07-14-2019, 08:54 AM | #2 |
Father of Frankenfold
282
Rep 529
Drives: Yo daddy's 2014 X3 M Sport
Cam lobes look fine. The cost for the turbo maintenance or replacement seems excessive. A new turbo and labor should be no more than $4000.
If you want to get a low mileage used motor, try to find one that's from 2015 or later, after they changed the timing chain guides to the more durable ones. Otherwise, you'll be in the same boat down the road. I say go PS1 or PS2 with it and don't worry about the timing chain until it implodes. Then replace with low mileage motor or different car. All problems solved! Enjoy the new powa!
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
07-17-2019, 06:33 AM | #3 | |
![]() ![]() 38
Rep 102
Pat
2015 F25 X3 35i M Sport - Carbon Black |
08-04-2019, 02:38 PM | #4 |
![]() ![]() 11
Rep 84
I would shoot the photo to BMW and see if they are willing to help out. The fact it is a 2013 model, you are only 19000 miles above warranty, and they are going to court about this now as no timing chain should fail this early. Thats why they use a chain rather than a belt. Longetivity.
02-28-2020, 07:12 PM | #5 |
Rep 10
Please register a complaint on NHTSA website for Timing-Chain issue
I called NHTSA today and so far they only have a couple of complaints pertaining to the timing-chain problem. There are 68 other complaints related to power-braking and an investigation is launched for only that.
This timing-chain is a universal problem and I seriously insist that a complaint be filed so an investigation can begin. Can you take a moment and go to www.nhtsa.gov and write up a complaint of when your issue occurred and what you have done about it. It takes less than 5 minutes and is very very straight forward - enter VIN number (it is available online on your insurance declaration page), select "Engine & Powertrain" as the affected components and type in the incident. Also contact KKG Law office and talk to the paralegal about your issue. ![]() ![]() ![]() |
