02-15-2019, 04:21 PM | #1 |
Rep 13
Full Screen CarPlay
Full screen AppleCarPlay patch I purchased from he NET worked perfectly.
https://www.ebay.com.au/itm/BMW-FSC-...53.m2749.l2649 Cheapest on the net @ $50 USD. The seller does all the checking for you so you don't make any mistakes. My car is a BMW X3 30D M-SPORT - build October 2018. Will attach pic shortly Last edited by geodeo; 02-15-2019 at 09:46 PM.. Reason: addidng pic |
02-15-2019, 10:31 PM | #3 |
Rep 8,283
Drives: 2024 X5 M60i
My OCD is going nuts over the amount of missed calls/voicemails and unread text messages you have displayed..
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
02-16-2019, 04:04 AM | #6 |
The limit of adhesion is my home.
1710
Rep 3,778
OMG.....jelly.....
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
02-16-2019, 05:26 AM | #8 |
Rep 214
02-16-2019, 05:28 AM | #9 |
Rep 13
Bought it on ebay - seller then sends you instructions and .bin file.
Copy file to usb and then plug it into a usb port. Took about 5 minutes. "Thank for you purchasing BMW FSC Code Full set & Apple Carplay Fullscreen & Android Screen mirroring & VIM Activation via USB for NBT EVO. UPDXXXXX.bin ( with numbers ) - enable UPD00000.bin - disable before going to workshop Install instructions: 1. Copy provided UPD BIN UPDXXXXX.bin file onto an available blank USB flash memory stick with FAT32 file system. 2. Turn ignition on or start engine of your car and insert the USB flash drive into the USB port in glove box/center console. 3. Wait at least 30 seconds and then remove the USB flash drive. 4. Reboot iDrive system by pressing and holding the volume button. 5. Once the NBT EVO has restarted, it will restart itself after 60-90 seconds, so just wait. 6. Wait until the NBT EVO has restarted and once again reboot iDrive system by pressing and holding the volume button. 7. Enjoy Apple Carplay Fullscreen & Android Screen mirroring & VIM." |
02-16-2019, 05:30 AM | #10 | |
Rep 214
I’m led to believe USB key installs no longer work. Have you had your car serviced in recent times? |
02-16-2019, 05:35 AM | #12 | |
Rep 214
UPDATE: They referred me to their other listing for coding the new software. https://www.ebay.com/itm/BMW-I-level....c100903.m5276 Last edited by cvee; 02-16-2019 at 05:41 AM.. |
langood0.00 |
02-16-2019, 10:16 AM | #13 | |
Rep 140
02-18-2019, 02:42 PM | #14 | |
Rep 140
Had this done tonight, had all sorts of issues with PC's (all my problems) but we finally got there, now I have widescreen carplay |
02-18-2019, 03:02 PM | #15 | |
Rep 214
From their eBay description they made it sound like a self coding program that you ran yourself. |
02-18-2019, 03:35 PM | #16 |
Rep 140
Depending on the version level it could be a usb install or remote coding, mine needed the remote luckily I already had the cable from my F30 years ago
02-21-2019, 03:09 PM | #17 | |
Rep 927
02-22-2019, 07:00 AM | #18 |
Rep 201
So the key will work multiple times on your OWN vehicle? So if it does flash back, I can just reuse the file again? This isnt something Bimmercode can do?
02-22-2019, 08:53 AM | #20 |
BMW Client Advisor
3487
Rep 2,503
Drives: 2020 M340i
I need this! Much cheaper than what bimmercode charges
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
02-22-2019, 11:47 AM | #21 |
Rep 24
02-22-2019, 12:00 PM | #22 |
BMW Client Advisor
3487
Rep 2,503
Drives: 2020 M340i
Maybe they include a "stock" file as well so that you can revert it back to stock
