Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions Your BMW Might Have A Hidden TESLA Mode?
      11-16-2019, 09:51 AM   #1
Marcelo_BSB
Drives: 328
Did you see this? Step by step to enable.
      11-16-2019, 02:21 PM   #2
azwillnj
Drives: 2023 M340i xDrive
This is really awesome. I want more codings! I am going to try this soon and will report back. I currently have the driving view but don't have lane change activated..
I am still a little worried about whats going to happen when BMW pulls their head out of their ass and starts offering the OTA updates. Will custom coding break that? At the very least we will likely need to redo custom coding.
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive
WE ARE!
      11-18-2019, 05:11 AM   #3
BigWagonFan
Drives: G21 330i xDrive
If I get it right, updating software version works more like programming. It replaces program binary code.
It should not affect coding & settings which I believe are stored separately.
      11-18-2019, 06:41 AM   #4
phillyd2
Drives: 2020 M340i XDrive
Anyone know what he means by Pre and After July production?
      11-18-2019, 05:21 PM   #5
TTG
TTG's Avatar
Drives: M340
There were some software and hardware changes starting July production. Don't ask me what they are as I have no idea.
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
      11-18-2019, 07:08 PM   #6
phillyd2
Ok. Can I ask how we know there were changes?
      11-19-2019, 09:02 AM   #7
AtticusHoy
Drives: 2020 M340i
Cars that were produced during and after July 2019 came with the active driving assistant view functionality enabled (if they had the proper package).
Cars produced before July did not have the active driving assistant view feature and, even after upgrading to the same (or greater) software version, it still is not enabled. It may be a bug or it may be intentional that it's not enabled for pre-July builds, but either way this coding exercise will enable it (again, assuming you have the correct driving assistance package). I have not seen any evidence that post-July builds have hardware changes.
phillyd2219.00
      11-19-2019, 11:00 AM   #8
ferbmw
Drives: BMW 330i G20 2019 Sportline
What package the car should have to enable this feature? I have a G20 produced 11-18 with parking assistant, reverse assistant, pedestrian detection, active cruise control. Is this the basic configuration to enable the changes shown here? Thanks
      11-19-2019, 04:04 PM   #9
phillyd2
Thanks for this. My main concern was hardware as I’m a pre July build but do have the package.
cak630.00
      11-19-2019, 04:16 PM   #10
AtticusHoy
Drives: 2020 M340i
I'm trying to decide which route I want to go for this: Launcher Pro or ESysX. Plus, hopefully we'll find plenty more goodies to take advantage of all that latent hardware.
      11-23-2019, 12:02 PM   #11
Marcelo_BSB
Drives: 328
I got up the courage and decided to do it on my BMW 330I M Sport, manufactured on May 2019. I used Laucher Pro 3 and E-SYS. It worked perfectly as in the video. No mistake, just follow the video.
      11-23-2019, 12:42 PM   #12
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
@Marcelo_BSB,
Wow, this is quite impressive-- not just this hidden capability, but how you discovered & documented it!! WELL DONE!!
Since I get confused by the different names for packages, I went my car's VIR. My car is a 2020 M340 Xdrive with a manufacture date of 6/26/19. The software was upgraded to 07/2019.70 recently when I took it in for rear camera recall. The car has Heads Up Display & I do see what you call "before" on both HUD & instrument panel. Here are related options:
• ZDA Driving Assist Package
-- 5AU Active Driving Assist Pro
-- ZN1 Active Blindspot
-- ZN4 Lane De8
• ZDY Driving Assistance Pro Package
-- 5AR Extended Traffic Jam Assist
Though I am new to G20 coding, I did a lot on my previous F30
My question is quite simply is whether this capability you found will work on my car
Thanks
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
      11-27-2019, 10:08 AM   #13
azwillnj
I can confirm that this works. I had the active driving assistant before so I didn't need to enable that but I did enable the lane change assistant. For anyone else looking to do it, here are the relevant codings to enable the lane change assistant, these are copied directly from the video:
BDC_Body3 > CAFD_7083 > SPURWECHSEL_ASSISTENT
Default: nicht_activ
Change to: activ
HU_MGU > CAFD_3E52 > SPURWECHSELASSISTENT
Change to: gen_1
SAS2 > CAFD_42C1 > C_SWA_VORHANDEN
Default: Nr000_nicht_vorhanden
Change to: NR001_VORHANDEN
Here is a picture of it working, it does a cool little animation that shows the lane expanding and then the 'locked car' brackets move over to the car in the destination lane. I took the picture right before the brackets moved over, the HUD also shows a little green arrow in the direction of the lane change.. its awesome! Thanks for posting this OP.
WE ARE!
      11-27-2019, 01:38 PM   #14
siegester
siegester's Avatar
345
Drives: '20 M340i
2020 BMW M340i  [0.00]
thank you for this!!
      11-27-2019, 02:40 PM   #15
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3459
Drives: 2020 M340i
Does auto lane change work on US Spec cars?
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com
Top M Client Advisor in New England.
      11-28-2019, 02:21 PM   #16
azwillnj
Yes, I have a US spec car and it works perfectly. It is pretty awesome too, it will 'lock' the car in the destination lane as you are switching lanes and begin reacting to that cars speed. It also works much faster than the Tesla version I tried on a test drive.
If you are in distance mode only and assisted driving is NOT enabled the lane change feature will still 'lock' the car in the destination lane as you are manually changing lanes and begin reacting to the new car's speed much faster. I have no clue why this was disabled, it makes the system feel much more polished.
WE ARE!
      11-28-2019, 09:54 PM   #17
siegester
siegester's Avatar
345
Drives: '20 M340i
Works on US cars fine. You don't have to hold the indicator stalk, just tap it and it does everything for you
      12-01-2019, 02:41 PM   #18
JayPichardo
BMW Client Advisor
3459
Drives: 2020 M340i
I need to code this on mine.
      12-02-2019, 03:39 PM   #19
JayPichardo
BMW Client Advisor
3459
Drives: 2020 M340i
Where can I download the necessary software?
      12-03-2019, 09:27 AM   #20
azwillnj
Here are the basic instructions: https://www.bimmerfest.com/forums/sh...d.php?t=983244
Contact TokenMaster for the most up to date download and access to LauncherPro: https://www.**************.com/
Edit: Seems like that link was censored, visit the first link and jump through there, look for "Launcher Pro 3.x"
WE ARE!
      12-05-2019, 07:19 PM   #21
jaimeen77
jaimeen77's Avatar
68
Drives: BMW 330i
my 330i doesnt work lane change assistant... anyone success LCA with 330i?
I coded it below and hu-mgu indicate the LCA enabled, but lane assist is not working...
Change to: activ
Change to: gen_1
      12-05-2019, 08:03 PM   #22
haruny
Drives: 2020 BMW M340i
2021 BMW X5 45e  [0.00]
Can this be done with bimmercode's expert mode?
2020 M340i RWD | C3Z | MAPQ | ZDA | ZDY | ZPK | ZPP | 1CR | 1PU | 688 | 6NW | 2VF | 316 | 4UR
Visit my Instagram
g20
