THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Liqui Moly Special Tec LL 5w-30
      03-19-2018, 03:00 PM   #1
amw896
amw896's Avatar
Drives: 2015 BMW M235i
2015 BMW M235i  [10.00]
All -
I just took my car out of storage and decided to try some Liqui Moly product in my 235i. I usually run the bmw branded pennzoil 5w-30 but figured why not as my shop swears by the products (potential conflict of interest aside).
So far so good and their technical spec sheets look promising in comparison. I've also seen quite a few favorable reviews about their products but doesn't seem like many forum members run it here.
Anyone have any feedback?
Cheers
      03-19-2018, 05:21 PM   #2
123Britt
Drives: 15 M235i AT
PP EURO 5W-30 and 5W-40
I just don't see any LM oil as a superior product over the BMW oil particularly in comparison to PP EURO 5W-40 in 70F +.
I run the 5W-30 in winter and 5W-40 in summer and have a hard time justifying not simply going the Wallmart and getting Castrol Edge 0W-40.
If it were not for the Low 6% NOACK range of the GTL oil I would get the PAO Castrol.
LM over on bobistheoilguy is not really seen as a go to oil.
      03-19-2018, 05:58 PM   #3
amw896
amw896's Avatar
nice, thanks for the feedback. I'll monitor my gauges to see how it manages heat and pressure. I did notice that the BMW PP seemed to run a bit high for my liking.
      04-05-2018, 10:42 AM   #4
MarcoZandrini
Drives: 2018 M240i
LM uses a base stock grade 4, while the stuff from the dealer is grade 3 base stock. The difference: grade 3 is hydrocracked Dino oil while grade 4 is synthetic from the get go. I’m running LM 5W-30 in my M240i. Tracked him at VIR last weekend with no issues.
      04-05-2018, 10:43 AM   #5
amw896
amw896's Avatar
Originally Posted by MarcoZandrini View Post
LM uses a base stock grade 4, while the stuff from the dealer is grade 3 base stock. The difference: grade 3 is hydrocracked Dino oil while grade 4 is synthetic from the get go. I'm running LM 5W-30 in my M240i. Tracked him at VIR last weekend with no issues.
thanks dude! I'll keep running
      04-06-2018, 12:41 PM   #6
biz4two
Drives: 2014 f22 n20 228i
Arrow
I continue to hear nothing but good about Liqui Moly products!! So, I hope you report back your thoughts and experience.
I watched this video last month...and thought you might find it interesting!!
biz
Tpeterson156.50
      04-06-2018, 05:12 PM   #7
amw896
amw896's Avatar
Nice find! I'm liking the product so far. Can't tell if it runs better or stable until it starts getting hot out but so far so good. I didn't know their fuel was that much better quality. I also don't really understand how fuel quality affects oil OCI either.
biz
      04-08-2018, 06:39 PM   #8
zipphreak
Drives: m235xi
FYI i just did the transmission fluid and filter in my 235. I used Liquid Moly's Top Tec ATF 1800 fluid.
https://products.liqui-moly.com/top-tec-atf-1800-2.html
"Developed for ZF 6HP19/26/32 and ZF 8HP 45/55/70/90 type automatic transmissions that are installed in various Audi, BMW, Jaguar, Land Rover, Porsche, etc. vehicles."
Certified BMW Approvals,
BMW 83 22 2 305 396
BMW 83 22 2 305 397
BMW 83 22 2 152 426
BMW 83 22 0 142 516
BMW 83 22 2 289 720
BMW M-1375.4
      04-08-2018, 06:59 PM   #9
amw896
amw896's Avatar
BMW 83 22 2 305 396
BMW 83 22 2 305 397
BMW 83 22 2 152 426
BMW 83 22 0 142 516
BMW 83 22 2 289 720
BMW M-1375.4
How do you like it? I was thinking about doing mine soon.
      04-12-2018, 10:43 AM   #10
123Britt
Drives: 15 M235i AT
BaseStock VS Final Product Performance
Following this logic: Redline 5W-30 Grp V is better all others.
In the past the basestock was a good indicator of the final products performance. Looking at the total package is now preferred because things like GTL is a game changer.
Although - I hear what you are saying -- Grp 4 & 5 are awesome.
      04-12-2018, 01:18 PM   #11
MarcoZandrini
Drives: 2018 M240i
Great question! Here's the skinny. Everytime a sparkplug fires, a few microscopic combustion particles get passed the compression and oil rings. After many miles thes microscopic particles add up. This determines the OCI.
Now, gasoline in the USA is not ulta-low sulphur gasoline. But, our diesel is ulta-low sulphur diesel. So, using a BMW LL04 oil in a gasoline fired BMW in the USA requires shorter OCI as it's not designed to handle the sulphur-based by-products.
amw896582.50
      04-12-2018, 03:54 PM   #12
amw896
amw896's Avatar
Nice! I wonder how ethanol based fuels impact this as well.
      10-15-2019, 08:14 AM   #13
MarcoZandrini
Drives: 2018 M240i
I contacted the EPA about ultra-low sulphur gas as I’m concerned about using an LL04 oil in the US. According to the EPA, refiners will be required to produce only ultra-low sulphur gas starting January 2020. So if you’re thinking about running an LL04 oil wait until February or March so the sulphur gas can be diluted with the ultra-low sulphur gas.
amw896582.50
      10-15-2019, 11:45 AM   #14
amw896
amw896's Avatar
so, this probably means bmw will also use only ll04 oils in the US in about a year?
      10-18-2019, 07:13 AM   #15
MarcoZandrini
Drives: 2018 M240i
That’s likely a valid assumption.
2addicts
