10-18-2020, 05:34 PM | #243 |
Rep 6,589
Private test day at Bandimere Speedway. Max Well FYI
__________________________________________________ ________ Pressures: Front 27, Rear 27 (Conti's) Spare and tools out 10 gallons of 100 (Sunoco GT), 4 miles on the clock of 91 (less than 1 gallon): let's call it 99 octane Sunroof No Tune Cold as heck this morning and throughout the day, high 30's into the 40's. Track elevation 5800' DA ranged from 5200' to 6800' from what I saw throughout the day. __________________________________________________ ________ Slips below: First 10 are my drag runs, 6th run was my best (and check out the Dragy screenshot). If anyone questions if Dragy isn't spot on, this should settle that. Near dead on. Last 2 runs were roll races, just figured I'd include them here. |
10-19-2020, 07:03 AM | #244 | |
Rep 2,531
I'm attaching your full logbook of 21 runs for documentation, but as can be seen, it gets cumbersome to view. So I'm planning on attaching only the top 8 for everyone as their logbook grows as it'll make viewing and analysis easier (also attached). I'd also like to leave it up to each Driver as to which run they wish to have in their Group's Leaderboard. Instinctively, it seems that everybody will choose the fastest ET, but some may actually wish to have their best performance run shown instead (which isn't necessarily always the fastest ET given maybe a slower 0-60' takeoff). Example - a strong argument could be given to placing forza1976's round 777 which clearly shows the strongest performance across the board, rather than round 185 which had the fastest ET but slower trap speed and interval times. |
forza19763398.00 |
10-19-2020, 09:15 AM | #245 | |
Rep 6,589
Max Well4734.50 |
10-19-2020, 10:55 AM | #246 | |
Rep 2,531
I saw your Dragy comparison - it captures ET and trap speed really well. Last year I did a comparison of my runs which I shared here: https://x3.xbimmers.com/forums/showp...7&postcount=68 Interestingly, it didn't capture the slope as well, at least for my small study, which I shared here: https://x3.xbimmers.com/forums/showp...7&postcount=46 The latter is why don't view Dragy results as reference (as a sanctioned Drag Strip can be inferred to have a reasonably level and consistent surface which allows apples-apples comparison). That, and it also provides date, time, and location to allow others to confirm the reported DA. But it is an excellent tool for those tuning and wishing to see results without having to wait for a track day. |
10-29-2020, 09:50 AM | #248 |
Satin black X3M Competition
114
Rep 36
Shearing my Draggy results, did a run few days ago with humidity around 75% temp 78F . First time to launch the car.
2020 X3MC, 21" Conti Moon roof no spare tire, stock tire pressure, running Bootmod3 OTS E30 with 91 octane just under half tank. Note: the down slope shown in the slip is not noticeable in the street. [IMG][/IMG]
Bootmod3 OTS Stage1 E30
10.75@127.86 |
Max Well4734.50 |
10-30-2020, 04:46 PM | #249 | |
Rep 2,531
10-30-2020, 05:30 PM | #250 | ||||
114
Rep 36
10.75@127.86 |
11-01-2020, 06:45 AM | #251 | |
Rep 2,531
Last edited by Max Well; 11-01-2020 at 07:00 AM.. Reason: Forgot to add Track altitude as needed for DA calc |
11-01-2020, 05:01 PM | #252 | ||
114
Rep 36
10.75@127.86 |
11-02-2020, 05:02 PM | #253 |
Rep 2,531
Curious what you're aiming for on the tire psi. I'm still looking at 4-5 weeks before I can get back out to the Strip, but I'm thinking I may skip over the 33F/32R and just go straight to 33F/30R. Given the estimated tire patch study I did, it seems 33F/29-30R should be pretty well balanced, at least static (which we know goes out the window at launch).
11-03-2020, 06:07 AM | #254 | |
114
Rep 36
10.75@127.86 |
11-04-2020, 06:16 AM | #255 | |
Rep 2,531
I would think if DA is good and with 100 octane on board, <11.6s should be possible. |
11-04-2020, 01:44 PM | #256 | ||
114
Rep 36
I managed to run 5 runs some were with launch control others were without. I started with tires setup of 33F/30R and this was the part that I didn't expect the track with n here is well prepared and the grip crazy so here is what happened. First run was without LC and tires were 33F/30R and the car did 11.6@123.81. Looking at the draggy graph there was a big drop in the acceleration. So I decided to go for another run with LC. Second run I had same tire setup and activated the LC and managed to get 11.44@123.52. Looking at the draggy graph again the drop in the acceleration is still there so I decided to adjust the tire pressure and to increase is installed. To 35F/33R. Third run I managed to get 11.16@124.57, and noticed that the drop is still there but it was slightly better. So I decided to increase the tire pressure again to 38F/38R Forth run unfortunately is didn't launch the car is was destructed with the other car so it was 11.4@124.65. Fifth run 11.26@124.08. And I decided to call it a day as tomorrow will be the qualifying. [IMG][/IMG] In the way home a came to a spot were I wanted to check the car in the street again and managed to get 10.93 on full tank with 38F/38R and 60" of 1.7 there was no drop in the acceleration graph! So I guess the prepared surface of the track is so good to a point it slowed the car by effecting the acceleration big time. Tomorrow plan will be to increase the air pressure to 42F/42R and give it a try 😅.
10.75@127.86 Last edited by FastPanther; 11-06-2020 at 08:41 AM.. |
forza19763398.00 |
11-05-2020, 11:43 AM | #257 | |
Rep 2,531
Thanks for contributing, FastPanther [EDIT NOTE: in a PM from FastPanther just a bit ago (0938AM, 6 Nov 2020), he indicated that even though the slips state 'AM', all runs start at 5'PM', so I'm going to have to go back and re-calculate the DA information for this data series, so would disregard this image. Also note he updated the images so the times are much clearer now, and the corrected data will be included in a post later today, 6 Nov 2020.] Last edited by Max Well; 11-06-2020 at 12:22 PM.. Reason: FastPanther indicates in a private msg that all times actually PM, not AM |
forza19763398.00 |
11-05-2020, 02:19 PM | #258 | |
Rep 6,589
I need to move!!! |
Max Well4734.50 |
11-05-2020, 02:41 PM | #259 | ||
114
Rep 36
I have added more tire pressure for tomorrow as it will be the final. [IMG][/IMG]
10.75@127.86 |
11-05-2020, 04:29 PM | #260 | |
Rep 1,219
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance 10.84@127.43 / +1912 DA NH Dragway | 10.6@130 Dragy / +820 DA The Streets | NOW: Tesla Model Y Performance |
11-06-2020, 08:17 AM | #261 | |
Rep 2,531
On closer analysis your interval times don't make sense for run 992 from 2 days ago, and I suspect it is mainly the 330' time as the 60'-330' is too fast and the 330'-660' is too slow. So need you to share another photo with clearer data points (I had PM'd you regarding this). If you just edit your post and delete that image of all five slips and share a clearer version of them I can take it from there. Either that, or clarify in a post what those numbers actually are. (Even at 400% mag I couldn't tell some of the numbers) Are your races head-head first across, or is it based on times? And curious if you used LC? Just wondering as your R/T from yesterday was only 0.406s, not the >2.0s of your other LC runs from the day before? Still with DSC off? [EDIT NOTE: in a PM from FastPanther just a bit ago (0938AM, 6 Nov 2020), he indicated that even though the slips state 'AM', all runs start at 5'PM', so I'm going to have to go back and re-calculate the DA information for this data series, so would disregard this image. Also note he updated the images so the times are much clearer now, and the corrected data will be included in a post later today, 6 Nov 2020.] Last edited by Max Well; 11-06-2020 at 12:24 PM.. Reason: Private msg from FastPanther indicated times are PM, not AM as states on the slips so re-calculation needed |
11-06-2020, 09:49 AM | #262 | ||
114
Rep 36
DSC off/ M xDrive 4WD/Engine Sport plus/ chassis Sport/ Steering Sport plus / transmission S3. Tire pressure is set to 55 PSI all around.
10.75@127.86 |
11-06-2020, 01:14 PM | #263 |
Rep 2,531
Much clearer images, FastPanther - thanks for sharing as it did change a fair number of times (in light yellow highlight). Also, appreciate your private msg indicating the times are all actually PM, not AM as the slips indicate. Thankfully, as your region appears remarkably stable through time with its atmospherics, the DA remains pretty much stable through the 3 hours of slips.
I'll add you to the St1 Board once I know you've finished submitting slips and when your fastest time can be discerned. |
