BMW 3-Series (E90 E92) Forum
CIC retrofit on non I-drive
12-04-2017, 09:59 AM | #1 |
Rep 9,209
I'm trying to figure out the AUX for the CIC retrofit on non Idrive 2008 e90.
Original AUX has 3 wires: ground, left and right channel CIC AUX has 6 wires. My question is: do I need to run new harness from AUX to CIC or I can just re-pin the 6 pin connector with the 3 wires that I have. Any input will be much appreciated. See photos for reference: Last edited by feuer; 12-14-2017 at 03:44 PM.. |
12-04-2017, 12:43 PM | #2 |
Rep 2,139
Drives: 2009 e92 335i MSport DCT
I was lucky that I already had USB and Aux in my console so didn’t have to do this part.
Can someone who has done this please chime in ? I believe that the CCC has aux that goes to the CCC but CIC it goes to the trunk to the MULF or combox unit. Aux audio goes from console to trunk via wiring and then from the MULF or combox via MOST fibre loop. |
feuer4277.00 |
12-04-2017, 12:52 PM | #3 |
Rep 9,209
I believe that 3 wires go to CIC and 3 wires go to Combox but need to confirm. I also think that CIC can be coded to receive AUX only from center console but need to confirm that as well.
12-04-2017, 09:47 PM | #4 |
Rep 202
I've read a lot of different things. 6FL and various configurations which include the USB hub and those that don't make this a complicated one, unfortunately I can't cast any light on this. I actually need to tap the Aux line myself, for a permanent wire which needs Aux access, hopefully that is possible. Checking the WDS may cast some light on the matter.
feuer4277.00 |
12-04-2017, 11:58 PM | #5 |
Rep 2,768
you can simply wire only 3 wires to HU, but if you have mulf2high or combox then better route aux to them
second 3 wires used in 6NF cradle for routing audio from phone in cradle
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
feuer4277.00 |
12-06-2017, 07:22 AM | #8 |
Rep 9,209
Ich schätze es! I have a small issue. After changine VO (I added #0910, $6VA and $609) I have sound, bluetooth works too. Adding #0909 didn't get me sound. CIC is from 2012 e92, last ever made e92. Some other settings got all crazy, mostly lights but the actual issue is that I found the CIC is update C08. I was told has to be C1A for pather to work. Any suggestions?
12-07-2017, 02:54 AM | #9 | |
Rep 207
Yes, you need to bring the CIC up to the last latest level, C1A.
I think you might have a problem with the daten here. Normally for the E9x series, there is no major benefit in using the latest daten ie V60, etc... Quote:
feuer4277.00 |
12-07-2017, 03:12 AM | #10 | ||
Rep 2,139
How to update CIC without ICOM http://www.e90post.com/forums/showthread.php?t=1401983
When you doppelkaplung you doppel your fun.
feuer4277.00 |
12-07-2017, 09:25 AM | #11 | ||
Rep 9,209
12-08-2017, 07:43 AM | #12 |
Rep 9,209
I was coding the CIC yesterday and notice it says CIC C1A in NCS. Does this mean I got lucky?
12-08-2017, 02:00 PM | #14 |
Rep 9,209
I think ZIF reading is avaible with INPA as well. Finding free FSTool seems almost impossible. Any suggestions there?
12-09-2017, 06:05 AM | #15 |
Rep 207
Yes, of course. Go here for the FSTOOL:
https://mega.nz/#!w3wyCBgQ!U_XFe2y1F...plAv_EhKLPhkpw I forgot to mention: JAVA runtime 1.4.2 will only work with FSTOOLS. You need EDIABAS 7.3.x Last edited by anees; 12-09-2017 at 06:11 AM.. Reason: some more info added |
Aus335iguy650.00 feuer4277.00 |
12-10-2017, 01:55 PM | #16 |
Rep 9,209
12-14-2017, 02:58 PM | #17 |
Rep 207
feuer ,
download this carserver folder: https://mega.nz/#!gpUxRJ7Q!7KVm_-ImJ...uBebPik91Kskks and copy it / overwrite your c:\ec-apps\carserver with this download. I think the daten files might not be correct. |
feuer4277.00 |
12-14-2017, 03:16 PM | #18 |
Rep 9,209
I'm not sure. You will need to take a look tomorrow. I can't load 1B now. Says invalid creation date. I'm clueless of what happened in FSTool. This is what I get with Get Status:
FCS rejected FCS Cert Status accepted SIG Cert Status accepted SW Signature Status accepted |
