05-06-2017, 04:59 PM | #1 |
Rep 84
Different hubs or wheel bearings between F25 years?
Hi all, hoping some of you might know and would be willing to help me figure this out.
I currently have a 2011 F25 X3 28i xDrive with style 306 17" wheels. I recently bought a set of remanufactured style 307 18" wheels with part number 36116787578. For some reason these will not sit flush with the hub and it looks like it would only fit if bored out. Very strange. Does anyone know if there were different hubs or wheel bearings between different F25 models that would require specific wheel style combinations? As far as I know all F25's have the same bore size on the hub. On RealOEM I can see style 307 has two part numbers, 36116867131 and 36116787578. As far as I can tell they are the same except for color, one black the other silver. Does anyone out there know what is going on? Thanks in advance. |
05-07-2017, 02:24 AM | #2 | |
Rep 619
make sure you Hub as well as the wheel hub cavity are properly cleaned before installation. 33406867815 Drive flange hub From:11/01/2014To:-Weight:2.220 kgPrice: Supersedes: 33406786999 (09/01/2010 — 01/14/2015) Part 33406867815 was found on the following vehicles: X3 F25 (06/2009 — 04/2017) X4 F26 (05/2013 — 04/2017) |
MonkeyHermit8.00 |
05-07-2017, 03:41 PM | #3 | ||
Rep 84
05-08-2017, 01:35 AM | #4 | |
Rep 619
05-08-2017, 08:39 AM | #6 |
Rep 84
Thanks. I wish I had known this earlier as Costco told me they could not install the wheels because they would not fit. I'm pretty sure they did not try clearing off the rust from the hub. At that point I was so confused and frustrated.
FSociety3859.00 |
05-08-2017, 01:30 PM | #7 | |
Rep 494
05-08-2017, 02:56 PM | #8 | ||
Rep 84
05-09-2017, 09:19 AM | #9 | |
Rep 494
05-09-2017, 07:42 PM | #10 | ||
Rep 84
