THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Connection failing / BMW Apps not working but USB audio works?
      07-06-2014, 10:43 AM   #1
HX_Guy
Drives: 2014 BMW M235i
Not sure what I'm doing wrong here, I have an M235i with the Tech Pkg and am using an iPhone 5S on the latest firmware (7.1.2) and can't seem to make this work.
Plugging in the phone via USB lighting cable (Apple original, tried another cable as well) will get it to show up under the External Devices area and I can access playlists, play songs, etc but can't get the BMW Connected App to work and none of the Apps are showing up under BMW Online.
I tried to do the Diagnostic Test and it fails every time. I also tried the M Laptimer and that also does not show up under Vehicle Info. I saw a video on YouTube that showed once you connect the phone and open the app, it's supposed to show a connecting screen on the iPhone? That doesn't happen either.
Any ideas? Thanks.
      07-06-2014, 12:35 PM   #2
HX_Guy
To add, I also tried my wife's iPhone 5 running iOS 6.X and same thing, does not connect.
      07-06-2014, 09:57 PM   #3
pikcachu
pikcachu's Avatar
1406
Drives: M235i (F22 Red angel)
the issue might be the cable... can you try a different one?
also is that an genuine cable?
      07-06-2014, 09:59 PM   #4
HX_Guy
Weirdest thing...got in the car tonight and all of a sudden it all works.
BTW I am using a genuine cable and also tried a different non genuine cable, bright worked earlier.
2014 BMW M235i 6MT
2012 Mercedes E350 Bluetec
      07-06-2014, 10:02 PM   #5
pikcachu
pikcachu's Avatar
1406
might some dumb but make sure you plug the cable all the way into the connector on the car
      07-06-2014, 10:06 PM   #6
HX_Guy
I don't think it could be that because the Connection Assistant should be in the menu even when nothing is plugged in. That's how I figured it was working, got in the car and the last screen up was the ConnectedDrive menu. All of a sudden I noticed the Connection Assistant was part of the list.
2014 BMW M235i 6MT
      07-07-2014, 12:39 PM   #7
SteveAustin
SteveAustin's Avatar
Drives: 2014 228i
Any ideas? Thanks.
See my post - also I have had to reboot my phone to get it to work (on occasion) but the app has to be open. The FAQs in the App tell you everything, read them.
http://www.2addicts.com/forums/showp...14&postcount=5
      07-07-2014, 12:44 PM   #8
HX_Guy
That wasn't it though because in the ConnectedDrive menu, the BMW Apps sections was completely missing...
For some strange reason, it appeared last night. I wonder if the car had to get some sort of activation over the air from BMW? Because the Sat radio also started working.
      07-10-2014, 12:26 PM   #9
SteveAustin
Drives: 2014 228i
I find it very flaky as well and you have to have it unlocked and the screen open to the App to get the Online Apps to show. It also seems to not work well when on WiFi so get out of range of your home's router. Just some things I've noticed.
      07-10-2014, 12:29 PM   #10
HX_Guy
It's been working great since it started working...not sure what the initial holdup was but all is good.
It's damn stupid though how the BMW Connect app has to be open all the time though, you can't even lock the phone to shut off the screen. Plus, if you make or receive a phone call, it exits the app and you have to manually open it again. Jeez, who programmed this app?
      07-10-2014, 01:06 PM   #11
pikcachu
pikcachu's Avatar
1406
What do you mean?
      07-14-2014, 05:22 PM   #12
SteveAustin
Drives: 2014 228i
Originally Posted by pikcachu View Post
What do you mean?
I was playing around with it in my garage - the thing just appears flaky if your phone is on WIFI. I could be wrong about the cause.
      07-14-2014, 05:29 PM   #13
pikcachu
pikcachu's Avatar
1406
Ah...I has nothing to do with WIFI but with the fact you were inside the garage...
It connects through 3G so won't work very well inside buildings
2addicts
