XBimmers | BMW X3 Forum BMW X3 and X4 Forums | F25 (2011 - 2017) | F26 (2014 - Current) Second Generation BMW X3 (F25) General Forum LED tail lights (xenon) burnt out
      09-17-2015, 11:50 AM   #1
smoothmoka
Drives: f25
Hi all,
Just wondering if anybody else had to replace the LED tail lights. I know it's very easy to replace but can they be fixed instead of the replacing the full assembly? My warranty expired as of May 2015 and my odometer is at 98000...not sure if dealership has any grace period on out of warranty replacement on them (wishful thinking).
Both outer left and inner right seem burnt out. I tried wiggling the wire on one of them and for a moment it lit up then dimmed out after 2 seconds.
Any advice would be very much appreciated!
Thanks.
      09-17-2015, 06:19 PM   #2
02420X3
Drives: 2011 X3 35i
I've had the same two replaced, one in warranty and one out. My recollection is that the inner one was priced at somewhere around $280 and the outer somewhere around $380. The problem appears to be with the control board, which is an integral part of the light and is not sold separately.
      09-18-2015, 06:31 AM   #3
Tnodlands
Drives: BMW X3 F25 2011
Wink LED tail lights
Mine also died and I replaced the complete inner tail light unit with an expensive new one.
I dismantled the old one by heating it in the stove. Unfortunatly I used too much heat, so the grey back-part deformed.
Anyway, I manage to split it apart in the glue seam and I took out the lead light unit for closer inspection. I hooked up a 12v supply and checked that voltage supply to the leds was OK, but no light. However after playing with the internal connectors and pulling/pushing the internal wiring the leds came alive again. So the failure could likely be due to bad contact or wire connection on the electronic boards.
To make a repair, the trick would be to take apart the glued halves of the unit without destroying it in the process.
      09-18-2015, 12:31 PM   #4
smoothmoka
Drives: f25
thanks for the responses...I appreciate it!
      09-18-2015, 04:21 PM   #5
Dave340
Dave340's Avatar
Drives: 2017 F25 & 2016 F30
I had my passenger inner light replaced under warranty last year.
      09-20-2015, 03:55 PM   #6
mge92
SPEED RACER
mge92's Avatar
Drives: BMW X5 M50d Mini JCW GP BMW M2
My inner left LED light went out have yet to replace it under warranty.
2019 BMW X5 M50d Artic Grey: Stealth Wrap | Clearplex |
2020 Mini JCW GP Racing Grey: Stealth Wrap | Clearplex |
2020 BMW M2 CS Misano Blue: ...
RIP - 2013 X3 xDrive28i Carbon Black: Enzo Flash Tune | ER Catless DP | Supersprint Quad Exhaust |
      09-24-2015, 10:17 PM   #7
96_Impreza
96_Impreza's Avatar
9
Drives: 96 Impreza,07 Vette,11 X3 35i
Below is my experience from another forum last year. I've since read posts that indicate that the problem is with cold solder joints on the rear-light assembly mini-circuit boards. Try searching for "cold solder joint"
""And here's an oddity. Over the past year, at four different times, all the rear lamps have failed except for the high-center brake lamp on the tailgate. The left outboard, right outboard, left tailgate and right tailgate lamps have failed which required replacement of the entire lamp assembly in each case. All covered under warranty.
We have Xenon headlamps which, I understand, gets you an upscale rear lighting package. LED maybe?
2011 X3 35i, bought new, now at 43,000 miles."
      09-25-2015, 10:53 AM   #8
smoothmoka
Drives: f25
Thanks for the info...I'll have to check it out!
      09-28-2015, 08:15 AM   #9
Tussy
Italy
Drives: X3 F25 2.0D XDRIVE WY31
The mini circuit board is protected by a glued plate. How does is it possible to remove. Are there any images to see how to repair the "cold solder joint". Thanks to all and sorry for my english. Bye
      10-11-2015, 05:04 PM   #10
Tussy
Italy
Hi to everybody. Today a friend of mine has resoldered all the joints on the circuit. The work takes above 30 minutes. After few minutes for dissipating the temperature caused by soldering i've mounted my tail led light and it is working very well! Cost: one beer! Bye
      10-11-2015, 10:37 PM   #11
96_Impreza
96_Impreza's Avatar
9
Bravissimo!
      10-12-2015, 12:26 PM   #12
Tussy
Italy
Thanks, it's only a suggestion for you! bye
      10-13-2015, 11:10 AM   #13
smoothmoka
Drives: f25
Grazie... for sharing! Glad it worked out for you!
      10-13-2015, 01:41 PM   #14
voipwizard
Drives: 2012 BMW X3
Anybody know how to disassemble the lights???
Hot gun maybe? Our friends in the Fatherland tend to make it difficult...
Thanks
      10-14-2015, 11:11 PM   #15
02420X3
Drives: 2011 X3 35i
Are you asking about disassembly of the light module, or removal of the light module from your X3?
The failed taillight which I have at hand has a thumb-sized circuit board, which is held in place by a bit of melted plastic. Nothing major to deal with there.
      10-16-2015, 08:51 AM   #16
voipwizard
Drives: 2012 BMW X3
I was asking if you know how to get to the offending circuit board. Some posters indicated that they struggled to get to the board.
Thanks!
      10-16-2015, 11:07 PM   #17
02420X3
Drives: 2011 X3 35i
It's easy to access. It's only held in place by the melty bit on the left and one connector. The whole board is about the size of my thumb.
      10-18-2015, 09:13 PM   #18
smoothmoka
Drives: f25
Awesome...this is a great help! Thanks for the pic!
      10-19-2015, 08:09 AM   #19
voipwizard
Drives: 2012 BMW X3
Perfect! Thank you !!!!
      10-19-2015, 08:33 PM   #20
kmarei
kmarei's Avatar
Egypt
410
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
The outer right hand side LED was intermittent on mine
I removed the tail light
You slide the black plastic piece to the left of the right tail light (or to the right of the left tail light) upwards
When you remove it, you reveal the 2X 10mm bolts
Removed the tail light, and since it was intermittent, I didn't think its was a soldering issue
Sure enough, the led panel has 2 gold colored contact points
I used sand paper on both of them
And cleaned the corresponding part in the cover that houses the bulbs
And bent them slight light outwards
So they would be touching those gold colored contacts points with more force when you reattach the bulb holder to the tail light
Sure enough, both tail lights work now
While I was there I also cleaned out all the bulbs with a tissue and some alcohol, since the bulbs were a little dirty
Also did the inner lights as well
Car looks good as new
      10-19-2015, 08:44 PM   #21
kmarei
kmarei's Avatar
Egypt
410
Link on how to remove the tail lights.
http://www.bavarianmw.com/guide-3549.html
      10-20-2015, 12:44 PM   #22
neelkc12
neelkc12's Avatar
Drives: x3
2011 BMW X3  [0.00]
Duh < Why did not I check with the forum before? Just replaced
Part Number Part Description Quantity Core Price Price Total
63217217314 electrical, rear lamps, tail lamps, tail lamp assy LIFT GATE, w/xenon Right 1 $0.00 $146.91 $146.91
Sub Total $146.91
Shipping method - Shipping $0.00
Handling Fee $0.00
Tax $9.18
Total $156.09
Copyright ©2000 - 2020, vBulletin Solutions Inc.
