BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > condensation in the headlights
      01-11-2006, 01:07 AM   #1
BMW_E90
BMW_E90's Avatar
57
Drives: 325i
Unhappy condensation in the headlights
i have condensation in both my headlights! ridiculous... it all started after i parked my car in the rain for a while... what should i do? will the dealer swap it out with a new one or what... :mad:
      01-11-2006, 02:51 AM   #2
jcoo085
jcoo085's Avatar
43
Drives: E90 320d
2005 320d  [0.00]
I sometimes get condensation in the bottom corners (near the grill) but it goes away after a while. If it hangs around or covers most/all of the headlight then take it to the dealer.
E90 320d - Black Ext/Fluid Grey Int | Steptronic | Business Navigation | PDC | Sunroof | Alarm
Exterior Pictures | Interior Pictures | Video
      01-11-2006, 06:20 AM   #3
eleven24
Foppa!
eleven24's Avatar
29
Drives: 2018 X5 xDrive35i
Take it to the dealer & get them swapped out. There shouldn't be condensation in there since they're sealed units.
Condensation + Electricity = Bad
      01-11-2006, 06:26 AM   #4
Paul330d
Torque junky
Paul330d's Avatar
France
115
Drives: Remapped e90 330d
2006 330d  [0.00]
2005 Fiat Panda 4x4  [0.00]
If they're xenons, then it's perfectly normal: xenon lamps burn very hot and need extra ventilation. For this reason, the headlight units are not sealed and humidity can get in. This is designed into the lights and is not a cause for concern. Once you start driving and pushing some air through the lights, the condensation should go.
      01-11-2006, 06:35 AM   #5
coolpetcat
Drives: BMW 320I Executive
get to the dealer, my one had that situation as well b4, then the dealer replaced it, everything is great now, good luck
      02-05-2006, 12:44 AM   #6
Armen52
Armen52's Avatar
34
Drives: 2006 330i
2006 330i  [0.00]
So I've had this problem as well and the head technican at my dealer took a look and said the headlights should be replaced. They are on order and I will be taking it in on or around the 23rd to get it done.
I've read through the various threads on this topic and it seems that most people had condensation early on when they picked up their car but not since then. On the other hand, I've had my car for months now and I still see the issue almost every time it is wet outside.
It also does not seem to go away even while the headlights are on for long periods of time. You would think it would since I imagine its very hot in the headlight assembly when the lights are one.
I will post an update after the service and let you know if the problem is reoccurring on the new set.
E90 330i delivered 6/29/2005, ZSP/ZPP/ZCW/Step, Arctic/Gray/Walnut
      02-05-2006, 04:38 AM   #7
David328M-Sport
Australia
101
Drives: F30 M-Sport 328i Estoril Blue
that happened to my old e36 halogen headlight. it was replaced with another unit. no more condensation.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
