12-02-2016, 12:36 PM | #1 |
Rep 3
Carly for BMW WiFi OBD 2 and Carly Pro App
Hi guys!
New here. Anyone tried this Carly scanner OBD 2 and the Carly Pro App? First use would be in replacing my OEM battery with an aftermarket (after 5 years) and registering the aftermarket battery using the Carly Pro app. Also, what's the best aftermarket battery can you people suggest? X3 is 2011 F25 xDrive 28i. Thank you! |
12-02-2016, 10:46 PM | #2 |
Rep 456
I've been using the Carly app since my e92 with much success. The app makes coding easy and being able to read and reset obd codes is terrific as well.
I'm not 100% sure that the battery registration option is available for the F25 yet. I haven't looked recently so I'm not positive but I know it wasn't an option the last time I used the app. So double check first if that's your primary reason for getting it.
Instagram: @dasianoak
08-07-2017, 09:10 PM | #4 |
Father of Frankenfold
297
Rep 532
Drives: Yo daddy's 2014 X3 M Sport
I have Carly and a coding cable and app. Carly pales in comparison. It's nice for quick, easy, simple changes, but the options are very limited in comparison to full coding capabilities.
That said, I coded 90% of what my wife wanted done in her X1 with Carly. Carly was only capable of maybe 50% of the coding I did to my X3. As for batteries, I've always liked the Odyssey batteries. If I had to replace mine today I'd probably get a Odyssey PC1350.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
10-24-2017, 06:05 PM | #6 | |
Rep 71
I started doing some coding with Carly the other night. Kind of annoyed I have to pay extra to code out the disclaimer. Also, I've disabled all of the available light bulb voltage checks (I have LED's in most) but I'm still getting warnings about the parking lights being out. Was really hoping to stop the warnings completely, not sure what the issue is there and haven't been able to find anything on it through Google searches. |
10-25-2017, 10:47 AM | #7 |
Rep 11,880
Drives: MY24 G01 AW Msport
bimmercode app is better with Vgate wifi adapter.
i coded bunch of things without errors. |
10-27-2017, 11:05 AM | #8 |
IG @bmwF9xG80
3856
Rep 7,614
Did you code your Camera to work at any speed?
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
10-27-2017, 11:08 AM | #9 |
Rep 11,880
i dont think i did that.
i took off disclaimer message, added //M to welcome navi screen, 100% angel eye , turned on rear taillight for drl, open/close trunk via remote and for windows and sunroof, added turning signal on headup display ..probably few other things i cant remember |
FSociety3856.00 |
10-30-2017, 01:04 PM | #10 | |
Rep 4
Other than taking a couple tries to get Bimmercode to connect to the Vgate, coding worked like a charm. BTW, was in contact with the developer, who told me Expert Mode will be avail on the Android version in about two weeks. |
nyalpine907415.00 |
10-31-2017, 03:26 PM | #11 | |
Rep 2,808
Am I understanding correctly that the app itself is free, so your cost is just the Vgate Adapter, which is like $20? App: https://itunes.apple.com/us/app/bimm...130787459?mt=8 |
nyalpine907415.00 |
11-01-2017, 06:47 AM | #12 | |
Rep 11,880
its very simple to use. |
11-01-2017, 11:30 AM | #13 | |
Rep 2,808
I know full blown coding cable with software does a lot more, but I thought Carly was currently the king of the coding apps? What more can it do? |
11-02-2017, 06:17 AM | #14 | |
Rep 11,880
but with the app is simple. |
01-16-2018, 06:52 PM | #15 |
General of the Space Forces
179
Rep 729
Just got Bimmercode and coded most of what I want, really like that I was able to put the media info and phone info into the HUD! Havent tapped into the expert mode yet to see what else I can do that I cant do in the standard mode.
Is there a list anywhere comparing standard to expert mode for Bimmercode? |
01-17-2018, 08:40 AM | #16 |
Rep 288
I have both Bimmercode and Carly. Carly has more coding features than Bimmercode at this time. Purchased Carly for the battery registration feature to register my new battery. Bimmercode has a better interface and quicker than Carly. I don't mind Carly being a little slower but again more features than Bimmercode. Great thing about Bimmercode is the Expertmode feature. I hope Carly can add this feature in future updates. Carly tends to provide updates every month with new features. Bimmercode provides bug fixes each month so far with no new features at this time. Both apps were more convenient than setting up my laptop/esys.
As far as replacement battery... I replaced my oem 90ah battery with Advanced Auto 110ah AGM battery for $156 with discount/coupons. It was bigger in length than the oem but easily installed by moving the battery tie down bracket to accommodate the length. I was able to registered the new battery with Carly with no problems. Hope this helps. |
01-18-2018, 10:45 AM | #17 |
Rep 818
I use Carly on my X3. I used it on my E90 as well but the ebay adapter didn't work and had to spend the $$$ for the official one. No issues. Got rid of things like seat belt warnings and seatbelt light on dash, warning screens on I drive, play DVDs when moving, fold mirrors with key, close hatch with key, cameras on at any speed, engine start/stop defaults to "off" so it's never on unless you goto ECO mode, windows continue to work with doors open and engine off, and my all time favorite for every BMW: digital speed display on dash.
I'm sure I'm missing things. Last edited by Riick; 01-18-2018 at 03:19 PM.. |
01-19-2018, 09:22 AM | #18 | |
179
Rep 729
01-23-2018, 06:45 AM | #19 |
Nuclear Chief of the Watch
122
Rep 637
Got the Carly BT Adaptor2 - have used it on my X3, i3 & daughters Mini.
Really easy to use, a bit slow but thats not an issue. Done the few niggles I wanted sorting and lest then £100 total so well pleased.... Happy to help anyone local to Plymouth UK too. Have coded mirror to auto fold on locking and added a confirmation beeb. (on X3 & i3) Also made the tailgate shut from driver door switch. Done a few other minor ones too.
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats Canon 70D 500mm, 85mm, 40mm, 24mm Sony QX10 & GoPro Hero 3 Last edited by plymjack; 02-01-2018 at 10:59 AM.. Reason: added list of works done |
03-15-2018, 02:23 PM | #20 |
Rep 13
Hi. Just bought a 2012 X3. Previously had an Audi with a large digital speed display and I miss it. Understand I can get something similar albeit small digits with the BimmerCode app.
What hardware do I need (cable / adaptor)? I have iPad, android phone and windows laptop so plenty options. Also got a fleabay OBD2 WiFi jobby somewhere if that can be used ? |
03-18-2018, 09:22 PM | #21 |
Rep 679
03-18-2018, 10:23 PM | #22 |
Rep 41
Drives: car
