      10-10-2015, 07:26 AM   #1
bimmereason
bimmereason's Avatar
Drives: G05 X5 40i, F10 535xi, F26 X4
BMW F25 LCI 6WB Retrofitted!
Since there are only a few resources online to put 6WB on F25, I made a short clip to present how the 6WB works on F25 X3 LCI. The coding part was kind of tough but generally solved all the problems and everything working properly.
Model: 2015 BMW F25 X3 20d xDrive (yeah... diesel)
Spec: JPN (RHD)
NBT Language: Japanese
Kombi Language: Traditional Chinese
Here is the footage how to install the 6WB on my F25.
Thank you~!
      10-10-2015, 08:35 AM   #2
Peter_R
Air Vice Marshall
Peter_R's Avatar
Cool
      10-11-2015, 03:39 PM   #3
Bimar
Bimar's Avatar
800
Drives: Bmw X
Costs? Must you have professional nav?
      10-11-2015, 08:08 PM   #4
bimmereason
Total cost is around $1500 USD, and yes the vehicle comes with navi system.
      10-11-2015, 10:01 PM   #5
Bimar
Bimar's Avatar
800
Drives: Bmw X
What I meant does this only work if you have professional Navi with updated instrument cluster,?
      10-12-2015, 09:03 PM   #6
terrywang
terrywang's Avatar
Australia
94
Drives: OG F87 M2
2016 BMW M2  [0.00]
Nice job dude.
My F25 20d (B47D20) xDrive doesn't have Sat Nav Pro fitted, so I don't even have EfficientDynamics gauge under RPM (it's a traditional pointer...).
Just wonder in this case if it is possible to fit the same stuff in? looks too cool to refuse...
BTW: Can you have a look at my post http://www.bimmerfest.com/forums/sho...d.php?t=864712
I am also concerned about the Sport+ mode (missing). Can it be enabled by ECU tuning?
      10-14-2015, 03:44 AM   #7
bimmereason
6WB work with the small screen head unit. It doesn't need the NBT or CIC with navi for retrofitting the cluster! Hopefully this can answer your question!
P.S. For vehicles don't come with factory navi or HUD, you may not have fiber-optic (MOST) built in the car. In this case you need to get extra MOST cable to install in between Kombi and Head Unit to make the 6WB Kombi work!
      10-14-2015, 12:24 PM   #8
Bimar
Bimar's Avatar
800
Drives: Bmw X
Thanks, understood!
      10-21-2015, 12:19 PM   #9
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
part number,
where did you buy it?
      10-22-2015, 02:51 AM   #10
bimmereason
Originally Posted by nyalpine90 View Post
part number,
I got it from my own source, but if you are in the States, you may get one from Bimmer Tech. Here is the LINK
Thank you!
      10-22-2015, 06:50 AM   #11
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
thanks
      11-23-2019, 11:17 PM   #12
willywi
Drives: BMW x3, BMW x5
Quick question how did you code it to the car? I don't think F25 have factory 6WB option.
      11-25-2019, 08:14 AM   #13
aspame82
Mr
Peru
21
Drives: BMW X3 XDrive28i Xline 2017
I did it. I used it BMW X5 F15 FA (changing the donor FA to my car VIN).
You load the FA adding 6WB (using F15 FA). Very important do not write FA to car.
Then you inject CADF file and finally VO code the DKOMBI.
Then FDL toDKOMBI: 1) choose tank capacity 66 liter (value available in F15). 2) search key word "F15" and change it by "F25" for all cases.
Also using FDL You can change logo to appear BMW instead of F15.
the good thing of using F15 FA is that you will see a F15 car when you have door open warning.
hope it helps.
BR
      05-25-2021, 08:56 AM   #14
hirurg78
Drives: BMW F15
6WB
Do you know if 6WB cluster from F01/F07/F12 will work on F15? I heard that there is different, someone says its the same, and it is possible to make it works.
      05-26-2021, 09:16 AM   #15
najnad
General of the Space Forces
najnad's Avatar
Drives: 11 X3 35i M-sport
how do you get the correct miles shown for your vehicle? would hate to install one and then it show either more miles or some tamper indication that will be problem when going to sell when moving on to another vehicle.
      06-03-2022, 05:58 PM   #16
daMANiack
daMANiack's Avatar
Australia
27
Drives: BMW F26 X4 35d
Hi,
I'm considering having a 6WB retrofitted to my 2016 F26 X4.
Can you recall if there was a car logo for the F26 X4 or F16 X6 car logo you can select?
Do you know if your X3 can be programmed by BMW due to non standard 6WB installed or does the original KOMBI have to be installed?
Cheerz
BR
2016 BMW F26 X4 35d, H&R spring lowered 30mm, QUAD exhausts
      06-10-2022, 07:44 AM   #17
timiboy
Drives: BMW E83 X3, F25 X3, E61 530xd
Question Vids not available
Hey guys,
what must one do to see the vids
Thanks,
Timiboy
      08-02-2022, 09:04 AM   #18
Eddy*5
Drives: x3 f25
yeah vids are down =/
