XBimmers | BMW X3 Forum BMW X3/X4 Forums BMW X3 (G01) / X4 (G02) Forum How to disable ASD on your X3 M40i: 3 methods that do not require coding
      12-17-2018, 07:23 PM   #1
TX3M
Drives: 2019 X3 M40i
BIMMERPOST
     Featured on BIMMERPOST.com
Hi all,
I've updated the title of this thread to reflect all of the methods (so far) for disconnecting ASD that the contributors to this thread have discovered and posted about. Thanks to everyone for your excellent, informative posts and for making this thread awesome! You all rock!
Methods:
1) Unplug the connector on the ASD mixing module (*works on HK equipped vehicles ONLY). See my original post below.
2) Take out fuse 218 (*works on HK equipped vehicles ONLY). See Pretzel's posts middle of page 3
3) Install the Technic bypass harness (works on HK equipped and base stereo vehicles). See Pretzel's post top of page 3
Method 1 - Unplug the connector on the ASD mixing module (*works on HK equipped vehicles only):
After reading several informative posts on here about disconnecting the ASD module (thanks to the OP's), I decided to try this on my X3 M40i. Turned out to be really easy and only took 10 minutes! Note that I have the Harmon Kardon sound system. Original posts are here:
https://f80.bimmerpost.com/forums/sh....php?t=1473441
https://f80.bimmerpost.com/forums/sh....php?t=1082175
Now that I've had a chance to compare ASD on and off, I must say that I am surprised how loud the "fake" sound actually is when ASD is on. No offense to those that like ASD, but I've concluded that I definitely prefer it off. Here are the steps (See Max Well's post in the middle of page 1 for all of the pictures):
1. Remove the left cover in the cargo area to reveal the large amp. The ASD mixing module that looks like a "small amp" which you need access to is behind this (pictures #1 and #2).
2. Remove the 4 bolts (10mm socket) holding the black bracket to which the large amp is attached to get access to the ASD mixing module. You don't need to disconnect the large amp, just move it to the side. The grey connector which you need to disconnect is located at the bottom of the ASD mixing module (picture #3).
3. Remove the 1 bolt on the upper left hand side (10mm socket) holding the black bracket which the ASD mixing module is attached to, then rotate it clockwise (as shown in picture #4 with the connector already disconnected) to get access to the grey connector.
4. To disconnect the connector (shown facing you in picture #5), press the small grey square "in" with a flathead screwdriver, then slide the black lever over it and pull to disconnect.
Put everything back in reverse order, and enjoy your "natural" sounding vehicle!
Appreciate 17
      12-17-2018, 07:38 PM   #2
LostX
Drives: N/A
None of the images are working for me?
Edit: they're working now. Thank you.
      12-17-2018, 07:45 PM   #3
TX3M
Sorry about that, maybe try pasting the URL's into another browser? I can see them in IE and Microsoft Edge.
      12-17-2018, 07:58 PM   #4
calintexas
calintexas's Avatar
No Photos for Me Either
I get a google requested URL not on server page with both Chrome and Firefox.
      12-17-2018, 08:02 PM   #5
BobsM3Coupe
BobsM3Coupe's Avatar
Same for me.
      12-17-2018, 08:07 PM   #6
TX3M
Originally Posted by BobsM3Coupe View Post
Same for me.
Sorry everyone, apparently I FAIL at this! Can I e-mail the pics to someone to host and put up working links?
      12-17-2018, 08:15 PM   #7
TX3M
Same for me.
I edited the post with new picture links. Please let me know if this is working now.
      12-17-2018, 08:23 PM   #8
calintexas
calintexas's Avatar
Yes, I can click on the link and the photo comes up now.
I'll send another post in several minutes that will tell you how to post the photos here if you want.
      12-17-2018, 08:26 PM   #9
TX3M
OK, thanks!
      12-17-2018, 08:42 PM   #10
calintexas
calintexas's Avatar
Uploading and Posting Photos
Down at the bottom of the page where you can create a quick reply post; click the "Go Advanced" button. Once the advanced post entry page comes up; scroll down the page until you see the "Manage Attachments" button; click on that and a page will pop up that will allow you to chose files off of your computer to upload, or to list URL's where files can be uploaded from. Once you have made your choices, be sure to click on the appropriate "Upload" button on the pop up page.
Once you've completed those steps you can manage your uploaded files from the "Attach Files" section near the bottom of your advanced post input page. You will be able to see how the uploaded photos will appear in your post by using the "Preview Post" button.
It's likely that there is more that you can do to manipulate your uploaded photos. It's just that it's been years since I've posted regularly here, and I'm sure I've forgotten several of the fine points.
      12-18-2018, 09:19 AM   #11
Max Well
Max Well's Avatar
2270
Drives: '20 BSM X3MC, '20 PB X3MC
Thanks for sharing your process, TX3M. I collated the photos onto one jpeg for ease of reference.
Pretzel83.00
SamS792.00
      12-18-2018, 09:33 AM   #12
SC11
Drives: X4 M40i
Assume then you just leave this connector disconnected and it doesn’t effect anything else?
      12-18-2018, 02:18 PM   #13
TX3M
Thank you for doing that!
      12-18-2018, 02:18 PM   #14
TX3M
Thank you, I will be sure to do this correctly next time!
      12-18-2018, 02:26 PM   #15
TX3M
Yes, just leave it disconnected. I did tie it down with a twist tie so it's not flopping around.
I can confirm that no other functions of the sound system are affected by disconnecting it. I also think that the sound system sounds "cleaner" now that it's not having to produce the additional engine and exhaust sounds.
      12-18-2018, 02:26 PM   #16
teaston
Pirate
teaston's Avatar
Drives: X3 M40d
Yes, although it will come up as an error if your dealership ever plugs it into diagnostics or to do a software update.
Current: X3 ///M40d in PB/Tartufo
Previous: F30 335d, F30 330d, E90 320d, E46 320d, E46 330ci
      12-18-2018, 02:42 PM   #17
MechX3M40i
MechX3M40i's Avatar
Drives: X3 M40i Blue/Cognac
A crazy thought just appeared in my mind - for those who added a dedicated amp and a big sub to the trunk - what would happen if the ASD is plugged to the new amp/sub? :
deladude144.50
      12-18-2018, 02:48 PM   #18
TX3M
Good point. I need to remember to tell my Service Advisor about it, and that they should not reconnect it when I bring it in for service.
      12-18-2018, 02:50 PM   #19
teaston
Pirate
teaston's Avatar
Drives: X3 M40d
You should re-connect it before it goes in for service in case they need to update the software, the computer won't let them update anything if there are any errors!
ted9992.00
      12-18-2018, 03:10 PM   #20
TX3M
Excellent tip, thanks!
teaston9803.50
      12-18-2018, 06:44 PM   #21
Yobyot
Yobyot's Avatar
324
Drives: MY19 X3 M40i
I paid for ASD and, by golly, I'm gonna listen to it.
Jokes aside I've never understood enthusiasts who turn stuff off in their cars. We're the kind of people who typically know everything about the cars before we buy them. I knew ASD was fake when I test drove the car — and I liked it.
So, apparently, did the C/D reviewer who test drove a Z4 M40i at the press introduction who describes a "throaty" exhaust note. Even fools the pros.
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29
MY19 X3 M40i:
Produced: 2018-08-15; Delivered 2018-08-22
BMWZ4803.50
      12-18-2018, 06:47 PM   #22
Neo1130
Drives: 2019 X4 M40i
Your BMW now becomes NASA Saturn V's competitor.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
