BMW 5-Series (G30) Forum Cosmetic Modifications Cerium Trim Part #'s
      06-11-2018, 07:53 PM   #1
ake111
Drives: 15'640xi
Im looking to install the cerium front grills, front air damn bumper trim and side vent trim
I searched and cannot fine any part numbers, any help would be appreciated
      06-11-2018, 09:00 PM   #2
Canuck99
Drives: '18 M550i, '15 Jaguar F-Type R
Ask the "getbmwparts" guys, they will know. Remember they are M550i parts when you search. Or you can always try to find someone in your area that swapped them out. If someone in western canada wants some, my set is sitting in the garage...
      06-13-2018, 06:21 AM   #3
nsa100
Drives: G31 540i & G30 540i M Sport
This may help
https://www.salesafter.eu/?cat=c331_...rieur-331.html
      06-30-2018, 02:52 PM   #4
Drewbie613
Drives: 2018 BMW M550
Im avtually trying to find black replacement parts for these parts on my M550. I found the side vents as im pretty sure theyre they same as any G30. The front cerium grill vents are what Im having trouble finding.
      07-06-2018, 08:11 AM   #5
roxxor
roxxor's Avatar
1141
Drives: 2024 iX50
Here are the Cerium part #'s:
Center Grille Left - 51138070471
Center Grille Right - 51138070470
Side Air Duct Trim Left - 51748063261
Side Air Duct Trim Right - 51748063262
Front Air Dam Trim Left - 51118063267
Front Air Dam Trim Right - 51118063268
Be aware though, based on what I researched, it seems that the Front Air Dam trim pieces for the M550 sit on a different grille part # than other models, as the M550 doesn't have fog lights. So if you are trying to install this on a model with fog lights, you may have to remove the fog lights in order to get this to work, as well as replace some other parts of the air dam.
      07-06-2018, 08:22 AM   #6
delrosa81
Delrosa81
delrosa81's Avatar
Singapore
59
Drives: G30 540i M Sport
I'm having the G30 540i M Sport. I did not change the grille parts nor removed the foglights. Instead, I got the local dealership to fit it in and I do not find that it poses any issues. Below are some photos.
F20 LCi
JustChris17489.00
      07-06-2018, 09:05 AM   #7
roxxor
roxxor's Avatar
1141
Drives: 2024 iX50
That's good to see that it can be done, as that is ideally what I would want to get done on mine if I end up getting the Mediterranean Blue. Looks good!
      07-06-2018, 02:59 PM   #8
Canuck99
Just a heads up, I have the Cerium Grey trim from my M550i available for sale. Parts include both grills, side vents, mirror caps and front bumper/air duct trim. There were removed before I took possession so they are new. Retail pricing is over $700 USD.
      08-09-2018, 11:51 AM   #9
billybarr
Drives: 2015 M3 yas marina
Yes, but how would you find the front air dam trim in black? I’m having a really hard time finding It
      08-09-2018, 08:51 PM   #10
Drewbie613
Here you go
https://www.getbmwparts.com/oem-parts/bmw-g30-m550i-m-performance-gloss-black-bumper-trim-right-51712431044
      08-11-2018, 05:10 AM   #11
wyang828
Drives: 2018 BMW G31 530i
Does anyone know if the LHD and RHD m550i share the same part number for side mirror caps ? Thanks again
      01-02-2019, 05:24 AM   #12
Soussef24
Drives: Volvo XC60 D5 Momentum MY11
Hi,
Do you happen to know how they managed to fit them in? My understanding is that the "M Performance" bumper finishers are different from those of the M Pack, the air vent to the side being fully contoured on it (see image below). I guess that why they say you need to lose the fog light to have it, because the part number 51118063267 comes with the grille.
If I understood correctly, for the "M Performance" finishers to fit in with the fog lights and the original M Pack grille, the additional guide need to be shaved? isn't it?
      01-16-2019, 04:24 AM   #13
rabjab12
rabjab12's Avatar
11
Drives: 2021 M5 comp
2021 M5 Comp  [0.00]
Canuck99. Where did you find all the replacement parts for the grey pieces? I want to change mine out for all black or carbon fiber. Thanks.
      01-16-2019, 04:36 AM   #14
rabjab12
rabjab12's Avatar
11
2021 M5 Comp  [0.00]
Ok. Found the grills and air dam moldings. Now i only need the black mirror caps and fender pieces in black. Where do i go next? Thanks. 2018 m550 dark graphite
      01-19-2019, 05:32 AM   #15
delrosa81
Delrosa81
delrosa81's Avatar
Singapore
59
Hi,
[IMG]https://4.bp.blogspot.com/-VqrYFkEui..._EightyOne.jpg[/IMG]
[IMG]https://4.bp.blogspot.com/-3AL3CqMPB..._EightyOne.jpg[/IMG]
[IMG]https://2.bp.blogspot.com/-9qV8UBsq1...yEightyOne.jpg[/IMG]
[IMG]https://3.bp.blogspot.com/-HYWhL5rDx...yEightyOne.jpg[/IMG]
[IMG]https://3.bp.blogspot.com/-5-BXUo2oV...yEightyOne.jpg[/IMG]
Hi,
[IMG]https://g30.bimmerpost.com/forums/at...8;d=1546428220[/IMG]
Nope no shaving nor cutting required. Just a straight fit in. I was present when the guys fitted these parts.
F20 LCi
      06-28-2023, 08:18 PM   #16
nytfox
nytfox's Avatar
Drives: 2018 BMW G30 M550xi
2020 BMW 750i  [0.00]
2018 BMW M550i  [0.00]
Do you know how they removed it from the bumper? Does it require unmounting the whole bumper or is there a trick to pull it with the bumper on? Mine's all scratched from a dodgy parking job one night. Wanted to replace it myself.
2018 BMW G30 M550xi
Past - 2016 BMW F06 650i GRAN COUPE / 2014 BMW F30 335xi / 2009 AUDI B8 A4 3.0L TFSI QUATTRO
5post
