      02-08-2015, 02:32 AM   #1
zzz
Belgium
12
Drives: G31 520i
Hooking up dash cam close to interior mirror
I managed to remove dome light console and tried to find good power source which turns off after the car is locked in order to hook up dash cam, but could not find any. Is there a power line closeby which behaves the same way as lighter power source, i.e. turns off after locking the car and after some delay? I would hate to run a cable all the way from mirror to the lighter socket at the bottom.
520i Touring
      02-08-2015, 03:17 AM   #2
PerryGunn
Idiot-in-chief
PerryGunn's Avatar
31
Drives: around: in: circles:
Do you have auto wipers? If so, you can tap into the rain sensor wiring as the power to the sensor is a switched live - don't think there's a delay after locking the car though, it should just switch on/off with the other car systems
I should say that I haven't tried this on the X3 but that's the way it works on other models of BMW
X3 F25 LCI 30d M Sport
Alpina Roadster S
      02-08-2015, 08:32 AM   #3
zzz
Belgium
12
Drives: G31 520i
Found it, and already did it
http://f30.bimmerpost.com/forums/sho...d.php?t=974007
520i Touring
      02-08-2015, 08:44 AM   #4
zzz
Belgium
12
Drives: G31 520i
Here are some photos...
520i Touring
      02-08-2015, 08:47 AM   #5
zzz
Belgium
12
Drives: G31 520i
step down DC-DC converter, extracted the one that came with the cam.
520i Touring
      02-08-2015, 01:41 PM   #6
mk3
Drives: 2014 X3 28i
What camera is that you're using?
      02-08-2015, 01:49 PM   #7
Mingstar88
Drives: BMW X3 35i
that's the mini 0803 or 0805 or 0806
      02-10-2015, 12:52 AM   #8
zzz
Belgium
12
Drives: G31 520i
Yep, mini 0805
520i Touring
      02-11-2015, 06:22 AM   #9
VinX3
Drives: 2015 X3
I just bought myself a Mini as well. I was debating between Mini and Mobius and decided to go w/ Mini because of the screen in the back. Did you built the AC-DC converter yourself?
      02-11-2015, 06:36 AM   #10
zzz
Belgium
12
Drives: G31 520i
I used the one supplied with mini, inside the lighter socket adapter.
520i Touring
      02-19-2015, 04:05 PM   #11
VinX3
Drives: 2015 X3
I'm thinking of doing the same. Does the converter get hot and may cause some issues down the line?
      02-20-2015, 12:04 AM   #12
zzz
Belgium
12
Drives: G31 520i
It's a high efficiency buck converter that shouldn't dissipate much.
      03-31-2015, 12:58 PM   #13
TuffLittleUnit
Drives: G26 420d MSport Pro
Just added a mini 0805 to mine but I've stuck with the 5v plug in. No problems hiding the cable - runs neatly under the dash, through the glove box, up the rubber trim on the door, tucks into the A pillar and finally along the roof liner. Given that these things aren't known for reliability I didn't want to start making it a permanent fixture in case it needs to go back to Amazon.
I avoided placing it close to the rear view mirror as I thought it might interfere with the light/rain sensors but I now realise these are located higher up where the mirror fixes to the windscreen. Meh.
G26 420d Gran Coupe MSport Black on black, MSport Pro Pack, Comfort Plus Pack, Harman Kardon audio
      03-31-2015, 01:13 PM   #14
Mingstar88
Drives: BMW X3 35i
please advise what parts used. can i buy the converter from ebay? looking to DIY as well
