      03-04-2018, 11:10 AM   #1
TheBMWBuster
Drives: 2018 X3 G01
2018 X3 G01 passenger side water leak
My new X3 is leaking water from the front passenger pillar. It is coming out of the horizontal seam about an inch below the top of the dash and causing the carpet to get wet. The seam is hidden if the door is closed. The leak seems to occur when water is sprayed on the outer side front portion of the roof rail. I have an appointment scheduled for Monday and would like to know if anyone has anything information that would help in diagnosing and solving the problem.
      03-04-2018, 11:57 AM   #2
arciga18
arciga18's Avatar
1757
Drives: LeMans/ Chestnut E90, RWD
YIKESSS. Keep us posted
      03-05-2018, 03:35 PM   #3
ed4
ed4's Avatar
1465
Drives: '21 F96 X6MC, '18 G30 M550i
I had your same exact problem with my (at the time, new) 2001 Audi S4. The cause to my issue was a clogged rain gutter drain, which had caused my inside front passenger footwell to get wet.
The dealer should quickly be able to diagnose your issue and either clear any clogs or to refit any weather seals. A real disappointment in a new car, but it's not too bad to resolve. Good luck!
'23 F93 M8 GC ZCP
- HRE S101SC - Full Akrapovic - '15 Audi R8 4.2 S-Tronic
(Past) YouTube '21 F96 X6M ZCP Akrapovic/MSS/BC Forged, ‘18 G30 M550i, '18 G01 X3 M40i, '15 F10 M5 ZCP HRE S101 #1 & #2/Akrapovic, ‘13 W204 C63 AMG - ADV1 5.01SL's
      05-24-2020, 11:09 PM   #4
Khelms04
Drives: 2019 X3 xDrive 30i
Any updates on this? My '19 X3 recently had a leak from the driver's side A pillar and microphone in the ceiling. It's never done this before and sits outside at work in rainstorms all the time. I was shocked and very upset. Everything dried out quickly with no lingering issues since it's been so hot here lately.
My X3 has 8,300 miles and is garage kept and never sits under trees. The sunroof drains are fine, front and rear. I've poured copious amounts of water into the rain gutters with the sunroof open and all four drains evacuate the water immediately. I can't seem to replicate the leak!
This leak occurred after a heavy downpour while I was parked sideways on a slight incline; the vehicle was essentially leaning to the left towards the driver's side. We were at a friend's house and the only place to park was along the edge of the ditch. My sunroof and doors were closed so that's not the culprit. I'm at a loss, especially given that I cannot replicate the issue even when pouring buckets of water onto the roof and windshield seams.
What do you think could have caused this? I've attached a picture of the water seeping from the A pillar.
      05-25-2020, 08:37 AM   #5
Toodalu
Toodalu's Avatar
626
Drives: 18 & 19 X3
Sunroof drains would be my 1st guess since it's common to see water around the drivers phone mic and 2nd common issue, are the pano seals. Open the sun roof and inspect the drains on each corner. While there, inspect the seals around the pano roof.
2018 X3 Xdrive30i
2019 X3 M40i
2004 Supercharged Acura TL 6MT, NAVI A-Spec
2022 M3 Competition XDrive
      05-25-2020, 12:54 PM   #6
Khelms04
Thanks for the input! I appreciate it. The drains were my first thought, as well. I even replicated parking in the same position and poured water into the gutters and couldn’t get it to leak. I’ve recalibrated the sunroof to ensure proper closing, but it appears that it was fine to begin with. The sunroof seals look fine as I treat them with non-silicone protectant and keep them wiped free of debris. There is literally nothing but a bit of pollen in the rain gutters; not even a speck of debris. I wouldn’t expect any different being only a few months old and garage kept.
Could the car being parked tilted to the left have perhaps caused even properly functioning rain gutters/drains to become overwhelmed and leak water into the headliner during a heavy rain? Just a thought. I’d hate to think that, but I’m running out of ideas. I also don’t want my dealer taking stuff apart and risk panels/pieces not being reassembled properly. Plus, it doesn’t look as though they’ll be able to recreate the leak anyway. Thanks again for any input!
      05-26-2020, 04:21 AM   #7
satz
Australia
384
Drives: 2019 BMW X3 M40i
My guess too would have been the sunroof drains, but it looks like you've tested them well. I'm sure I've read other thread/s with exactly the same location of leak as you describe. They turned out to be the sunroof drain in those cases.
Perhaps the hole where the roof rail attaches to the roof might not be properly sealed?
Is yours the original windscreen?
PLease let us know how you go..
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K
Previous: 2009 335i LCI, Bluewater
      05-26-2020, 04:48 AM   #8
satz
Australia
384
if it's any help, here's a diagram showing the drain holes, and pipes for the sunroof
https://www.realoem.com/bmw/enUS/sho...diagId=54_0562
      02-08-2022, 11:29 AM   #9
powerpop2000
powerpop2000's Avatar
Drives: 2010 E90 X-Drive Sedan
Reviving the thread G01 sunroof drain leak
Ok, this thing just happened to me. Parked car on level ground for a week at a northeast airport in the winter weather. Came back to 10'F cold temps and an icicle along the interior door below the glove box. And drips of water coming from the microphone and map light when turning L or R.
So I've read the thread and understand the problem of clogged drain plugs.
The question is, WHY? When the sunroof is closed, isn't this a closed system??
It's at the dealer ….
      02-08-2022, 11:53 PM   #10
MX330I
Drives: G01 X3 30i xDrive
2018 G01 X3 30i  [0.00]
Had that too. Dealer said the car was parked at a wrong angle
      02-09-2022, 02:58 AM   #11
Dandle
Drives: G05 X5 M50i
Does anyone know where the rear drains actually drain out. I've cleaned the front drains on my car but cant find the rear ones.
      02-24-2024, 01:47 PM   #12
Danyelmathers
Drives: Bmw X3 Xdrive2.0i 2018
Clogging sun roof drain
Hi chaps,
I've just bought my X3 xdriver2.0i December 2018 registered.
Love it. However:
I have this issues that you guys mentioned.
I took the car to get cameras fitted by someone and he told me that my passager side footwell is well soaked.
I took the seat out and trims and it's all soaking wet. Only on passager.
I've opened up the sunroof and poured all at once a 500ml bottle of water, and I saw water dripping from the trim down by the windscreen and also a bit wet by the microphone on the passager side.
I took that trim out but unfortunately the drain is thru the chassis of the vehicle. So tomorrow I'll try and unclog it somehow.
Hopefully I'll sort it...
      02-26-2024, 07:50 PM   #13
Danyelmathers
Originally Posted by Danyelmathers View Post
Hi chaps,
Love it. However:
UPDATE ON THIS.
TODAY I FOUND OUT 2 THINGS.
1 small glass back seal has shrunk, not enough to leak water yet.
2 and the most important thing:
THE SEAL THAT IS BETWEEN THE WINDSCREN AND THE ROOF OF THE VEHICLE HAS GOT A BIT DETACHED, MAKING THIS A NIGHTMARE.
I've attached some pictures for reference of how the seals are on my car and how it should be.
