BMW 3-Series (E90 E92) Forum
Where they wash the car for the first time?
01-03-2006, 09:53 AM | #1 |
Rep 2
When I took delivery of my jet black e46 2001 330ci the car had swirl marks already that took me three weeks to get rid of them.
Now I ordered a black e90 and was wondering if any of you knew where they wash the car for the first time, because if they do it at my local dealer I want them to stop and teach them how to properly wash a car (No circles)...Any inputs? |
01-03-2006, 09:54 AM | #2 | |
Rep 699
Drives: 2013 F30 335xi
01-03-2006, 09:55 AM | #3 |
Resident Detailer
Rep 17
The best thing I can tell you is to make sure they don't prep it.
When I order my 330i (about 5 months away), I am picking it up with plastic wrap still intact. I already told the BMW dealer this and they laughed, but agreed. Check out: www.autopia.org www.bettercarcare.com for detailing galore. ______________________________________________ edit: BTW, new here . I am a professional detailer. Hopefully I will be able to help out in the detailing area. |
01-03-2006, 10:18 AM | #4 |
Rep 137
Drives: 2006 325i
I have heard that it arrives at the prep center coverered in a heavy film that needs to be removed with a hot wash. It is also usually washed by the dealer when they prep for delivery.
Swirls probably caused by dirty water or sponge during the wash. |
01-03-2006, 10:23 AM | #5 |
Resident Detailer
Rep 17
Yep, swirls are caused from poor washing and drying techniques. Simply speaking, you should use at least 2 buckets (1 wash, 1 rinse) and 2 mitts (lambswool or cotton chenille). You should do 3-4 swipes then toss the mitt into the rinse bucket and agitate with your hand. When drying, try switching to a Waffle Weave Microfiber towel as compared to a bath towel, chamois, or Absorber.
Dealerships usually use rags, dirty mitts, brushes, caustic cleaners. There are far better ways to remove the plastic film, but I agree with you, Jimifighter, you need heat to get the plastic off. |
01-03-2006, 06:27 PM | #7 |
Rep 3,742
The exterior is coated with a protective coating otherwise known as cosmoline (helps prevent corrosion during shipping) When the cars arrive at the VPC, the cosmoline is removed with a hot kerosene bath/soak (drive through car wash type thing). After this the car is inspected and usually polished, but it appears these days that the VPC is not doing this as my car arrived with some dissolved cosmoline on the hood, roof and trunk lid.
My best advice, do not let your dealer detail the car. Do it yourself, as this is really the only way you are going to avoid the initial swirl marks. |
01-03-2006, 06:31 PM | #8 |
Rep 104
Its just a car. In my opinion, an every day driver is just that. Don't sweat the small stuff. Black is the toughest to maintain. In 3 or 4 years you will own another.
01-03-2006, 06:32 PM | #9 | |
Rep 3,742
If it was "just a car" the majority of us would not be here. |
01-03-2006, 06:38 PM | #10 |
Rep 2,059
E90 Peeps who have the black need to wash their own cars to ensure there are no swirl damage done to the clearcoat. If you already have swirls, you will need to wax it with canauba wax or of similar high quality wax to minimize the swirl effects on your paint finish.
330i 6MT l 255 HP @ 5900 rpm 214 lb-ft Torque @ 3500 rpm l Alpine White l Beige l Aluminum l ZSP l 494 l PDC
"Freude am Fahren" = "Joy to Drive" |
01-03-2006, 06:48 PM | #11 |
Throw your hands in the air, if you's a true playa.
79
Rep 436
Yep. Black is a swirl & dust magnet -- can't get away from that. Even sparkling graphite is a bit on the dust magnet side.
Anyway, the swirls are caused by the dealer -- believe it or not, my dealer uses a washing system with automatic brushes -- IDIOTS! I tell them with an exclaimation mark to keep away from my car each time I bring it it.
01-03-2006, 06:53 PM | #12 |
Rep 12,276
It's the dealer that does the poor washing. They think they are doing you a favor - and for most of their customers, they are. But for those of us that care about our cars finish - we're much better off not letting them get (this part meant literlly) their grubby mits on it.
I think it is bad luck to be superstitious |
