BMW 3-Series (E90 E92) Forum
Strange e91 taillight issue
02-20-2016, 12:13 AM | #1 |
Rep 5
Hello first post here. E91 noob so perhaps this has been covered before.
My inner drivers side taillight is out on the center bulb. Like a idiot I assumed it was a led and ordered a entire tail light replacement only to take it apart to find a bulb DOH! Anyway even after replacing the bulb, and the entire assembly I am still not getting light. At this point I would assume that it was a open or shorted wire. However here is the weird part. When I first turn the car on it lights up perfectly fine. It will stay on for about 15-20 seconds, then the lightbulb icon comes on the dash and it turns off. Tried 3 different bulbs with the same result. What could be causing this? It's almost as if the car is getting a error code and purposely cutting voltage to the lamp. I am stumped since the wire obviously has continuity, and is not shorted since it lights up perfectly for 15 seconds. Any ideas on where to look on trouble shooting this? |
02-20-2016, 02:19 AM | #3 | |
Rep 128
02-20-2016, 02:58 AM | #4 |
Rep 5
02-20-2016, 03:44 AM | #5 |
Rep 128
I don't know if you have the simple bordcomputer like I have or the the navigation with a screnn on the dashboard. If you have regular bordcomputer you have the bc button on left indicator arm. My English isent the best. I hope you understand.
