BMW 3-Series (E90 E92) Forum
Hotchkis Sport Anti Roll Bars for E90 E92 335i except xi Ready to ship!
04-10-2008, 12:58 PM | #1 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
The Hotchkis Anti Roll or Sway Bars are in stock and ready to ship!
Retail is $495.95 Special is $450 with FREE shipping to the 48 states! Application: 2006 – 2008 BMW E90 Sedan & E92 Coupe ( xi models excluded) Enhance the cornering performance of your BMW with a set of Hotchkis Sport Suspension sport sway bars. Our 335I sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the 335I has excessive under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greaseable bushings, and adjustable Heim joint end links. Features: Front sway bar-lightweight, durable 1 1/4” (32mm) tubular steel (95% stiffer than stock) Rear sway bar-lightweight, durable 5/8” (16mm) tubular steel (105% stiffer than stock) Precision adjustable front end links w quiet operating heavy duty ball joints. Precision adjustable rear end links w quiet operating heavy duty ball joints and high articulation rod ends. Greasable polyurethane bushings and heavy duty mounts included. Autocross & track tuned for maximum performance improvement. Finished in durable gloss gray powder coat. Benefits: Increased Traction. Reduced Body Roll Increased Vehicle Stability Crisper Cornering Easy Installation Last edited by HP Autosport; 11-11-2008 at 12:07 AM.. |
04-10-2008, 03:03 PM | #2 |
Rep 16,214
Drives: 2011 E92 M3
have you had this on your car? if so please gime a personal opinion. how good are they? any relations to titanmotorsport cause it seems like you guys have the same pricing? what makes HP better than titan cause the prices seem the same. im not bashing. just curious.
stock car
04-10-2008, 03:25 PM | #3 | |
3847
Rep 54,376
Drives: F80 M3
Every car will respond differently to anti roll bars and each person has his/her preference on handling. The anti roll bar is on our project 335i with TC Kline Coil-over suspension with 400 lbs front and 500 lbs rear springs, camber plates and a Quaife differentail. Understeer and body-roll is reduced, and vehicle is more responsive. Basically, the same benefits Hotchkis has mentioned. Harold |
04-10-2008, 03:26 PM | #4 |
Rep 16,214
Drives: 2011 E92 M3
i love your project car! i thought these were called hotchicks sways bars.
stock car
04-10-2008, 03:27 PM | #5 | |
Rep 8,091
I highly recommend doing business with them |
04-10-2008, 03:29 PM | #6 | |
Smiling Politely
1381
Rep 29,118
oooooo...me want
04-10-2008, 06:38 PM | #7 |
3847
Rep 54,376
Drives: F80 M3
04-10-2008, 06:38 PM | #8 |
3847
Rep 54,376
Drives: F80 M3
04-14-2008, 12:39 PM | #10 |
3847
Rep 54,376
Drives: F80 M3
04-14-2008, 12:49 PM | #11 |
Rep 5,780
Thanks, I haven't climbed under the rear of the car (been under the front more than a few times ) to look at what is involved. Any hints or tips and does the kit include any instructions as they are not listed on Hotchkis's website?
Thanks again... |
04-14-2008, 12:58 PM | #12 |
"I know you know that I know you know..."
24
Rep 795
Drives: Sparkling Graphite E90 328i
Just wondering... how do these compare with the H&R Sway Bars that were released a long time ago?
04-14-2008, 03:19 PM | #13 | |
3847
Rep 54,376
Drives: F80 M3
The Hotchkis anti-roll bars are hollow, so if weight is a concern they are lighter. The bushings have zerk fitting for re-lubrication, so you dont haveto remore anything when the bushings get noisy. |
04-17-2008, 12:45 PM | #14 |
Moderator
618
Rep 10,855
The balance btw front and rear sway resistance is different. The H&R rear bar is big, resulting in inside wheel lift and loss of traction. The Hotchkis system, particularly in combination with the Bilstein PSS9/10 coilovers and a LSD, will provide better control, traction, and turn-in. Camber plates and strut braces complete the picture (assuming you already have forged lightweight wheels and proper non-rft tires)...
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
04-17-2008, 12:47 PM | #15 |
Moderator
618
Rep 10,855
Harold I have not seen stats on the weight of the Hotchkis vs. stock bars. Any chance you guys could weigh them?
Thanks!
04-17-2008, 04:51 PM | #16 |
3847
Rep 54,376
Drives: F80 M3
04-17-2008, 05:24 PM | #17 |
Rep 16,214
Drives: 2011 E92 M3
pm please!
stock car
04-22-2008, 11:12 AM | #20 |
3847
Rep 54,376
Drives: F80 M3
04-22-2008, 11:37 PM | #21 |
Moderator
618
Rep 10,855
I am psyched about these, they look great. Waiting on someone to test them out for us!
04-24-2008, 12:20 AM | #22 |
MMA Changed My Life!
317
Rep 6,629
Drives: e92 m3 & f30 328i
please pm me price shipped to 92833 thanks
