08-20-2018, 01:52 PM | #1 |
Rep 911
Drives: 2020 X3 M40i
New Snow Shoes
Ordered from tirerack.com. Went w/ 18" wheels in a 'satin' finish - thought finish might match mirros and trim. Tires slightly wider than stock @ 255/55 R 18. (Saved $200 by going up to 245 series as found closeout special.) Specs list diameter @ 0.4" larger than my 20" stock tires. This rubber will allow me to run over stuff and not sweat the pot holes.
See photos below. Don't plan to mount until eminent snow. Enclosing receipt and photos. Last edited by sinbad4; 08-20-2018 at 01:57 PM.. |
08-20-2018, 02:49 PM | #2 |
Lateral grip estimator
957
Rep 1,390
I suggest you do a test fit on one front wheel ASAP to make sure they clear the brakes.
If they do, great! If they don’t at least you know now rather than when the snow is imminent... |
08-20-2018, 07:12 PM | #4 | |
Rep 911
I called tirerack.com, they were adamant they'd fit. Perhaps you're right. Better safe than sorry. |
Rbrown2765.50 |
08-21-2018, 06:27 AM | #6 |
Rep 969
TireRack doesn't always get a chance to test for things like brake clearance on every single model -- learned that years ago on a Subaru forum. I would not assume they actually put 18" wheels on an M40i. Could be fine for all we know but definitely test first. I assume the front calipers are the largest but don't know offhand.
thestuarts84.00 |
08-21-2018, 07:43 AM | #7 |
Rep 641
I had 18” winter wheels on F80 M3 (BMW OEM) don’t think M40i brakes are any bigger. They don’t fit with ceramic brake option on the M3 I believe.
M2 competition, Alpine White
Previously Owned : X3 M 40i, F80 M3 Comp Pack, DCT, Yas Marina Blue, F80 M3, DCT , E92 M3 Comp Pack, E92 M3, Z4MC, E46 M3 CS, E46 M3 |
08-25-2018, 07:28 PM | #8 |
Rep 911
Tires fit OK. No problem clearing brakes. Little close on upper inside by control arm. With factory front, I can fit 1.5 fingers, with new rubber, only about 0.8 fingers. Probably enough. Maybe I'll order spacers - saw some somewhere in forum. Posting pics w/ Winter on front, factory 20's on rear. Including photo w/ wheel off as well, you can see larger front brakes with some interesting suspension parts (active).
10-01-2018, 02:16 PM | #10 |
Rep 13
Glad I saw this post, as I'm looking into winters and was looking for the least expensive option since my m40i is a lease. Looks like 18's will do the trick. Is there a particular offset you would recommend?
Thanks. |
10-01-2018, 02:43 PM | #11 |
Rep 911
10-01-2018, 02:53 PM | #12 |
Rep 4
I spoke tire rack this morning as I was interested in 18s as well. The guy told me that they had an M40 in and used a CAD or something to scan everything including the brakes to ensure fit. The ones I’m interested in ordering have a 32mm offset.
10-01-2018, 08:46 PM | #14 |
Rep 92
10-01-2018, 09:00 PM | #15 |
Rep 3,654
10-02-2018, 08:56 AM | #17 |
Rep 13
Thanks for the heads up
11-12-2018, 01:44 PM | #19 |
Rep 1,063
Thanks for this thread. I used your fitment experience to order 18"s (A15s in Matte Titanium) along with 225/60R-18 Michelin Pilot Alpin from TireRack. I was going to go with the non-RFT tires, but then I thought....I'd rather spend a little more money to have the peace of mind....especially in rural Colorado.
Delivered --> '21 G01 X3 M40i, 8SA, Sunstone Metallic with Cognac Vernasca, 22Z, ZDA, ZDB, ZPK, ZPP w/ 4HA, ZPX, 2VF, 3AC, 4K1, 688, 6NW, 5DF
Past --> ?19 G01 X3 m40i, 15 F33 328xi, 8SA, '13 F30 328i, '08 E92 335xi, '95 E34 530i, '88 E30 M3 |
sinbad4782.50 |
11-12-2018, 08:47 PM | #20 | |
Rep 911
I like those A15 wheels a lot.. but tirerack.com says they're not a fit for the M40i. Did you call them to verify? Nevermind.. now it says they fit. Go figure. ;-) |
shoptb176.00 |
