03-05-2018, 11:10 PM | #1 |
Rep 2
2005 X3 2.5 Fuel Issue
Hello X’ers! Here is my issue that I can not do the life of me figure out. I have a crank but no start issue. Fuel pump right? Replaced, still the same problem. Replaced Cam Shaft Sensor. Same issue. Replaced the Coil Packs and plugs. Same issue. Before replacing the fuel pump, I ran diagnostics and no DTCs or even faults in memory, so I went on knowledge of troubleshooting. The pump is working as I can hear it pump when I cycle the ignition. I have pressure to the blue fuel line at the top of the white cover but no pressure or fuel in the fuel rail. I’ve also replaced the relayand fuses. What am I missing? Could it be the Fuel Filter/Regulator as the culprit? Please help!!!
