as "equivalent stopping power to OEM brakes, way less dust". Would that be about right?
If I don't mind the dust and wanted a little more stopping power, or at least a little more bite, what's my best alternative? |
12-20-2019, 09:30 AM | #9 | |
Rep 2,928
softsign9.50 |
12-20-2019, 09:37 AM | #10 |
Rep 355
As for rotors, just look for a name brand coated rotors. My preference is the ATE (likely the OEM) coated, but Zimmerman, Bosch, Brembo, and others mentioned here are all fine. Just be sure they're coated.
I've tried a number of other pads over the years for various BMWs but always end up coming back OE compound pads. You always seem to lose some of that cold bite that BMW is known for. I deal with the dust by waxing the wheels to make it easier to clean. I will also never own a BBS cross spoke style wheel again. I also own separate summer and winter wheel sets so they get thoroughly cleaned once a year. On my 2012, I know Jurid is the OEM for the rears. I think ATE is the OEM for the fronts. |
12-23-2019, 06:06 AM | #11 |
Rep 2,529
Just did the following:
Akebono pads Zimmerman rotors 5.1 brake fluid OEM rotors started to crumble after 7 years/65k KM. They were turning my wheels another shade with a nasty brown fine powder I last changed the pads 3 years ago / 20k KM ago. Rear pads died quickly before and were the same case now. Front pads and rotors seemed to have a lot of life left but very rusty. |
softsign9.50 |
12-24-2019, 09:24 AM | #12 | |
Rep 15
11-03-2021, 03:19 AM | #15 |
Rep 29
Hi anyone try textar rotor before ? I though of replacing it with the original which worn pretty fast. Front pad on bendix Eu pad, much cleaner but friction slightly lower than ori pad.
11-03-2021, 07:38 AM | #16 |
Rep 84
I used Zimmerman on my M5 and that's what I will use on this vehicle- don't know the price point between your brand and Zimmerman tho - I use Michael at Newparts for my parts
11-05-2021, 11:04 AM | #17 | |
Rep 619
With this knowledge, i ran to buy the complete kit for my X3 and .... well. I am regretting it. Not sure why but my brake pedal feels spongy and I get this vibration when the brakes heat up at high speed. Used TIS and followed BMW recommended way of doing this job. I'm this close to dropping the car off at the dealer and having them redo the entire job again using OE parts. |
11-27-2021, 10:06 AM | #18 | ||
Rep 29
01-04-2022, 08:47 AM | #19 | |||
Rep 29
01-05-2022, 07:26 PM | #20 | |
Rep 176
