BMW 5-Series (G30) Forum Cosmetic Modifications IND Reflectors Rear
      09-30-2017, 01:22 PM   #1
12F10HOUSTON
Drives: 2012 528i
Fellas to save you from butchering your rear diffusers please see my photos and use this approach vs the F10 approach to removing your reflectors. It is easier to pop out the diffuser to access the reflector.
clee1982797.50
540iSUP704.00
      10-05-2017, 04:58 AM   #2
mobilejo
mobilejo's Avatar
Drives: G06 X6 40i
Thats helpful thanks - can you explain how you pop out the diffuser? is it just pull & pray?
      10-09-2017, 05:32 PM   #3
12F10HOUSTON
Drives: 2012 528i
Pretty much, LOL It came out when I pulled on the old reflector. I think if you look at where the clips are based on my picture likely you could pop it out easier.
      10-29-2017, 06:13 AM   #4
PurpleSector
2018 530i
25
Drives: G30
excellent. I'm going to try this and pop that ugly thing out to paint it or wrap the whole thing in carbon fiber.
Just one question, no tools needed right, just pull it out? any tabs/clips I should watch out for (prone to break)?
      03-17-2019, 05:22 PM   #5
crl125
crl125's Avatar
Drives: BMW G30
I spent a good hour this afternoon trying to remove the rear reflector/disconnect the rear diffuser with no luck on either. Anyone have any suggestions to get this DYI complete?
_____________________________________
'19 G30 M Sport /// Carbon Black
'19 G05 /// Mineral White
'14 F10 M Sport /// Carbon Black
      03-17-2019, 07:38 PM   #6
HomeIn2
HomeIn2's Avatar
Drives: 2020 X5 M50i
The rear bumper trim is quite easy to remove if you first remover the 5 or so screws near the edge. Once they are remove the trim snaps out without too much effort. Just start on one end and work your way around. When the trim is off, you can easily unclip and remove the factory rear reflectors. The painted ones just snap in. With the painted reflectors in place, you just snap the bumper trim back in place working your way all around. Replace the screws and you are done.
540iSUP704.00
      03-18-2019, 09:39 AM   #7
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
Good tip!
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      04-16-2019, 09:08 AM   #8
Kolyasin
Drives: BMW G30 530D
Hi,
Could you tell us paint code to match the color on the diffuser?
5post
