10-29-2019, 01:14 PM | #1 |
Rep 361
Intake tube vs Charge Pipe
I been reading people replace intake tube , some mention charge pipe.
I did some google and can't seem to find what are the differ. Are they same thing, just call differently? Or it is actually totally differ thing? If they are differ, anyone got BOTH replaced but keeping the stock airbox?
2019 X3 M40i - Phytonic Blue, Black Vernasca Leather, 21" 718M Wheels, Premium Essential
10-29-2019, 02:35 PM | #2 |
Cowboy Astronaut Millionaire
2314
Rep 2,885
Hello
10-29-2019, 07:56 PM | #3 |
2314
Rep 2,885
I wanted to correct this. The intake tube is technically shorter. From filter box it is just the last tube. Charge pipe goes beyond that further down the engine.
Either way we still do not have a good intake system for the G01. The BMS is youre only option and it is a hot air intake and you actually lose power. IDK what would be the actual performance benefits of just a intake or charge pipe installs, besides cosmetic appearance and the sound.
10-29-2019, 09:24 PM | #4 | |
Rep 361
10-30-2019, 08:48 PM | #5 | ||
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3512
Rep 4,211
Also, the charge pipe will not "fail" but "can fail" if increased boost is used and sometimes at normal boost levels. The benefit of a charge pipe is to allow better flow and quicker response for turbo pressure build up. Usually by being metal and minimal pieces with smooth corners and good flow. |
10-30-2019, 09:09 PM | #6 | |
Rep 280
10-30-2019, 09:30 PM | #7 |
2314
Rep 2,885
Did you do a dyno pull? Or a 1/4 mile comparison? Or is this just the seat dyno?
10-30-2019, 09:38 PM | #8 | |
Rep 280
01-23-2020, 08:22 PM | #9 |
2314
Rep 2,885
I see we have a few companies that are now offering an intake tube and charge pipes. They are about $200 a pop. Is this worth it at all? The plastic pipes used to break in older gen BMW's. But I assume with the newer B58 setup it is redesigned. So even going higher boost levels with a tune. Does anyone here recommend shelling out $200 for either or $400+ for both?
01-24-2020, 12:47 AM | #10 |
Rep 271
Nope. I haven't heard of any on the B58 motors failing. The N55 and N54 motors had charge pipe problems. I think there was a 4-pot or two that had some charge pipe problems too. I don't really buy the faster response kool-aid either. Maybe some smoother flow, but negligible if there isn't an accordion of plastic somewhere in the path.
