      06-03-2016, 04:33 PM   #1
dgilson
Drives: X3 20d xDrive SE Auto
Sticking windows
Anyone else having a problem with sticking windows? My X3 is five years old. First thing in the morning, the windows open with a horrible audible jerk. Subsequent closing and opening is fine, it’s just that initial opening. It sounds and feels as though the glass is sticking to the rubber channels.
I’ve even had the odd occasion when a window refused to open at all. All four windows are affected.
I’ve tried lubricating the channels with various materials - soap, washing up liquid, silicone spray, even the famous Gummi Pflege. The latter seemed to help a bit, but not much.
When I asked BMW Service, they didn’t recognise the problem. Searching this forum and Google, hasn’t revealed anything useful. Presumably my next move is to look at the mechanism inside the door. First have to figure out how to get the trim off without doing any damage.
Any constructive suggestions would be appreciated.
      06-03-2016, 06:07 PM   #2
BMWZ4
BMWZ4's Avatar
1924
Drives: '23 X1/'23 Allroad Progressiv
I had an '11 as well and had this issue with the driver's window. Brought it in under warranty and they replaced a control module - I fact if I recall correctly it was a Technical Service Bulletin (TSB).
      06-03-2016, 07:28 PM   #3
mge92
SPEED RACER
mge92's Avatar
Drives: BMW X5 M50d BMW M2 CS
Try resetting the window motors.
Push down all the way and hold for 10 secs. Release.
Pull up all the way and hold for 10 secs then release.
Hope that helps.
2019 BMW X5 M50d Artic Grey | 2020 BMW M2 CS Misano Blue
Incoming - Ginetta G56 GT Academy | Incoming - BMW X5M Comp Oxford Green
RIP - 2020 Mini JCW GP Racing Grey | RIP - 2013 X3 xDrive28i Carbon Black
      06-12-2016, 02:00 PM   #4
dgilson
Thanks for the replies, gents.
BMWZ4: Presumably the module they replaced was the footwell module (FRM) which handles all 4 window switches in the drivers door, (according to BMW Training Manual). But if I understand it right, the window switches in the rear doors are routed via a different module, the junction box electronics (JBE). Since all my window switches are afflicted in the same way, it seems unlikely that my problem is a module problem - I think!
mge92: I tried your reset procedure, but sadly it made no difference.
Will post again if I ever find a solution.
      06-12-2016, 03:24 PM   #5
Tjalle
Drives: X4 35i
Cornwall? Rain? Salt spray? Whisky?
Since lubricating upper parts of guides/channels is a nogo, there are two options left:
- lubricating lower parts= remove doortrim
-corroded mechanism = remove doortrim
I am afraid that removing trim is not easy - risk for damage on panels. Any local shop that has half the rate of the BMW dealer? Most know the tricks and has the tools.
      06-12-2016, 03:25 PM   #6
Greg2010
Greg2010's Avatar
Drives: 2020 X1 sDrive28i
I had the same issue a few months ago....drivers window only, when lowering it in the morning (and then it tended to subside after raising it back up and lowering it again).
So I brought it into the stealership, who said they found/cleared out debris in the window track (which accumulates over time) and according the the SA, it was all fixed. Then the next morning, as I lowered the drivers side window, I had the same problem (and videoed it this time).
However, over the next couple days, the screeching sound was less than before, and as I was planning to return it back to the stealership...the problem magically went away (and it has not screeched for the past month).
Op, not sure what to tell you, but It sounds like I experienced the same problem and if it reoccurs, I will let you know what I find out.
2020 X1 sDrive28i l Xline l Luxury l Harman Kardon l Wireless l Parking Assist l Sliding/ Reclining Rear Seat
SOLD - 2013 X3 35i l BSM l MSport l DHP l Premium l Sound l Tech l CW/CWII l Apps l 35% Tint
SOLD - 2010 E92 335 X-drive l BSM l MSport l Steptronic l Premium l CW l Logic 7 l Confort l Nav l KW-V1s l 35% Tint
      06-13-2016, 12:30 AM   #7
Tjalle
Drives: X4 35i
I am curious: how come you are operating sidewindows that often - I rarely do, although most times parked in garage.
      06-14-2016, 06:56 PM   #8
Greg2010
Greg2010's Avatar
...a bit off topic, but the entrance to the garage at work requires me to lower the window.
      06-14-2016, 09:20 PM   #9
west1
Drives: 2017 M2 6MT
yes, same problem and it's annoying. any solid resolutions or recommendations?
i have years experience replacing BMW window limiters so I'd be comfortable taking this door apart if there's a fix to be had.
