XBimmers | BMW X3 Forum BMW X3/X4 Forums BMW X3M (F97) and X4M (F98) General Forum (2018+) X3M X Drive Test
      10-31-2019, 08:59 PM   #1
onfireX5
Drives: F90M5,F85X5M
X3M X Drive Test
BIMMERPOST
     Featured on BIMMERPOST.com
Appreciate 8
      10-31-2019, 09:06 PM   #2
chassis
chassis's Avatar
Drives: BMW G01 X3, M-B GLE350W4
Very interesting. What are the center differential technical details for xDrive?
      10-31-2019, 09:17 PM   #3
onfireX5
Same diff as the M5. My truck would fail that test with rollers on both rear and one front.
clee1982668.00
      11-01-2019, 12:28 AM   #4
r33_RGSport
r33_RGSport's Avatar
Drives: 997.1 C4S / F39 X2 / F97 X3MC
So lift kit would be great then.
Email: sales@rgsport.com === IG: RGSport_USA
onfireX52808.50
      11-05-2019, 03:05 PM   #5
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
One of the most interesting tests. I was impressed with one particular test when 3 wheels were on rollers. The remaining wheel still managed to provide enough traction. Thanks for sharing.
      11-05-2019, 03:15 PM   #6
///M TOWN
///M TOWN's Avatar
2945
Drives: ///M
I'd like to see a comparison between ///M xDrive and standard xDrive.
Looks like they perform very much the same.
Thank you for posting.
      11-05-2019, 03:40 PM   #7
Barbera335
Drives: F25
Why would it fail? All you have to do is apply the brake with enough pressure to transfer power through your open front diff to the wheel with traction. This is basic off roading. And if your truck is relatively new the computer will brake individual wheels for you.
clee1982668.00
      11-05-2019, 03:54 PM   #8
bjcarls
Drives: Trackhawk & 340xi
On the three wheel - to me it looks like it moves forward because it starts to grip the side of the roller base. Idk...or really care.
X7 did it much faster and smoother which just confuses me. I’d need to know the software and mechanical differences.
clee1982668.00
      11-05-2019, 04:23 PM   #9
MrFargo13
MrFargo13's Avatar
Drives: 2014 X3 35i M-Sport/2011 328i
I don't understand the point of this. I attended a driving event in 2011 where they did this same demo with the 2012 X3. And it actually came off the rollers in seconds, not minutes.
MrFargo13
Mine: 2014 X3 35i M-Sport VR on Black w/wave wood trim, Tech, DHP, DAP w/RR Top View Cam, Premium Sound, Prem Pkg, Cold Weather.
The Wife's: 2011 328i Deep Sea Blue Metallic Navigation Premium Pkg Sports Pkg Xenon Heated Seats Folddown Rear Seats BMW Apps
///M TOWN2944.50
      11-05-2019, 04:44 PM   #10
Max Well
Max Well's Avatar
2488
Drives: '20 BSM X3MC, '20 PB X3MC
? - Apologies if I'm misunderstanding you, but the timing is in seconds, so it completed all maneuvers in 18.00 sec. If they don't complete a test section within 10 sec doesn't it stop and fail that section?
X7 did it much faster and smoother which just confuses me. Id need to know the software and mechanical differences.
The X7 40i completed it in 9:16 sec. I'm not a Physicist, but perhaps the weight of the vehicle alone allows gravity to provide more traction to one wheel? I haven't looked at their tests of smaller, lighter vehicles to see if that pans out, just thinking... And personally, not worried about those 9 seconds tbh.
      11-05-2019, 04:45 PM   #11
TTR
Drives: m3 f80 st3+ (800whp), x3m comp
Weight? So in 1 point more pressure
Current cars: m3 f80 zcp st3+, x3mc st1, tts mk3 st3+, 1m v8 swap - tracktool, Huracan perfromante - stock
Instagram: @ttrandrey
      11-05-2019, 05:02 PM   #12
Miko M
///M
Miko M's Avatar
Drives: 2020 M2C. 2020 X3M
Looking good
And all started in 80' with Subaru's symmetrical AWD
Pioneers in AWD
Life is too short...enjoy your life
///M
      11-05-2019, 05:04 PM   #13
onfireX5
2007. Two rollers in the back and one up front will stop it cold because the tire that is on the ground is equal to 100% braking on that point.
Not the same as going up a muddy hill with partial traction on both sides. You could put 100% pressure on the brake and torque up the converter but as soon as you let off the brake the open front differential will sense the 100% 0 % split and start spinning the roller side.
clee1982668.00
      11-05-2019, 06:05 PM   #14
Raikkonen
Raikkonen's Avatar
212
Drives: 2017 M3 - DCT
You're absolutely right in your assessment, and that's why "roller" traction test results are questionable at best.
The vehicle always ends up moving forward because of momentum, not traction.
In the real world, this does happen in something like snow or mud as tires eventually gain traction, but that's not the point of this test.
The point of these tests are to highlight the efficiency of an awd system, and its strengths and weaknesses.
In theory, in a roller test, you should be able to apply light throttle, continuously, and the car should gain traction. Time and time again, as in this video, the driver floors the accelerator, which then causes a tire to "catch" the roller, in conjunction with forward weight and momentum.
The proper way to do these tests is the opposite of what's being shown....you provide artificial traction, and real slippage (think wet ice), not artificial slippage. This way, you remove the infinite variables involved in creating a zero traction (artificial) environment, especially through something like a mechanical roller. On the other hand, a surface that provides grip has few, if any variables, assuming that the surface provides traction.
Here, you're simply watching a roller test, which could have a hundred different outcomes depending on the rollers used, and the way the vehicle is being driven.
clee1982668.00
      11-05-2019, 06:43 PM   #15
Salottox5m
Salottox5m's Avatar
Drives: x5m
Most bored video to watch - bmw owes me 25 seconds of my live back
RWSM345.00
      11-05-2019, 09:19 PM   #16
onfireX5
Interesting that this test did not catch a roller at high wheel speed with TC on and off.
ZHPsedan128.00
      11-05-2019, 09:52 PM   #17
Logical
Drives: 2014 M5
Ultimate Driving Machine!!
2015 F85 X5 M
2015 F86 X6 M (Retired)
2014 F10 M5 (Retired)
2010 E70 X5 M (Retired), 2010 E92 M3 MT (Retired)
2006 E60 M5 (Retired), 2000 E39 M5 MT (Retired)
1999 E39 328i (Retired), 1995 525i (Retired)
1987 325i (Totaled - that was fun!)
MK2018186.50
      11-06-2019, 06:25 AM   #18
Sedoy
Drives: F10 535xi Triple Black
Nothing new, xDrive have been passing this test for years.
      11-06-2019, 03:09 PM   #19
bimmer456
Drives: 340i
I think this lets you do actual donuts not just sliding. On the M5 you can turn off x drive completely.
      11-06-2019, 03:21 PM   #20
///M TOWN
///M TOWN's Avatar
2945
Drives: ///M
I'm referring to a comparison between the 2 variations of xDrive on the roller tests.
I know you can turn it off on the X5M.
clee1982668.00
      11-06-2019, 03:54 PM   #21
ParadigmDawg
ParadigmDawg's Avatar
574
Drives: 2019 AMG GLC63s
This a more fun way to do it.
onfireX52808.50
      11-06-2019, 08:18 PM   #22
onfireX5
X3MC does it like this when pissing on the competitors....
clee1982668.00
Opulence179.00
Copyright ©2000 - 2020, vBulletin Solutions Inc.
