07-17-2018, 10:27 AM | #1 |
Rep 3,032
2013 X3 35i - What to pay for brakes and rotors?
Not getting any replies on the X3 forum .....
Car is off warranty so took it to a local indy (never been there before), says brakes need doing, i guess they are due but it only has 60,000KM (40,000 miles). Assuming they do need doing, he wants a little over $1,400 for the job, seems excessive to me or am I just being a little ignorant here? What have you paid in the past and do you always go with OEM parts from BMW? 'Mericans, don't bother doing the exchange conversion it's irrelevant. |
07-17-2018, 10:35 AM | #2 |
BXR
575
Rep 636
My guess would be that the OEM stuff is just really spendy. It's hard to say without a brake down of that quote though. Pads? Rotors? Caliper work? Bleeding? Flushing?
If you're out of warranty, I'd look at nicer aftermarket stuff. I imagine you could find good rotors and pads for $600 for all those parts. Labor shouldn't be horrible. |
07-17-2018, 10:47 AM | #3 |
Rep 3,032
Pads $382
Rotors: $714 Front sensor: $36 Brake Fluid: $22 Labour: $435 = 1,588 - $150 "new customer discount". All numbers include taxes. |
07-17-2018, 10:51 AM | #4 |
Rep 1,171
sounds right for BMW OE parts. You can save a lot by buying non OE parts. Check RockAuto for non-OE parts. Guessing will be ~$700 for parts.
07-17-2018, 10:58 AM | #5 | |
BXR
575
Rep 636
Rotors/pads/bleed is a pretty easy home job, so I'd want to do that myself, personally. You could get that done at home for less than half of that. I'd call a local shop (non dealer) and see what they'd want. None of this labor is weird or BMW specific, so any repair shop could do it. |
07-17-2018, 11:13 AM | #6 |
Rep 3,032
Nah this was from an Indy, not a dealer, not sure if he is using OEM parts either, i suspect not.
Any recommended or "Avoid" for aftermarket? I see Textar, Zimmerman,Wagner, TRW, Raybestos ... thoughts? |
07-17-2018, 12:02 PM | #7 | |
Rep 132
Good lord, that's insane! Buy your own parts from reputable online retailer and find an indy to install (or install yourself) It's not hard. Any of those brands are fine. I personally use the better grade centric coated rotors on all our cars. Well under $100 each. Not sure which pads are good yet, I need research to get some lower dust ones for my 335i. |
07-17-2018, 12:55 PM | #8 |
Rep 3,032
Ok I can source those parts locally for about $650 under those brand names, if y'all are good with those brands then i will go that route.
07-17-2018, 01:26 PM | #9 | |
Rep 28
I switched to Akebono - no dusting, but stopping power is very different -lacking initial bite, so I need to "work" more to stop car predictably. Once Akebono wears out, I will probably switch back to OEM - I do miss the way they stop. |
07-17-2018, 01:40 PM | #10 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
I've been using EBC pad and rotor kits on my cars lately. They're great quality and super inexpensive. For the X3 front, there's EBC S12KF1521 (Redstuff pads) S13KF1803 (Yellowstuff pads). For the rear, S12KR1378 (Red) and S13KR1503 (Yellow). Should be able to pick up pads and rotors for all four corners for less than $500 if you shop online for good prices with free shipping. Then pay an indy to install it all. BTW, if the sensors haven't been triggered by being worn through, they can be reused.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
07-17-2018, 01:51 PM | #12 |
Rep 2,527
OP, last few runs I've gotten my maintenance items from Germanparts.ca - they carry the typical OEMs. I believe it`s Textar, TRW, Zimmerman, and Brembo for the BMWs.
07-17-2018, 02:00 PM | #13 |
Rep 3,032
this is where I am looking. Ok so you're good with that vendor and their parts? The prices are yeah, a SOLID 40% less than the numbers I saw this morning.
07-17-2018, 03:59 PM | #17 |
Rep 3,549
Hmm not sure which thread to reply to. Anyhow - you don't necessarily have to replace the rotors. They can be turned down, and a shop that knows what they are doing (it's not a tough job) can do it correctly. It'll give you a good clean surface for the new pads. You will want to check minimum thicknesses first but unless you currently have a problem will probably be OK.
For my Ford Ranger or old Eclipse I'd just get new rotors since they were like $30 - $50 each. At $700 I think I'd look into some other options. Maybe you need new ones but - maybe not. |
07-17-2018, 08:16 PM | #20 |
Rep 290
07-18-2018, 08:18 AM | #21 | |
Rep 2,527
I do echo the other comments here that you should physically/visually inspect the rotors and pads and determine what you really need. We did have to do brake pads at all four @ 40,000km but not rotors. I believe we got TRWs, which now seem to be glazed at the rear as there's a lot of squeal recently but they still appear to have plenty of life. no issues with performance though. |
07-19-2018, 04:49 PM | #22 | |
Rep 227
Including labor, I think anything between $900-$1300 USD is what I'd expect. |
