BMW 3-Series (E90 E92) Forum
Killing car
02-16-2016, 07:14 PM | #1 |
///Kenney
118
Rep 796
Killing car
Hey everyone, I'm pretty sure my I drive is killing my vehicle. It won't start if left over night. My I drive recently went out a couple months back and haven't really looked into shop wanted around $1500 to replace and re code.
Is there a fuse I can pull? If so where and which one? Take the I drive CCc completly out since it's broken anyways? Also getting code p0456 ( fine emission system leak ) swapped gas caps from my 335i to my n52 and reset battery by popping up neg terminal and restarting car. Ses light did not go away.. If anyone has any idea on that let me know. Hooked up battery charger to car through bonnet and car isn't even making the clicking sound when trying to start? Any idea? Thanks all
2009 335i / sedan / silver & black / stock / 187's / sport and premium package - wife's ( purchased 09/01/2015 )
2006 330xi / sedan / black and saddle brown / sport, cold weather & premium / stock - mine! ( purchased 04/01/2014 ) |
02-16-2016, 08:18 PM | #2 |
///Kenney
118
Rep 796
I drive is broke and it's killing my battery. I just want to unplug it or take the fuse out that's running it any help?
02-16-2016, 09:08 PM | #3 |
Rep 807
Drives: 2011 335is 6MT
Can you give a little more description?
What does "my I drive went out" mean? Specifically? Can you tell us the part numbers from the quote? What is your battery charge currently showing? There are several different fuses for the idrive radio and its controllers and its modules. |
02-16-2016, 09:17 PM | #4 | |
///Kenney
118
Rep 796
He didn't print out the quote so not sure on part number. But it's the CCc I need. It sounds like a disk is spinning freely even when the car is shut off. My mechanic said the car isn't going to sleep via the I drive so I'm just trying to figure out how to dis connect the whole thing.
02-16-2016, 09:18 PM | #5 |
///Kenney
118
Rep 796
Battery is currently showing 12.3 volts but dies quickly cause the I drive isn't sending the car to sleep. Alternator is good ect. I wake in the morning to a completely dead car.
02-16-2016, 09:29 PM | #6 |
Rep 807
May have a couple posts here as I find them.
Have you tried a CCC reset: Simultaneously press and hold eject buttons on DVD or CD Player and iDrive Ccontroller for approximately 10 seconds. |
02-16-2016, 09:30 PM | #7 |
///Kenney
118
Rep 796
Yes I tried that nothing happeneds. Thanks for reply
02-16-2016, 09:34 PM | #8 |
Rep 807
Fuse F56 (20A) in the Junction box is described as "CCC/M-ASK" not sure everything it controls.
You know where the junction box and the fuse diagram are in the back of the glovebox, right? |
02-16-2016, 09:37 PM | #9 |
Rep 807
After checking, I think M-ASK is just the control panel in non CCC cars. Try that for now.
02-16-2016, 09:41 PM | #10 |
///Kenney
118
Rep 796
So try pulling fuse f56? (20a)
02-16-2016, 09:41 PM | #11 |
Rep 807
Yes
02-16-2016, 09:52 PM | #12 |
6 of Diamonds (ret)
82
Rep 566
Take a look & hope you find it
OP link: http://www.e90post.com/forums/showthread.php?t=342518
2007 Z4Si(gone)
Couple E30 Verts (DD) 2003 330i 2011 E93 335is - current fav |
02-16-2016, 09:53 PM | #14 |
///Kenney
118
Rep 796
Jeez. How do you even read the diagram?
02-16-2016, 09:55 PM | #15 |
///Kenney
118
Rep 796
Bought the car used. 2 years ago and never changed battery, but it's my I drive I know I never had these issues before I had a different mechanic look at it. My prior one pulled the fuse or killed it so it would kill battery
02-16-2016, 09:55 PM | #16 |
///Kenney
118
Rep 796
I have this same diagram, but I don't get how to read it. Pretty sure I'm needing to pull 2,23 and 31?
02-16-2016, 10:00 PM | #17 |
Rep 807
Which car?
F56 is CCC/M-ASK in 09/2007 and newer My bad, just saw you said it was the N52. Use F31. |
02-16-2016, 10:02 PM | #18 |
///Kenney
118
Rep 796
Oh never mind I figured out how to read it. Was fuse 31 killed it
02-16-2016, 10:04 PM | #19 |
///Kenney
118
Rep 796
My 06. Thanks all I needed to know besides my fine emission leak? P0456? I guess my I drive is faulty than well my (CCc) otherwise it'd turn on when car started if fuse was working?
02-16-2016, 10:07 PM | #20 |
Rep 807
Maybe someone more knowledgeable can chime in, but maybe you could get away with a used CCC without coding if it has the same options as your car. I would think you could source one for a few hundred bucks.
02-16-2016, 10:11 PM | #21 |
///Kenney
118
Rep 796
How do I go about that? Same part number as mine? Have to take it out to see.
02-16-2016, 10:12 PM | #22 | |
6 of Diamonds (ret)
82
Rep 566
2007 Z4Si(gone)
