10-24-2018, 08:19 PM | #1 |
Rep 1,066
G01 rear cargo floor shock retrofit
To my dismay, the 2019 models do not have the shock to hold up the floor in the cargo areas. Instead, it has a Velcro strap. I felt like this was pretty cheap of BMW to remove the feature. Another thread talked about this and if it was possible to retrofit the 2018 shock. Since I just swapped my 18 for a 19 I had enough time with both vehicles to swap out the rear cargo floors. The hardest part was adding a wing nut to the ball stud for the shock since, surprisingly, bmw stopped welding in the nut the stud would normally thread into. Luckily, there is a small cut out you can get a finger through to attach a wing nut. Once that was done, it was smooth sailing. All you really need for the conversion is the floor with shock and the ball stud. The cargo storage area carpet doesn’t have the hole for the stud but could be easily cut out to accommodate. See pictures below on how to make the conversion.
18
BMWZ41909.50 iamahumanbeing10.50 r33_RGSport12971.00 Hairysteve35.00 pej744593.00 Legis53.00 M3X3Z326.00 sinbad4782.50 teaston10994.50 Captain_H19.00 jjrandorin355.50 X3inZug15.50 rem40i132.00 PeriklisV9.00 JoshV14.50 JustChris17489.00 MechX3M40i1006.00 dinan5m34263.50 |
10-24-2018, 09:12 PM | #2 | |
Rep 213
Drives: 2019 X3 m40i
10-25-2018, 06:54 PM | #4 |
Rep 3,933
Guess they thought we wouldn't notice the strut missing. Wrong.
Mine doesn't even have the 50 cent strap that the 19's are supposed to come with. Really cheap. But no doubt some slacker on the assembly line was to busy smoking a doobie to bother installing the strap. I did the honorable thing and cut a piece of PVC pipe to hold open the lid on the very rare time I need to get at something in the storage area. |
10-25-2018, 07:17 PM | #5 | |
Rep 1,066
You deserve at least a strap. Take it in for service and show them it is missing. Although they may have removed it for weight savings on the performance models. 😉 |
pej744593.00 |
10-26-2018, 02:58 AM | #7 |
Rep 738
This the set up for the boot floor without 'Extended Storage' option.
In my opinion, this now works better than the Extended Storage floor, as it is narrower and the fold out hook doesn't reach!! I know the removal of the strut is a minor thing, but the result for the extended storage floor is very poor and not what I'd expect from a premium brand ....
X3 M40i Carbon Black
10-26-2018, 03:39 AM | #8 |
Rep 2,046
Drives: X3 G01 30i xDrive
I agree, premium brand shouldn't do such a cost cuting things and changes after the release of the vehicle. People are expecting to have the strut - that's how it says in every advert.
The picture was mainly for those, who says they don't have any hook for the floor now. I didn't now (stupid me, it's obvious now), that the floor with extended storage is actually narrower |
10-26-2018, 04:06 PM | #10 |
Rep 46
Drives: 2019 X3 s30i
My 2019 has the shock as well.
10-26-2018, 06:19 PM | #11 |
Rep 3,933
I was told all 2019 s30i's have it up till August production. Just like the other X3's for the 2018 model year. Then when the entire line of 2019 models started production, that's when they deleted the strut thinking we wouldn't notice.
10-26-2018, 10:13 PM | #12 |
Rep 969
They were making 2019 models of the s30i since spring, in parallel with 2018 models of the x30i and M40i. The "current" 2019 models (late July prodution and beyond) don't have the shock anymore.
10-27-2018, 07:54 AM | #13 |
Rep 4,558
So cheap of them to delete the strut.
Current: 2021 ///M3 Competition Isle of Man Green
Ordered: 2024 ///M2 Zandvoort Blue Past: 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i |
10-27-2018, 11:07 AM | #14 | |
Jim
270
Rep 156
Then it must be after the 27th, that is what they quoted as my build date. |
10-27-2018, 02:38 PM | #16 |
Rep 1,066
From my original post, you’ll need the floor with shock (it’s glued on), the ball stud mount and you can either cut a small hole in the carpeted storage area you have or replace that as well.
10-27-2018, 05:36 PM | #17 |
Rep 969
That sounds about right based on the VINs and build dates folks were posting in the 2019 build sticky thread when 2019 M40i production started. You probably have one of the very last X3's built during the previous model year cycle.
10-28-2018, 07:05 AM | #18 | |
Rep 55
10-28-2018, 07:59 AM | #20 | ||
Rep 1,054
Last cars that had strut would have been built in July, they take around 6-8 weeks to reach UK and maybe if dealer put it in as a stock car it wouldn't have been registered straight away, so possibly a older car than it looks maybe? |
10-28-2018, 08:48 AM | #21 |
Lateral grip estimator
957
Rep 1,390
My 2019 X3 M40i delivered last week in the UK has no boot strut.
Just a Velcro loop which kinda lines up with the curry hook on the right of the boot.
10-28-2018, 08:54 AM | #22 |
Rep 64
Drives: G01 X3 xDrive20i M Sport
Just ordered an X3 last week, and when I asked my sales assistant if there were any differences between the 2018 and 19 models, he told me there were absolutely no differences (I’m in the Netherlands) could this be correct for NL or is he simply ill-informed? Don’t really care about the strut etc but would be nice to know
