BMW 3-Series (E90 E92) Forum
Sending car to Indy shop for Trans problems. What do I say?
02-17-2016, 08:44 AM | #1 |
Rep 358
07 335i e92 AT 6 speed.
Past few months my car has had a transmission fault (4F8D or 4F86) all saying "5 after 4" so shifting from 5th to 4th usually downhill (4 times total). Temp is fine when it faults (according to INPA). I'm taking my car to an Indy BMW shop. What should I tell him to do? Fluid change? Check grommets? Check solenoids? I know there are a lot of DIY for random transmission things but I want the indy shop to do things without it costing me thousands of dollars. I know a lot of people say these transmissions are "bullet proof" but the guy I bought mine from said almost every other E9X he ends up buying has a trans problem (automatics only) and he has to send it to auction. (He buys trade-ins from two local BMW dealers). |
02-17-2016, 09:02 AM | #2 |
Rep 524
People say these transmissions are bullet proof? When my warranty was up and BMW was trying to sell me extended warranty I was told "if you had an automatic transmission I'd highly advise you get extended warranty because something will go wrong. But you have a manual so you should be fine"
I'd start with a fluid change. But realistically if you're going to bring it to an Indy, you pretty much should be relying on them to do what they think is best instead of doing what you think they should start on |
02-17-2016, 09:06 AM | #3 | ||
Rep 358
02-17-2016, 10:26 AM | #4 |
Rep 589
Check this thread: http://www.e90post.com/forums/showthread.php?t=1036295
02-17-2016, 12:43 PM | #5 | |
Rep 358
"Allow the vehicle to then coast to a stop" |
02-17-2016, 12:50 PM | #6 | |
Rep 3,696
Answer: say to the mechanic, "it's broken, fix it... I need it soon, here's money." done sorry I had to... it was just too easy 1) 6AT fluid flush (I like the redline fluid) 2) New pan and filter with new screws 3) replace the Mechatronic sleeve $12 part and no labor 4) Do the procedure to make sure the fluid is FULL 5) Reset the transmission 6) Get the Alpina flash if your 2007 can be allowed to have it. enjoy driving again |
02-17-2016, 01:06 PM | #7 | |
Rep 358
But I think I'll start with the things you mentioned here, unfortunately I can't flash my trans (because my bluetooth module is too old????) but I'll see if he can do the rest and whatever else he suggests that is not too costly. |
02-17-2016, 01:24 PM | #8 | |
Rep 589
But I'm not sure how helpful just doing the adaptation reset will be, I think really you need to update the transmission software. |
02-17-2016, 01:37 PM | #9 | |
Rep 3,696
I recently did that transmission service at my Indy at the 100k mile mark for my 6AT. It's not a crazy bill to be honest. The Mechatronic sleeve tends to leak by 70k miles so just expect that this will be a recurring service you should always do at this interval (My mechatronic sleeve was done under CPO at 75k miles but they wouldn't do the other stuff). Check out the parts here: https://www.ecstuning.com/BMW-E92-33...ce/Drivetrain/ The rest is whatever you work out on labor rates with your indy and if he is up to the job? The alpina flash can be done with a simple $20 coding cable (I don't recommend wireless) and a coding laptop with winkfp/ncs/inpa |
02-17-2016, 02:06 PM | #10 | ||
Rep 358
02-17-2016, 03:15 PM | #11 |
BMWCCA 149159
38
Rep 847
If you put redline in the AFT good luck. Regardless of what redline or any other ATF manufacturer states there are only two approved AFTs; Lifeguard 6 or Mercons SP. ZF transmission are pretty much bullet proof until you start to experiment and then wonder what happened.
Fluid change is prudent. Also solenoid replacement does happen as well but not super common. I would not get too excited and take this step by step with fluid change then reset adaptations. If that doesn't work move to the next step. Yes your transmission might be having an issue especially if it is a 19TU and not updates to a 21 which it should have been... |
02-17-2016, 03:45 PM | #12 | |
Rep 358
02-17-2016, 08:48 PM | #13 |
Rep 3,696
its hard to break out to a line item cost... i have a good relationship with my indy where he takes care of my cars at a great price and i just pay him whatever he asks as a cash tip... ymmv (i try to make good contacts with win/win situations). i did a lot of work all in one go and dropped a huge coin... this was just a small part of the maintanence i had done all at the same visit.
yea the cut off is some time with a march 2007 build date i think honestly... i tried the alpina flash... i went back to the oem stock flash and still have it. |
02-17-2016, 08:57 PM | #14 | |
Rep 3,696
Its hard to believe that i can only go to one reseller to get a product like transmission fluid for a mass market vehicle. We researched compatible fluids and called Redline who is not a fly by night company. I've been using redline in most of my vehicles over the past 20 years and no issues to date on any transmission... i still own every car i have ever bought... they all shift better than at day one with oem fluids (IMHO). FYI - I have this in my transmission right now: https://www.ecstuning.com/BMW-E92-33...rain/ES251177/ |
