      10-20-2019, 12:33 PM   #1
dscollins
dscollins
Drives: BMW X3 F25 2.0D SE 2014
Whirring Noise
Hi i have started to notice a very slight whirring noise which appears to come from the front passenger side of car , ( Automatic) its only noticeable at low speeds increases with RPM ?
Last edited by dscollins; 11-11-2019 at 03:07 PM.. Reason: After observing for a longer period
      10-20-2019, 01:11 PM   #2
Wgosma
Drives: 2012 F25 X3 28i (N52)
Not had this issue; trans in neutral and sound goes away would point to drivetrain/driveline issue...hard to say, could be anything from transmission to u-joint, bushing, etc.
Would seem car needs to be put on lift for diagnosis.
      10-20-2019, 07:21 PM   #3
BMWZ4
BMWZ4's Avatar
1924
Drives: '23 X1/'23 Allroad Progressiv
Originally Posted by dscollins View Post
Hi i have started to notice a very slight whirring noise which appears to come from the front passenger side of car , its only noticeable when the car is in motion and under drive ( Automatic) if i take the car out of drive whilst moving theirs no whirring noise. Any body had this problem ?
Is the fan running when you hear the noise? My fan (at high speed) makes a whirring sound
      10-21-2019, 07:18 AM   #4
TheCoolX3
Drives: 2016 BMW X3 35i M-Sport
I posted this awhile ago and still have the sound. Good news is that it likely means your trans is not likely to explode. Note my use of "likely"
I suspect it has something with the fluid level in the transmission. I am going to be changing my transmission fluid next week. I will update if it solves my issue or if it doesn't.
https://x3.xbimmers.com/forums/showt...t=transmission
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others
Instagram @TheCoolX3
      10-21-2019, 07:58 AM   #5
dat1guy
Drives: X3 xDrive35i 2016
I started noticing some new sound maybe like the one described here in the past 3 days. The sound is tied to the engine's RPMs and can only be heard at very low speed.
I changed my transmission oil roughly a month ago at a ZF certified mechanic. Transmission is acting great other than that.
      10-22-2019, 12:07 AM   #6
Oilverland
Red-gistered
11
Drives: 2016 X3 F25 xDrive 35i
Try turning A/C off, and wait a bit and see if it goes away. I get some whirring-like noise when mine is engaged. I can only hear it when driving slowly as other regular noises mask it once doing even city speeds. I ignore the noise. Just did a serpentine belt change and the compressor bearing seemed OK.
      10-24-2019, 12:51 PM   #7
dat1guy
that seemed to be it... well the noise stopped even with AC on.
      11-11-2019, 03:21 PM   #8
dscollins
dscollins
BMW 2.OD AUTO 2014 Whirring Noise
BMW F25 2.0D SE AUTO, A whirring noise is noticeable with increasing & decreasing RPM whilst under drive and at standstill. This is an update to my previous posting regarding this issue, i have had longer to observe this problem. any advice would be greatly appreciated
      11-23-2019, 12:12 PM   #9
dscollins
dscollins
How much fluid does it take to fill, did you change the plastic pan ?
