      01-01-2019, 12:16 PM   #1
$M2
$M2's Avatar
72
Drives: 2019 X3 M40i
Let's talk radar detectors
I have been out of the "detector" market for quite awhile. So I did the research thing and have determined that Escort, Belltronics and Valentine are the big 3.
I would use a blend mount with hard tap to the mirror for installation.
So what are you currently or contemplating using? What influenced your decision? And how many issues with the sensors for false triggers? I have read the thread on our windshield and interference but practical everyday users have the real perspective.
Thanks in advance.
      01-01-2019, 12:50 PM   #2
LostX
Drives: N/A
Thanks in advance.
How do they compare with Thinkware and Blackvue?
      01-01-2019, 01:37 PM   #3
BMWZ4
BMWZ4's Avatar
1910
Drives: '23 X1/'23 Allroad Progressiv
Thanks in advance.
Those are dash cams, OP is asking about radar detectors.
OP, I went with Beltronics based on other user's feedback, specifically around laser detection tech used by OPP and Surete in Quebec
So far so good, a few false alarms here & there but not a constant issue.
      01-01-2019, 01:39 PM   #4
AnOldBiker
Jim
AnOldBiker's Avatar
Drives: 2019 X5 XDrive 40i
Am I wrong, or are we talking apples to oranges ?
Thinkware & Blackvue are dash cams (or apples),
Escort, Belltronics and Valentine are radar detectors (oranges).
      01-01-2019, 01:47 PM   #5
LostX
Drives: N/A
Nope, you guys are right, I was thinking incorrectly.
      01-01-2019, 04:40 PM   #6
TXSoxFan
Drives: 2018 M3
Head over to RDforum.org . All you could ever want to know about detectors, etc.
      01-01-2019, 05:12 PM   #7
$M2
$M2's Avatar
72
Thanks. Been all over that forum. Just wondering with our windshields if there are any specific issues with interference.
      01-01-2019, 05:55 PM   #8
Orient330iNYC
Drives: 2023 X7 40i
if you have gesture control, you may have a non stop rear laser alert.
ended up putting some gaffers tape over the emitter thats on the roof console, even shutting off gesture control does not disable the emitter.
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC
SROC31702.00
$M271.50
      01-01-2019, 07:48 PM   #9
$M2
$M2's Avatar
72
Thank you for the info. That is what I was looking for.
      01-01-2019, 07:52 PM   #10
MechX3M40i
MechX3M40i's Avatar
Drives: X3 M40i Blue/Cognac
Another member posted a thread about this with a YouTube video. You might want to check it out...
Radar Detector Laser keeps going off.. found interior location https://x3.xbimmers.com/forums/showthread.php?t=1569184
      01-01-2019, 08:17 PM   #11
Jeepersjoey
Stay Tuned!
Drives: 2018 X3 m40i
Mine is a Escort 360.
Mounted under the rear view mirror.
No issues with mine. Works just fine. No false alarms that are apparently caused by my car.
I leave in Highway mode.
Paul
$M271.50
      01-01-2019, 08:51 PM   #12
Rhidium
Drives: 2019 BMW X3
Yup.. Look at the video for the position of your gesture control or it will drive you nuts setting off the laser warning.
I have a Valentine One and it senses the Ka band easily. Haven't seen any issues with it. Very little tasks alarm on its logic mode. I have no experience with other brands (been a V1 user for over 20 years and it has worked great)
      01-02-2019, 01:44 AM   #13
darrylo
Head Idiot
darrylo's Avatar
Drives: 2018 G01 X3 x30i
Earlier discussion of radar detectors and gesture control: https://x3.xbimmers.com/forums/showthread.php?t=1477151
$M271.50
      01-02-2019, 09:04 AM   #14
therealtk
therealtk's Avatar
64
Drives: '12 E92 ZCP
I've got a valentine one mounted under the mirror with near constant laser false alarms which, is stemming from the gesture control. I'm planning on programming the laser function off to remedy.
$M271.50
      01-02-2019, 09:52 AM   #15
verysideways
Lateral grip estimator
verysideways's Avatar
957
Drives: i4, M2
Why not turn off gesture control instead?
'20 BMW M2
'23 BWM i4 Mora
'10 Porsche 997
'02 Morgan Aero 8
http://petrolhead.tours
      01-02-2019, 10:05 AM   #16
Rhidium
Drives: 2019 BMW X3
Turning it off doesn't turn off the sensor detecting the gestures hence it's still emitting the wavelength to set off the laser warning.
I've determined that the whole thing is coming from the gesture system.. I've covered the sensor and it doesn't go off anymore. The thought that it was coming from the rear view mirror was partially wrong.. it was reflecting, not refracting the signal from the gesture control.
      01-02-2019, 10:22 AM   #17
EvanF
Drives: 2019 X3
Tangential question: am I correct in assuming the 12v "cigarette lighter " plug in the front console (2019 X3, non-wireless) is always on rather than switching on/off with the car? Will leaving a radar detector plugged in 24/7 kill the battery, or does the car have some way of cutting the power when the battery gets too low?
Thanks!
      01-02-2019, 10:48 AM   #18
MechX3M40i
MechX3M40i's Avatar
Thanks!
That outlet will be cut off when car is shut down. So no issues with slow battery drain.
      01-02-2019, 10:59 AM   #19
Wgosma
Drives: 2012 F25 X3 28i (N52)
+1 re: V-1. Been using my 13 y/o unit in each car Ive purchased; detector plus one eye glued to the rear view mirror = no excess speed violations.
      01-02-2019, 11:17 AM   #20
bmwgrande
bmwgrande's Avatar
I have a V1 as well. I programmed off the laser detection so as not to go crazy with the gesture control creating false alerts. I'm running the cable to the 12v plug at the rear of the center console, and have it mounted with a BlendMount.
Between the excellent detection range of the V1 and using Waze via Apple Carplay, I've so far not had any issues (knock on wood). And for the past 12 years of using the V1, the only two times I've ever been tagged were both in VA when the cops were pacing me in undercover cars, one apparently from 4 lanes over and a couple hundred feet back.
2019 X3 M40i Alpine White
$M271.50
      01-02-2019, 12:44 PM   #21
deladude
Drives: X3 M40i
I use a V1 that I've had for well over ten years now and it has paid for itself ten fold. I drive the I89 corridor a lot and NY Highway Patrol is usually very active. It saves my ass on the regular.
Honestly I haven't looked at the market recently either so my opinion is probably dated but the directional detection and range is why I went with V1. At the time Passport was the only competitor that came close to the range V1 has and that matters a lot.
FWIW most of us found that mirror tapping in G01 is not viable. I used a fuse tap and it worked out great, no wire splicing. I have it mounted directly below the rear view mirror and haven't had any issues (no gesture controls here).
$M271.50
      01-02-2019, 01:58 PM   #22
Rhidium
Drives: 2019 BMW X3
Happy to hear others have the same great experience with V1..
