06-14-2018, 07:03 PM | #1 |
Rep 221
35i M sport Front bumper 20"rims 275/315 tires
Hi all,
Thought I would share some of the mods I have done so far. This post is long overdue, I just never got around it. Its a 35i that I purchased back in 2015. I'm on my second set of wheels. The first set (black) 20x8.5 with 245 front and 20x10.5 315 out back. The offset was't optimal so I had some rubbing in rear (even after I clearance the outside of the fender) . The second set have a much better offset they are 20x9.5 and 20x11 with factory X5 sport tire sizes 275F/315R. Mods as follows:
I think that covers it for now. On to the pics! Edit the pics I have are too large I will need to figure out how to resizes them in order to post them. Below is the only one I could get to upload. Last edited by rcsup1; 06-14-2018 at 10:02 PM.. |
06-15-2018, 09:13 AM | #4 |
Rep 221
The wheels in the picture are F20x8.5 35mm and R20x10.5 32mm. The wheels on it now are F20x9.5 35mm and R20x11 40mm.
I'll try to get the other pics to load over the weekend. |
06-15-2018, 10:18 AM | #6 |
Rep 921
06-15-2018, 11:09 AM | #7 |
Rep 221
Overdose,
This is not a factory M Sport. I installed an M sport front bumper, seats and steering wheel . I plan to color match the rest of the body moldings and will be installing the wider M sport flares in the rear as well. |
06-15-2018, 01:55 PM | #8 | |
Rep 5
06-15-2018, 02:27 PM | #9 |
Rep 221
It was relatively easy but I have been modifying cars for 25 plus years. You will need to trim and alter the factory splash guards some since they don't line up fully.
I also trimmed to front bumper support to get the coolers mounted and have the full mesh look/functionality, vs the factory half cover side vents. I'll try and post pics later. What is an easy way of shrinking the pics I have so I can upload them. |
06-16-2018, 03:20 AM | #10 |
Rep 64
Did you have edc for your suspension from the factory? I want to get coilers but not sure how it'll affect other electronics in the car, or if the brake system uses input from the electronic shocks to apply the brakes for handling, or if codes will be thrown, etc.
06-16-2018, 08:31 AM | #11 | |
Rep 383
Image Size by vsmedia.de Check the App Store |
06-16-2018, 08:35 AM | #12 | |
Rep 383
“37: Vehicles equipped with electronic damper control: Electronic damper control needs to be disabled. Disable modules available through KW. Please check KW accessories list.” http://whttp://http://www.kwsuspensions.com/...-1522000z.htmlww.kwsuspensions.com/products/kw-suspensions/cancellation-kits/kw-suspensions-kw-edc-delete-unit-bmw-68510301.html http://www.kwsuspensions.com/product...-1522000z.html |
chknlytle16.50 |
06-16-2018, 11:16 AM | #13 | |
Rep 4,102
These offsets - you said the first ones rubbed, the second set was OK? I've been considering another set of wheels for my X3 and am looking at what I can get away with. I know tire width is a factor as well. If you have a minute could you clarify what did and didn't work? |
06-18-2018, 07:44 PM | #15 |
Rep 221
The first set rubbed in the rear with the 315's. This even after cut the top of the fenders some to make space. The second set does not rub in the rear, again keep in mind my fender are cut to allow more space. There is some minor rubbing in the front with the second set (due to the 275 tires which are wider) on full lock. Nothing major though.
tracer bullet3438.00 |
06-18-2018, 10:18 PM | #17 |
IG @bmwF9xG80
3859
Rep 7,614
Looks good when you get more serious into tuning/performance stuff let me know i've done it
- CTS Turbo FMIC - CTS Turbo Downpipe - CTS Turbo Chargepipe - proTUNING Freaks Bootmod3 - Dragy Performance Meter = Smiles per gallon
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
06-18-2018, 11:02 PM | #18 |
Rep 221
Thanks man I plan too. I've let this ride since it's my daily but i have always have a case of mod fever..lol I also have a Single turbo Supra, rc cars, rc boats, dirt bike and 4yr old daughter so time and funds get kind of scarce...lol
FSociety3859.00 |
