04-09-2016, 08:16 AM | #1 |
Rep 2,099
First repair on my M40i under warranty
The car had a boost leak at the charge pipe to the intercooler on the turbo side and it was repaired yesterday at the dealer.
The symptoms were a check engine light, I got a drivetrain malfunction error once that went away by simply restarting the car, rough idle, less power and a bit of lag in the throttle. The most obvious symptom though was that under load, with the windows down, you could hear a rush of air accompanied by an annoying whine (like say the supercharger whine of a hellcat just not as loud) and you could hear the whine even with the radio on although barely under the slightest of loads. After googling a bit, I figured that it was a boost leak, but since it did not produce the rush of air when revving with the car parked, I could not identify where the leak was. I suspected that the wastegate was not closing, but could not verify my hunch because of how tight everything is in the engine bay. I was wrong about the wastegate but it was still a boost leak. The tech said that it was likely incorrectly installed at the factory, either it was not sealed properly or the pipe was kinked causing a restriction and with too much pressure on one side, the seal gave out. In any case, I am happy to have it repaired and now the car feels right. I also swapped the tires to the 20" wheels and PSS tires, and I must say that the ride is noticeably more stiff. Not uncomfortable but definately not as plush as with the 18" winters on. GG |
04-09-2016, 10:13 AM | #2 | |
Rep 75
'05 RSX-Type S Pearl White 6MT GONE
'13 BMW 128i M-Sport Black 6MT GONE '04 Acura TSX Silver GONE '13 Mercedes Benz C-350 Opal Red GONE '16 BMW x4 M40i Carbon Black W/ Mocha INT Current! |
04-09-2016, 06:27 PM | #3 |
Rep 5,115
Charge pipe failed you say? Not uncommon. You can replace for a metal CP with a hugely improved collar/connection for about $350US from ER.
04-10-2016, 03:06 PM | #4 |
IG @bmwF9xG80
3859
Rep 7,614
ggalanis how many miles now? do you drive it in sport/sport+ often or spirited ?
So far 1650 miles on my M40i and I drive it very spirited due to that reason, harder break-in could help weak parts come out or make things seal harder
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
04-10-2016, 03:09 PM | #5 |
Rep 103
Wow that sucks, but I guess you want the problems to show up now rather than later. I took the 7yr extended warranty for that sole reason, sure it might be a waste of money if your car has no issues, but with my luck, best to have it. I intend to keep it around 8 years.
04-10-2016, 05:59 PM | #6 | |
Rep 2,099
With the family, 75% of my driving, I drive in comfort near home, sport on the expressways. When I am alone, 25% of the time, I drive in sport or sport+. I don't really consider my driving so far to be spirited since quite a bit of it was with winter roads... but it is going to start warming up now and that's going to change a bit. GG |
04-11-2016, 05:57 AM | #7 |
Rep 788
Hi ggalanis,
It seems the quality build & control in South Carolina is weak. I will give my car to service for the following problems: - Stolen X drive Logo after 5 days of owning it Of course in Italy (this has nothing to do with Quality Build & Control, I agree) - Steering Wheel not proprely aligned - Noise/sizzle/crackling coming from the Dashboard beetween 100-120km/h - Noise/whistle coming from front axle driver side The carbon gear shift I kept from my old X4 and asked to install in the new one, wasn't correctly installed. Now the gear shift is dislocating.. During the breakin period (1st time I did the breakin period with the radio off all time) I heard two times strange noises, like if the car was loosing pieces... So they will inspect and fix the car during 3 days. already 3'000 km done. |
