03-10-2019, 06:34 PM | #1 |
![]() ![]() 80
Rep 151
Update on my random trunk opening problem
There are multiple threads discussing the random trunk opening problem:
Random Boot/Trunk Opening What's wrong with the trunk??? Random Trunk Opening - happened to you? Update: know the cause now! 2019 X3 tailgate opened suddenly during highway driving I dropped off my 2019 M40i at the dealer on February 25, 2019. I showed them the video of the trunk opening and closing on its own. The service manager agreed the trunk should not do that. They took the bumper off and did some diagnostics. The service technician "found antenna intermittently shorting causing smart open control module to fail." They ordered the following parts:
It took 10 days for the parts to arrive, and it only took them 1 day to install the parts and reattach the bumper. The car was returned to me on March 8th, 2019. You won't believe what happened next. The lot attendant pulled the car out of the garage and parked it in the customer pickup area. He handed me the key, then I walked toward the vehicle with they key held flat in my open hand so I wouldn't accidentally push the trunk button. As I approached the vehicle, the trunk opened on its own! I stood still in disbelief. I turned and asked the lot attendant if he saw the trunk open on its own. He said he did. As we were standing there, the trunk closed on its own! Obviously, the repair did not fix the problem. However, I did notice something that may be relevant. The vehicle was wet because the dealership just gave the vehicle a courtesy wash. To the best of my recollection, the problem only happens to me when the vehicle is wet. If you are experiencing the random trunk opening problem, I do I'd like to know if you can recall if the problem only happens when the vehicle is wet or is possibly covered in snow/slush that is melting. |
03-10-2019, 07:16 PM | #2 |
![]() ![]() ![]() ![]() ![]() 540
Rep 980
That must be very frustrating as well as a huge inconvenience. Clearly nothing they changed made any difference which means they’re back to the drawing board. Hope they sort it for you soon.
03-10-2019, 07:42 PM | #4 |
![]() ![]() 98
Rep 173
thestuarts,
YES! This has happened to me twice and BOTH times I had just hand-washed the car and was drying it - far away from the liftgate and with the fob lying motionless on a garage shelf far away from me. We are in the same boat. I've not had the time to address it, so I'm just drying it and detailing it outside my garage, so as to avoid any damage when it starts this unexplained malarchy. EDIT: My vehicle was unlocked in both instances, as I was drying it (and of course was drying door sills, jambs, interior glass, etc). Just wanted to be clear that my vehicle was not locked when this occurred. |
03-10-2019, 08:25 PM | #5 |
![]() ![]() 1000
Rep 1,727
I'm wondering if there is some kind of pathway of water ingression to the sensors to cause this to happen? Maybe some better seal would do the trick?
Frustrating that this happens to some unlucky people but not to everyone?! |
03-10-2019, 08:50 PM | #6 |
![]() 1529
Rep 4,569
I think the OP is saying that, despite the work the issue has not been resolved.
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino; Loaded '23 X1 Cape York green and Red/Black interior
03-10-2019, 09:04 PM | #7 |
Ring Leader of G8X Haters
![]() 23531
Rep 8,532
Drives: A Car
Garage List 2023 Genesis GV70 [0.00]
2022 Mercedes S 580 [9.25] 2007 Mercedes E 350 [0.00] 1999 Mazda MX-5 Miata [0.00] |
Is this only an issue with the X3, or have any X4 owners noticed it as well, or even X5 owners too?
Current Garage: 2022 Mercedes-Benz S 580 / 2023 Genesis GV70 2.5T / 2007 Mercedes-Benz E 350 / 1999 Mazda MX-5 Miata
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300 |
03-11-2019, 05:47 AM | #8 |
![]() ![]() 913
Rep 2,039
Drives: X3 G01 30i xDrive
If it's related only to wet conditions (not sure whether it is), than it could be possible, that only some are experiencing the issue. Might be some bad alignment of seal, or missing seal. Manufacturing error.
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
03-11-2019, 08:35 AM | #9 |
![]() ![]() 226
Rep 363
Well this will only add to the confusion, but mine was not related to wet conditions. However the fix they did was the same, mostly. They diagnosed a fault with the sensor unit which was triggering the trunk release. They replaced just the controller unit and it appears (so far) to have fixed it.
03-11-2019, 09:20 AM | #10 |
![]() ![]() 81
Rep 108
Drives: X3 M40i
If I had that much trouble with the kick opening , I would disconnect it and be done .
Just use button /key fob
M40I - phytonic blue -21 in wheels -black leather - M -sport plus pack -comfort pack -folding mirrors
03-11-2019, 09:28 AM | #11 |
BMW Client Advisor
3358
Rep 2,504
Drives: 2020 M340i
This has never happened to me but I want to keep an eye on this.
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. ![]() |
03-11-2019, 09:58 AM | #12 |
![]() ![]() 1000
Rep 1,727
In addition to faulty sensor, I would suggest OP check the key fob too just in case it got a 'stuck key' on the trunk button. This can be experiment to compare if both key fobs do the same to allow the trunk opens/closes itself when in proximity to the car.
03-11-2019, 12:18 PM | #14 | |
![]() ![]() 80
Rep 151
However, your point is valid. The fob could still be experiencing a malfunction. I will discuss this with the dealer because they did not mention troubleshooting the fob. Thanks! |
XGoober256.00 |
03-11-2019, 12:24 PM | #15 | |
![]() ![]() 80
Rep 151
I do want to clarify that I am not frustrated with this particular problem. I love the vehicle, even with the trunk problem. I write software and firmware for a living, so I can be understanding and patient while the bugs are worked out. |
03-11-2019, 12:29 PM | #16 | |
![]() ![]() 80
Rep 151
03-11-2019, 01:13 PM | #17 |
![]() 1529
Rep 4,569
I'm wondering if mine is fine because I have the factory tow hitch, therefore no kick-to-open feature
03-11-2019, 01:15 PM | #18 |
![]() ![]() ![]() ![]() 256
Rep 402
thestuarts Thanks for posting your ongoing experiences with this. I'm awaiting delivery of my M40i and I'm unsure what to do about all this. My biggest concern is this will happen while going through a carwash. The damage could be very bad in that case and I don't fancy trying to fight with BMW to pay for it.
So far I think I have seen a couple of potential workarounds posted. 1. Have the dealer code the car so that the trunk will never open when the car is locked 2. Have the dealer disable the kick-to-open feature (at least I'm assuming that is a dealer code option?) Anything else that can be done? I know neither of the above are ideal as we lose functionality in either case. |
03-11-2019, 02:30 PM | #19 | |
![]() ![]() ![]() 151
Rep 372
Drives: 2019 X3 M40i
03-11-2019, 02:34 PM | #20 | |
Rep 402
![]() https://x3.xbimmers.com/forums/showthread.php?t=1588303 |
03-11-2019, 02:38 PM | #21 | |
Rep 372
Your poll showed almost 30% of people who responded are having the issue - that is not the same as 30% of X3's having the issue... |
XGoober256.00 Spacecoast91.50 |
03-11-2019, 02:43 PM | #22 | ||
![]() ![]() 1000
Rep 1,727
XGoober256.00 |
